[OSGeo-Discuss] RE: Harvesting from a Geoportal Extension 9.3.1
jforne jforne at linz.govt.nz
Thu Feb 3 19:44:49 PST 2011
Hi Marten - thanks for your advice - much appreciated!
Ian, do you know what the URL is for the CSW interface?
Cheers,
John
John Forne
New Zealand Geospatial Office |
DDI: +64 4 496 5404
www.geospatial.govt.nz<http://www.geospatial.govt.nz/>
Land Information New Zealand  l  Toitu te whenua
Lambton House  l  160 Lambton Quay  l  PO Box 5501  l  Wellington 6145  l  New Zealand | Fax +64 4 498 3519
From: marten [via OSGeo.org] [mailto:ml-node+5985461-224158555-288785 at n2.nabble.com]
Sent: Thursday, February 03, 2011 5:30 AM
To: John Forne
Subject: Re: Harvesting from a Geoportal Extension 9.3.1
hi John,
it appears as if you've registered the homepage of the Geoportal. the CSW interface has its own endpoint. For example:
http://gptogc.esri.com/geoportal/csw/discovery?request=GetCapabilities&service=CSW&version=2.0.2
The open source Geoportal Server (http://esriurl.com/geoportalserver) implements CSW 2.0.2 and depending on what the implementer has configured supports the OGCCORE profile (always), ISO-Application Profile (most useful if the catalog only has ISO metadata), and the INSPIRE Discovery Service (sort of like ISO-AP but not entirely).
cheers,
@martenhogeweg
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5985461.html
To unsubscribe from Harvesting from a Geoportal Extension 9.3.1, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5968645&code=amZvcm5lQGxpbnouZ292dC5uenw1OTY4NjQ1fC0zOTI0ODQ0NQ==>.
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Harvesting-from-a-Geoportal-Extension-9-3-1-tp5968645p5991431.html
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110203/f429b9c6/attachment-0002.html>
More information about the Discuss mailing list
