[OSGeo-Discuss] Batch geocoding
Alvaro Zabala azabala at gmail.com
Sat Feb 5 09:44:12 PST 2011
Do you know cartociudad project, from spanish IGN?
It have web services related with spanish street map, and one of this is
geocoding service:
http://www.cartociudad.es/portal/pdf/CARTOCIUDAD_Direcciones.pdf
Best regards
On 4 February 2011 21:27, JP Glutting <jpglutting at gmail.com> wrote:
> Hi Wladimir,
> That is sort of what I thought. Too bad. I was just in Barcelona yesterday,
> at the CSIC, to get data. Where do you work?
> I am on the geoinquiets list too, but I am afraid I am on so many lists and
> in so many projects that I don't keep close track of them all. I should hop
> over and introduce myself, though.
> Fins aviat,
> JP
> Public Health - GIS - Bioinformatics
> http://www.bmeisis.com
> <http://www.bmeisis.com/>http://www.jpglutting.com
> On Fri, Feb 4, 2011 at 7:18 PM, Wladimir Szczerban <bolosig at gmail.com>wrote:
>> Hi JP,
>> I live in Barcelona and unfortunately there is no open geocoding service
>> in Barcelona. In the group of geoinquietos (http://www.geoinquiets.cat/
>> or http://wiki.osgeo.org/wiki/Geoinquiets_Barcelona) we are trying to get
>> the ICC (http://www.icc.cat/) the official agency open the geocoding
>> service they have.
>> Cheers,
>> BOLO
>> 2011/2/4 Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>> Any initiative for OA is appreciated highly ;o)
>>> Best,
>>> hj
>>> *Von:* discuss-bounces at lists.osgeo.org [mailto:
>>> discuss-bounces at lists.osgeo.org] *Im Auftrag von *JP Glutting
>>> *Gesendet:* Freitag, 4. Februar 2011 16:17
>>> *An:* OSGeo Discussions
>>> *Betreff:* Re: [OSGeo-Discuss] Batch geocoding
>>> There might be a data sharing initiative, there are several different
>>> actors (city, regional government, etc.). I don't know all of what there is
>>> out there, and the data was originally collected for another project.
>>> I think I will be Ok with Yahoo. If it works out, it shouldn't be
>>> difficult to export the dataset for openaddresses. It isn't my data, though,
>>> so I will have to ask permission first. It seems like a good idea, though.
>>> Cheers,
>>> JP
>>> On Fri, Feb 4, 2011 at 3:49 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>>> *Gesendet:* Freitag, 4. Februar 2011 15:34
>>> Hi Hans-Jörg,
>>> I am not aware that Barcelona (the city?) has a very open geodata
>>> strategy, but that certainly would be nice. If you know of anyone in the
>>> area who might know more, I am more than willing to contact them.
>>> *[shj] my mistake. I thought I had read something on this some time ago.
>>> Maybe also because Spain has strong support in the FOSS domain.*
>>> I have the addresses, do you mean the coordinates? The address format is
>>> not ideal, but I am pretty happy with them, as they seem to geocode well in
>>> the tests I have done.
>>> *[shj] yes, addresses along with co-ordinates.*
>>> The Yahoo API allows geocoding of 50k addresses a day, which is plenty
>>> for what I need. I am going to try to use that.
>>> *[shj] that’ll certainly do.*
>>> Cheers,
>>> JP
>>> On Fri, Feb 4, 2011 at 3:26 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>>> wrote:
>>> Hi JP
>>> Barcelona is unfortunately not well covered yet in OA. But I thought that
>>> Spain has a very “open” strategy in terms of providing geodata. If you
>>> manage to get Barcelona addresses (perhaps from council or any other
>>> “official body”) the OA team will insert these into OA and then you can use
>>> the REST service.
>>> Good luck!
>>> -hj
>>> *Gesendet:* Freitag, 4. Februar 2011 15:24
>>> Thanks for all the responses! I will track them all down and see how they
>>> work.
>>> Stark, I have 146,472 addresses in the city of Barcelona. Many of them
>>> are duplicates, but at the very least I have 31,514 that need to be coded,
>>> although that would leave out many that I want to use. I am in the process
>>> of developing filters to clean out apartment numbers, etc., to be able to
>>> pull a single coordinate for a whole set of addresses, and there are at
>>> least 6,000 that are invalid (from the original 146k, so 140k). It is a lot.
>>> I will take a look at openaddresses and do some testing.
>>> Thanks!
>>> JP
>>> On Fri, Feb 4, 2011 at 3:10 PM, Stark Hans-Jörg <hansjoerg.stark at fhnw.ch>
>>> wrote:
>>> The OpenAddresses project (www.openaddresses.org) is supposed to solve
>>> exactly your problem.
>>> You can use the provided geocoding services (
>>> http://code.google.com/p/openaddresses/wiki/RESTService)
>>> OpenAddresses has some regions where data was donated – there you will
>>> get high-quality results. Unfortunately this is not yet globally available…
>>> Hth
>>> -hj
>>> *Gesendet:* Freitag, 4. Februar 2011 14:34
>>> *An:* discuss at lists.osgeo.org
>>> *Betreff:* [OSGeo-Discuss] Batch geocoding
>>> Hello,
>>> I have a large set of addresses (around 150k) that I need to geocode for
>>> a study (my Masters thesis on heat-related mortality). I am looking into
>>> different solutions, but I can't find anything that seems like it would work
>>> properly.
>>> I could script a solution using Google's map API, but there is a limit of
>>> 2,500 addreses per day (I can get around them with a little patience).
>>> Right now the best solution I am looking at geopy for geocoding addresses
>>> (http://code.google.com/p/geopy/). It seems like a good system, I think
>>> I can use it to pull addresses out of my database and write back
>>> coordinates. There is one thing that I am not sure, about, though, is
>>> whether I am actually allowed to use the Google API without my use being
>>> liked to a specific web page. The terms of service and form for getting a
>>> Google API key require a URL linked to a Google account. In fact, it looks
>>> like the API can only be used through a web site:
>>> "5.2 *Account Key*. After supplying Google with your account information
>>> and the URL of your Maps API Implementation, and accepting the Terms, you
>>> will be issued an alphanumeric key assigned to you by Google that is
>>> uniquely associated with your Google Account and the URL of your Maps API
>>> Implementation. Your Maps API Implementation must import the Google Maps
>>> APIs using this key as described in the Maps APIs Documentation<http://code.google.com/apis/maps/documentation/>,
>>> and Google will block requests with an invalid key or invalid URL. You may
>>> only obtain and use a key in accordance with these Terms and the Maps
>>> APIs Documentation <http://code.google.com/apis/maps/documentation/>."
>>> So it looks like I can't even get it to work without a URL.
>>> I can always write a script that loops through results extracted from the
>>> database, creates URLs and parses the XML results one at a time, but that
>>> seems like a fairly inelegant solution.
>>> Does anyone have any good ideas about how to geocode a few thousand
>>> addresses?
>>> Many thanks,
>>> JP
>>> Discuss mailing list
>>> Discuss at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/discuss
Alvaro Zabala Ordóñez
azabala[en]gmail[punto]com
alvaro.zabala[en]juntadeandalucia[punto]es
Tlf: 954 995 572
Gabinete de Normalización y Calidad
Servicio de Coordinación y Desarrollo de Sistemas Horizontales.
D.G. de Innovación y Administraciones Públicas.
Consejería de Innovación, Ciencia y Empresa, Junta de Andalucía
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20110205/ef79ca51/attachment-0002.html>
More information about the Discuss mailing list
