[OSGeo-Discuss] Problems to install ms4w in windows7 (64bit)
Jan Tappenbeck tappenbeck at widemann.de
Wed Jan 4 02:24:29 PST 2012
  Hi !
i try to install ms4w in windows7 64bit and there are many problems....
the source is [1] rel. 3.0.3
to install the software i try to run osgeo4w.bat - but the PATH-Variable
will not add automaticlly - so i try manuell.
in the next line there sould be run some bat-files in the folder -
%OSGEO4W%\etc\ini -> the folder etc exists; but ini not - there only is
a folder setup with non-bat-files !!!!
at last i try to run setenv.bat manuell - but sorry the PATH will not
added. in my opion i am missing the drive-letter ...?
set
PATH=\ms4w\Apache\cgi-bin;\ms4w\tools\gdal-ogr;\ms4w\tools\mapserv;\ms4w\tools\shapelib;\ms4w\proj\bin;\ms4w\tools\shp2tile;\ms4w\tools\shpdiff;\ms4w\tools\avce00;\ms4w\python\gdal;%PATH%
next there will be added some other Variables like GDAL_DATA - here i am
missing drive-letters agains and then i try a test by following command:
echo %GDAL_DATA% - but no value will show.
can anyone help me ?
regards Jan :-)
[1] http://www.maptools.org/dl/ms4w/ms4w_3.0.3.zip
regards Jan :-)
More information about the Discuss mailing list
