[OSGeo-Discuss] Re: Discuss Digest, Vol 50, Issue 40
Marten Hogeweg mhogeweg at esri.com
Sat Feb 19 09:10:16 PST 2011
Shp.xml are normal metadata XML files you can create with any metadata editor. For example the Geoportal Server: http://gptogc.esri.com. Sign up, create FGDC metadata (or iso dataset metadata) save, export to you shapefile and rename to yourshapefile.shp.xml.
Setup your own catalog using this product? Visit http://geoportal.sourceforge.net. Does not require any Esri cots license and uses the now *free* arcgis online map services (http://www.esri.com/software/arcgis/arcgisonline/standard-maps.html).
Marten
On Feb 19, 2011, at 9:00 AM, "discuss-request at lists.osgeo.org" <discuss-request at lists.osgeo.org> wrote:
> Send Discuss mailing list submissions to
>        discuss at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/discuss
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        discuss-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Discuss digest..."
> Today's Topics:
>   1. Creating *.shp.xml files with open source tools (Dan Putler)
>   2. Re: Creating *.shp.xml files with open source tools (Bob Basques)
>   3. Re: Creating *.shp.xml files with open source tools (Alex Mandel)
>   4. RE: Creating *.shp.xml files with open source tools
>      (Kralidis,Tom [Ontario])
>   5. Re: Creating *.shp.xml files with open source tools (Dan Putler)
>   6. Re: Creating *.shp.xml files with open source tools
>      (Yves Jacolin (free))
> Message: 1
> Date: Fri, 18 Feb 2011 08:59:51 -0800
> From: Dan Putler <dan.putler at sauder.ubc.ca>
> Subject: [OSGeo-Discuss] Creating *.shp.xml files with open source
>        tools
> To: OSGeo Discussions <discuss at lists.osgeo.org>
> Message-ID: <4D5EA587.7040908 at sauder.ubc.ca>
> Content-Type: text/plain; charset="ISO-8859-1"; format=flowed
> All,
> I wanted to know if there were open source tools available to create
> metadata *.shp.xml files to distribute with a shapefile set.
> Thanks,
> Dan
> Message: 2
> Date: Fri, 18 Feb 2011 11:04:36 -0600
> From: "Bob Basques" <Bob.Basques at ci.stpaul.mn.us>
> Subject: Re: [OSGeo-Discuss] Creating *.shp.xml files with open source
>        tools
> To: "OSGeo Discussions" <discuss at lists.osgeo.org>
> Message-ID: <4D5E5244020000A800026A7C at heckle>
> Content-Type: text/plain; charset="us-ascii"
> I'd be interested in this as well, with the added request that the generation is adhereing to some standard, like USGS or ???
> thanks
> bobb
>>>> Dan Putler <dan.putler at sauder.ubc.ca> wrote:
> All,
> Thanks,
> Dan
> Discuss at lists.osgeo.org
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/discuss/attachments/20110218/12c9130f/attachment-0001.html
> Message: 3
> Date: Fri, 18 Feb 2011 11:36:08 -0800
> From: Alex Mandel <tech_dev at wildintellect.com>
>        tools
> To: discuss at lists.osgeo.org
> Message-ID: <4D5ECA28.2040505 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1
> I created an experimental plugin for QGIS to deal with Metadata xml
> records. We never got the creation part finished, but there should be
> template xml files for FGDC, ISO and some other standards (USGS and all
> US agencies follow FGDC, and now the FGDC variant of a new ISO format).
> Though FGDC only finished their variant of the ISO last year so it has
> not been included yet.
> There are a few other tools out their: CatMDEdit
> http://sourceforge.net/projects/gimed/ was also announced a few months
> back with support for INSPIRE
> Geonetwork can also be used to edit the same info, I just can't remember
> if it makes an xml you can download to pack with your file.
> I think there's at least one other QGIS component in the works but I
> don't know the ETA on it.
> Thanks,
> Alex
>> thanks
>> bobb
>> All,
>> Thanks,
>> Dan
> Message: 4
> Date: Fri, 18 Feb 2011 14:55:31 -0500
> From: "Kralidis,Tom [Ontario]" <Tom.Kralidis at ec.gc.ca>
> Subject: RE: [OSGeo-Discuss] Creating *.shp.xml files with open source
>        tools
> To: <tech at wildintellect.com>,   "OSGeo Discussions"
> Message-ID:
>        <DB58B7551932BF47AE1BF406D287C444032E3DC5 at OntExch3.ontario.int.ec.gc.ca>
> Also check out http://www.fgdc.gov/metadata/iso-metadata-editor-review.
> It also depends on what your metadata requirements are in terms of
> standards support.  ISO 19139:2007 (or some profile of, such as North
> American Profile) is the metadata standard of choice for many SDI
> actitivites currently.
> ..Tom
>> -----Original Message-----
>> From: discuss-bounces at lists.osgeo.org
>> [mailto:discuss-bounces at lists.osgeo.org] On Behalf Of Alex Mandel
>> Sent: Friday, 18 February 2011 14:36
>> open source tools
>> Metadata xml records. We never got the creation part
>> finished, but there should be template xml files for FGDC,
>> ISO and some other standards (USGS and all US agencies follow
>> so it has not been included yet.
>> few months back with support for INSPIRE Geonetwork can also
>> be used to edit the same info, I just can't remember if it
>> works but I don't know the ETA on it.
>> Thanks,
>> Alex
>>> thanks
>>> bobb
>>> All,
>> to create
>>> Thanks,
>>> Dan
> Message: 5
> Date: Fri, 18 Feb 2011 12:08:32 -0800
>        tools
> To: <discuss at lists.osgeo.org>
> Message-ID: <4D5ED1C0.7020405 at sauder.ubc.ca>
> Thanks Tom and Alex. Both of your comments were very helpful. Looking at
> the link that Tom sent, it seems that GeoNetwork is the solution to the
> problem.
> Dan
>> ..Tom
>>> open source tools
>>> Thanks,
>>> Alex
>>>> thanks
>>>> bobb
>>>>>>> Dan Putler<dan.putler at sauder.ubc.ca>  wrote:
>>>> All,
>>> to create
>>>> Thanks,
>>>> Dan
> Message: 6
> Date: Sat, 19 Feb 2011 12:23:44 +0100
> From: "Yves Jacolin (free)" <yjacolin at free.fr>
>        tools
> Message-ID: <201102191223.44932.yjacolin at free.fr>
> Content-Type: Text/Plain;  charset="iso-8859-1"
> Hello,
> Note that you can use SpatialDataIntegrator to import data to GeoNetwork Node
> or create Metadata XML  file.
> see http://www.talendforge.org/wiki/doku.php?id=sdi:mainpage#tutorials for
> more information.
> This could not be the best solution for your user case though but seems
> interesting to talk about it.
> Y.
> Le vendredi 18 f?vrier 2011 21:08:32, Dan Putler a ?crit :
>> problem.
>> Dan
>>> ..Tom
>>>> open source tools
>>>> Thanks,
>>>> Alex
>>>>> thanks
>>>>> bobb
>>>>> All,
>>>> to create
>>>>> Thanks,
>>>>> Dan
> Yves Jacolin
> End of Discuss Digest, Vol 50, Issue 40
More information about the Discuss mailing list
