[OSGeo-Discuss] problem loading .ecw to store
Jody Garnett
jody.garnett at gmail.com
Wed Jan 4 19:08:02 EST 2012
You will want to ask on the geoserver users list; this email list discuss at osgeo.org is for more general discussion about the Open Source Geospatial Foundation, promotion and so on.
For more information on the geoserver users list please see the website: http://geoserver.org/display/GEOS/Mailing+Lists
Jody Garnett
On Wednesday, 4 January 2012 at 10:18 PM, hosuresh wrote:
> Hi...
> I am new to geoserver...
> want to load the .ecw to the store but its displaying some error like
> 2012-01-04 17:32:53,302 INFO [org.geoserver] - Loaded workspace 'topp'
> 2012-01-04 17:32:53,307 INFO [org.geoserver] - Loaded store 'arcGridSample',
> enabled
> 2012-01-04 17:32:53,311 INFO [org.geoserver] - Loaded coverage store
> 'arcGridSample'
> 2012-01-04 17:32:53,746 WARN [referencing.factory] - Axis elements found in
> a wkt definition, the force longitude first axis order hint might not be
> respected:
> PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
> SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
> UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
> PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
> PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
> PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
> NORTH], AUTHORITY["EPSG","54004"]]
> 2012-01-04 17:32:53,828 INFO [org.geoserver] - Loaded coverage 'Arc_Sample',
> enabled
> 2012-01-04 17:32:53,842 INFO [org.geoserver] - Loaded coverage
> 'arcGridSample'
> 2012-01-04 17:32:53,875 WARN [gce.imagemosaic] - Unable to set ordering
> between tiff readers spi
> 2012-01-04 17:32:53,900 WARN [gce.imagemosaic] - Unable to set ordering
> between jp2 readers
> spi-it.geosolutions.imageio.plugins.jp2ecw.JP2GDALEcwImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderCodecLibSpi
> 2012-01-04 17:32:53,901 WARN [gce.imagemosaic] - Unable to set ordering
> between jp2 readers
> spi-it.geosolutions.imageio.plugins.jp2ecw.JP2GDALEcwImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderSpi
> 2012-01-04 17:32:53,903 WARN [gce.imagemosaic] - Unable to set ordering
> between jp2 readers
> spi-it.geosolutions.imageio.plugins.jp2mrsid.JP2GDALMrSidImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderCodecLibSpi
> between jp2 readers
> spi-it.geosolutions.imageio.plugins.jp2mrsid.JP2GDALMrSidImageReaderSpi:com.sun.media.imageioimpl.plugins.jpeg2000.J2KImageReaderSpi
> 2012-01-04 17:32:54,229 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
> 2012-01-04 17:32:54,230 INFO [org.geoserver] - Loaded store 'img_sample2',
> enabled
> 2012-01-04 17:32:54,231 INFO [org.geoserver] - Loaded coverage store
> 'img_sample2'
> 2012-01-04 17:32:54,378 INFO [org.geoserver] - Loaded coverage 'Pk50095',
> enabled
> 2012-01-04 17:32:54,379 INFO [org.geoserver] - Loaded coverage 'img_sample2'
> 2012-01-04 17:32:54,425 INFO [org.geoserver] - Loaded layer 'Pk50095'
> 2012-01-04 17:32:54,426 INFO [org.geoserver] - Loaded store 'mosaic',
> enabled
> 2012-01-04 17:32:54,426 INFO [org.geoserver] - Loaded coverage store
> 'mosaic'
> 2012-01-04 17:32:54,430 INFO [org.geoserver] - Loaded coverage 'mosaic',
> enabled
> 2012-01-04 17:32:54,431 INFO [org.geoserver] - Loaded coverage 'mosaic'
> 2012-01-04 17:32:54,511 WARN [imagemosaic.catalog] -
> BBOXFilterExtractor::extractBasicProperties(): passed typename is null,
> using: mosaic
> am not getting what mistake i am doing...
> Geoserver Version:2.1.1
> I downloaded the gdal-plugin and imageio-ext
> and installed properly even set the path correctly...
> My Raster Data Store is appearing like:
> # Raster Data Sources
> AIG - Arc/Info Binary Grid (AIG) Coverage Format
> ArcGrid - Arc Grid Coverage Format
> DTED - DTED Coverage Format
> ECW - ECW Coverage Format
> EHdr - EHdr Coverage Format
> ENVIHdr - ENVIHdr Coverage Format
> ERDASImg - Erdas Imagine Coverage Format
> GeoTIFF - Tagged Image File Format with Geographic information
> Gtopo30 - Gtopo30 Coverage Format
> ImageMosaic - Image mosaicking plugin
> JP2ECW - JP2K (ECW) Coverage Format
> JP2MrSID - JP2K (MrSID) Coverage Format
> MrSID - MrSID Coverage Format
> NITF - NITF Coverage Format
> WorldImage - A raster file accompanied by a spatial data file
> but when i select ECW and mention the .ecw file in store just the store is
> creating when i go to layers
> the store is appearing but once i select that store its not displaying
> anything...
> Pleasse help me to come out from it...
> Regards,
> SURESH HOSUR
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/problem-loading-ecw-to-store-tp7150183p7150183.html
> Sent from the OSGeo Discuss mailing list archive at Nabble.com (http://Nabble.com).
> Discuss at lists.osgeo.org (mailto:Discuss at lists.osgeo.org)
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: http://lists.osgeo.org/pipermail/discuss/attachments/20120105/f7ea5b89/attachment.html
More information about the Discuss
