[OSGeo-Discuss] problem loading .ecw to store
hosuresh
suri.hosur at gmail.com
Wed Jan 4 07:18:24 EST 2012
Hi...
I am new to geoserver...
want to load the .ecw to the store but its displaying some error like
2012-01-04 17:32:53,302 INFO [org.geoserver] - Loaded workspace 'topp'
2012-01-04 17:32:53,307 INFO [org.geoserver] - Loaded store 'arcGridSample',
enabled
2012-01-04 17:32:53,311 INFO [org.geoserver] - Loaded coverage store
'arcGridSample'
2012-01-04 17:32:53,746 WARN [referencing.factory] - Axis elements found in
a wkt definition, the force longitude first axis order hint might not be
respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
NORTH], AUTHORITY["EPSG","54004"]]
2012-01-04 17:32:53,828 INFO [org.geoserver] - Loaded coverage 'Arc_Sample',
enabled
2012-01-04 17:32:53,842 INFO [org.geoserver] - Loaded coverage
'arcGridSample'
2012-01-04 17:32:53,875 WARN [gce.imagemosaic] - Unable to set ordering
between tiff readers spi
2012-01-04 17:32:53,900 WARN [gce.imagemosaic] - Unable to set ordering
between jp2 readers
spi-it.geosolutions.imageio.plugins.jp2ecw.JP2GDALEcwImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderCodecLibSpi
2012-01-04 17:32:53,901 WARN [gce.imagemosaic] - Unable to set ordering
between jp2 readers
spi-it.geosolutions.imageio.plugins.jp2ecw.JP2GDALEcwImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderSpi
2012-01-04 17:32:53,903 WARN [gce.imagemosaic] - Unable to set ordering
between jp2 readers
spi-it.geosolutions.imageio.plugins.jp2mrsid.JP2GDALMrSidImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderCodecLibSpi
between jp2 readers
spi-it.geosolutions.imageio.plugins.jp2mrsid.JP2GDALMrSidImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderSpi
2012-01-04 17:32:54,229 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
2012-01-04 17:32:54,230 INFO [org.geoserver] - Loaded store 'img_sample2',
enabled
2012-01-04 17:32:54,231 INFO [org.geoserver] - Loaded coverage store
'img_sample2'
2012-01-04 17:32:54,378 INFO [org.geoserver] - Loaded coverage 'Pk50095',
enabled
2012-01-04 17:32:54,379 INFO [org.geoserver] - Loaded coverage 'img_sample2'
2012-01-04 17:32:54,425 INFO [org.geoserver] - Loaded layer 'Pk50095'
2012-01-04 17:32:54,426 INFO [org.geoserver] - Loaded store 'mosaic',
enabled
2012-01-04 17:32:54,426 INFO [org.geoserver] - Loaded coverage store
'mosaic'
2012-01-04 17:32:54,430 INFO [org.geoserver] - Loaded coverage 'mosaic',
enabled
2012-01-04 17:32:54,431 INFO [org.geoserver] - Loaded coverage 'mosaic'
2012-01-04 17:32:54,511 WARN [imagemosaic.catalog] -
BBOXFilterExtractor::extractBasicProperties(): passed typename is null,
using: mosaic
am not getting what mistake i am doing...
Geoserver Version:2.1.1
I downloaded the gdal-plugin and imageio-ext
and installed properly even set the path correctly...
My Raster Data Store is appearing like:
# Raster Data Sources
AIG - Arc/Info Binary Grid (AIG) Coverage Format
ArcGrid - Arc Grid Coverage Format
DTED - DTED Coverage Format
ECW - ECW Coverage Format
EHdr - EHdr Coverage Format
ENVIHdr - ENVIHdr Coverage Format
ERDASImg - Erdas Imagine Coverage Format
GeoTIFF - Tagged Image File Format with Geographic information
Gtopo30 - Gtopo30 Coverage Format
ImageMosaic - Image mosaicking plugin
JP2ECW - JP2K (ECW) Coverage Format
JP2MrSID - JP2K (MrSID) Coverage Format
MrSID - MrSID Coverage Format
NITF - NITF Coverage Format
WorldImage - A raster file accompanied by a spatial data file
but when i select ECW and mention the .ecw file in store just the store is
creating when i go to layers
the store is appearing but once i select that store its not displaying
anything...
Pleasse help me to come out from it...
Regards,
SURESH HOSUR
View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-loading-ecw-to-store-tp7150183p7150183.html
Sent from the OSGeo Discuss mailing list archive at Nabble.com.
More information about the Discuss
