[OSGeo-Discuss] The OSGeo response to the proposed "GeoServices REST API" document [was: Would you be concerned ...]
Cameron Shorter cameron.shorter at gmail.com
Thu May 9 16:11:22 PDT 2013
Adrian,
This is an exceptionally well written letter, which I believes captures
what many of us in the OSGeo Community would like to say.
You have provided an eloquent, unbiased, concise summary of the issues,
covering the key technical issues. If an OGC voter only had time to read
one thing before voting, I would recommend they read this email of yours.
As such, I'd like to work with you to see what the best way would be to
incorporate your text into our open letter at:
http://wiki.osgeo.org/wiki/Geoservices_REST_API (assuming that would be
ok with you).
I'd like your text in this open letter, as I'm expecting it to have lots
of OGC Voters reading it.
I note that we already have a number of people have collated reasons
for not voting for this standard. I suggest that we invite these authors
to check if their concerns have been covered by your summary, and if so,
remove their duplicate concerns.
Anything left can either be added by Adrian Custer into his summary, or
collected in a "Further Comments" section at the end.
Adrian,
What are your thoughts?
On 10/05/2013 2:20 AM, Adrian Custer wrote:
> Hey Cameron, all,
> Cameron, you recently asked me to join your letter from the OSGeo to
> the OGC Members regarding the adoption of the proposed "ESRI
> GeoServices REST API" as an OGC standard.
> http://wiki.osgeo.org/wiki/Geoservices_REST_API#Open_Letter_to_OGC_and_voting_members
> Thanks. Your request has forced me to define my position, which has
> been a huge waste of my time, but was probably worth doing.
> My response has two sides, my position on the debate and my decision
> to participate in the letter.
> The first is my position on the actual proposed standard.
> The pros:
>   * The OGC should be in the business of developing good standards,
>     not of choosing which standards should be implemented.
>   * The proposers of the document want to make a standard and have
>     followed all the rules of the consortium. The work of any such
>     group of members deserves serious, good faith consideration.
>   * The need for an integrated suite of services using simple data,
>     which is addressed (partially) by the document, is real. The
>     proposed document is pushing the OGC on this issue.
>   * The proposed document could be useful to a number of people.
>   * The proposed document is not significantly more broken than the
>     existing standards of the OGC. As an author of standards at the
>     OGC, I know how totally impossible it is to write a good standard,
>     so the weaknesses in the existing document seem more acceptable.
> The cons:
>   * The OGC is, de-facto, in the position of recommending the
>     interoperable standards for geospatial services. The proposed
>     document is not good enough, not widely enough implemented, and
>     not publicly supported enough, to be considered at the same level
>     as existing standards.
>   * Adopting a standard implies a desire to maintain the standard
>     but the desire to support this approach by the OGC membership is
>     limited. The lack of collaboration on this version bodes ill for
>     the future.
>   * The overlap in functionality between the proposed services and the
>     existing services, notably with the ongoing work to modularize the
>     existing services, is almost 100 percent. However, compatibility is
>     low.
>   * There is already a published document:
> http://www.esri.com/library/whitepapers/pdfs/geoservices-rest-spec.pdf
>     so there is no need for the document to be adopted as an
>     OGC Standard merely for interoperability with the ESRI
>     implemetation.
>   * The document, as a new, separate effort, repeats mistakes which were
>     made and since solved by the other services.
>   * The document focuses on the past (notably with backwards
>     compatibility and use of only GET/POST) not on the future.
>   * The document needs a comprehensive editorial rewrite. (see at end)
> The problem for me, is that both simple answers are bad.
> A simple acceptance of the standard would introduce a new set of 'OGC
> approved' open services. The OGC approval might enable governments to
> buy a XXXX-new-name-here-XXXX solution instead of a W*S or a S*S
> solution. (On that, I am inclined to let them make their own
> mistakes.) The path forwards towards harmonizing the services is
> unclear. There is little good will towards the standard on behalf of
> the membership. Fixing this document in addition to fixing the W*S
> services will be a pain.
> Simply rejecting the solution would be bad for the OGC. It would place
> the OGC in the position of picking winners and losers in the standards
> business. It would mean that the OGC is stuck on the project of fixing
> the W*S standards to meet some nebulous future functionality without
> having any path to get there. It would discourage innovation and
> progress.
> Is there a third way?
> Well, actually, there is. The natural consequence of either decision
> is a renewed commitment towards trying to build this thing that we
> want, an integrated suite of simple services built using simple, well
> defined resources, accessible and usable using the core HTTP verbs,
> and discoverable through link following. That's the way forwards and
> why I have wasted a chunk of my life on WMS-Next.
> My personal conclusion, then, is that the vote does not concern me.
> I suspect the vote is mostly of interest to the commercial entities,
> groups whose self-interest is so destructive everywhere because it
> does not place user freedom and action first and foremost. Acceptance
> will have several net negative impacts on me but that's life, eh?
> For me, the path forwards is clear: make WMS-Next kick ass. The vote
> is merely a waste of my time.
> The second side to my response regards the actual letter.
> The pros:
>   * The letter comes from the Free Software community which I think
>     could have a voice on the matter.
>   * The letter was started by someone who has my respect.
>   * The letter re-enforces the link between OSGeo and the OGC.
>   * The letter expresses many concerns which I share.
> The cons:
>   * The letter comes from OSGeo, a group with which I have an
>     ambivalent relationship from being a second class citizen and
>     from its focus on 'open source' rather than on freedom.
>   * As a member of the OGC, I have a direct voice there (albeit again
>     as a second class member without a vote) so it makes more sense
>     for me to act directly at the OGC than indirectly through OSGeo.
>   * The letter is only rejection of the proposal without offering an
>     alternative way forwards.
>   * The critique of the letter is not yet fully formulated making it
>     hard to decide if I actually agree with it.
>   * The critiques do not inspire me. I suspect none of you has actually
>     read the proposed document, nor have any real analysis to offer of
>     it. (EDIT: actually, a new wave of criticisms focused on 'imagery'
>     seem to come from folk who actually have read the document. Cool!)
>   * Some the concerns are wrong. (It seems, this is simply due to lack
>     of knowledge of the details, a minor issue ultimately).
> My personal conclusion then is that I should not be trying to express
> myself on the matter through an incompletely formed statement of the
> OSGeo community.
> Therefore, I will not add myself to your letter.
> Nonetheless, thanks for your effort, thanks for asking, and thanks for
> prodding me to sit down and write this; given the time I have taken,
> it is clear that I wanted to make myself do it.
> cheers,
>   ~adrian
>     A Quick Critique of the proposed standard document.
> 1. The name.
> The document currently uses a name that is confusing in all
> discussions on the matter, both internally at the OGC and externally.
> (Yesterday, the Standards Working Group proposing the document agreed
> to accept proposals for new names; if they can find a good
> alternative, they may adopt it.)
> 2. The design.
> The document does not show an overall, coherent design to the service
> suite. This is mostly because the design reflects a suite that evolved
> piecemeal at ESRI rather than one designed from the start to meet the
> needs of a broad swath of users. This is also due because the experts
> at the OGC did not contribute to an improved design for a multitude of
> reasons.
> The design of the service which does exist is focused on yesteryear.
> As an apology for the existing design, section~6.2.2 of part 1, Core
> says that the only HTTP verbs used are GET and PUT because "the API
> was originally developed several years ago" but that's okay because it
> enables support for "Microsoft Silverlight" and "Adobe Flex" two
> standards which are dying rapidly. In 2013, a new standard ought to be
> focused on the next 10 years not the past ten.
> 3. The writing.
> The document is poorly written.
> 3.1 The document is poorly introduced.
> The document should start with a discussion of the overall design of
> the suite of services and what each individual service provides within
> that suite. This would make it easy for a user to understand the focus
> of the suite. (The note between requirements~3 and requirement~4,
> stating that the spec makes no requirements on clients, is really part
> of the scope of the document and should be front and center.)
> The document instead starts with a whole section on REST.
>     1. Scope
>     The GeoServices REST API provides a standard way for web clients to
>     communicate with geographic information system (GIS) servers based
>     on Representational State Transfer (REST) principles.
> The scope claims that the document identifies resources and a way to
> use "structured URLs" to exchange those resources between clients and
> services. If that were true, I would expect
>     (1) a list of resources at least as an example, and
>     (2) an example of the structure and structuring principles of
>         the URLs.
> Section~6 stats this process. Section~6.1 introduces the concept of a
> root URL for each service and mixes in that that root URL is also a
> catalog and that the hierarchy offers resources. This all happens in a
> single, overly compact paragraph. This section needs an editorial
> rewrite for clarity separating
>     (1) the end point,
>     (2) the catalog,
>     (3) the URL hierarchy,
>     (3) the resources, and
>     (4) interaction of clients with the URLs through the exchange
>         (get/post) of the resources to the different URLs.
> Unfortunately, section~6 then decays into a meandering discussion of
> REST which mentions the buzzword a lot but does not discuss the
> aspects of REST design that have been met by the suite and those that
> have not. If REST is a form of design which offers certain benefits,
> OGC standards should be discussing the benefits achieved not the buzz
> word. To what extent are the resources cachable and how do clients and
> servers agree on that? To what extent are the endpoints and actions on
> those endpoints discoverable, and how? Those are the issues of RESTful
> design.
> Section~6.3 discusses Resources but immediately then states:
>     Each resource has a unique URL. Resources MAY support parameters.
> which is a discussion of the URL hierarchy. (And 'Resources' do not
> 'support parameters'! Services may 'handle requests containing
> parameters' if that is what is meant.) Then the standard introduces a
> new idea 'Controller Resources' which are able to 'edit' and 'query'!?
> A web search does not reveal any formal discussion of 'Controller
> Resource' so this new type of resource probably deserves some kind of
> formal introduction.
> Section~6.3.3 is not really about resources but the fact that the URL
> hierarchy is not discoverable from the Resources themselves.
> Section~6.3.4 does give a list of resources, but since 'image' is not
> part of it but will be used by the Service for Map Images, I surmise
> that the list is of the things 'we have designed a JSON representation
> for' rather than a list of 'the resources identified and exchanged in
> the service suite' which is what I expect in an introductory design.
> This introduction therefore needs a substantial editorial rewrite to
> be effective in its goal of explaining what the suite of standards
> actually does.
> This criticism is not limited to the core document.
> The Service for Maps document also starts without setting out the five
> core elements (end pt, catalog?, URL hierarchy, resources, and
> interactions).
> Section~6 of the Service for Maps part, in the middle of the second
> paragraph, introduces a new concept, with capitalized letters:
>     The Map Service Root resource includes a tables property ...
> without giving us any clue what this is. It "provides basic
> information" (perhaps it is a data structure?) but it also "supports
> several operations" (maybe it's a magical 'Controller Resource'). To
> me, this just reads as 'the authors of the spec are confused and
> imprecise in their written language'.
> Then, in the figure of 'Resources,' there is actually a resource
> called 'All layers and tables'. Sorry, but this reader needs some real
> help to understand what that resource might be.
> 3.2 The document requirements are poor.
> The very first requirement, Requirement~1 of the Core document, states:
>     Req 1 If a request uses the HTTP GET method, the processing of the
>     request by the service SHALL be safe and idempotent as specified
>     by RFC 2616, 9.1.
> This is a *ridiculous* requirement, completely untestable, and
> explicitly what the Mod Spec should be preventing with its attempt to
> require all injunctive language to be accompanied by formal tests. The
> formal test indeed shows that the requirement is untestable.
>     Inspect the documentation of the implementation to identify, if
>     requests specified in the GeoServices REST API standard that
>     support the HTTP GET method, are all safe and idempotent, i.e.
>     free of side- effects, as specified in HTTP (RFC 2616, section
>     9.1). Alternatively, ask the developer of the the service.
>     Note that it is not possible to run automated tests against a
>     service to verify conformance with the requirement (and IETF
>     provides no test for conformance with HTTP either). In the absence
>     of such tests, a statement of the developers of the service is
>     sufficient indication that the requirement was addressed.
> So essentially this requirement is met if the developers say 'yeah, we
> thought about it.' In other words, requirement 1 of the whole shebang
> is a recommendation. Contrast this with requirement 2 which has a nice
> test defined for it and is a good, solid requirement.
> Again, broadening the critique to the Services for Maps, its first
> requirement states:
>     Req 1 The Map Service Root resource SHALL accept requests that
>     conform to the URI template in Table and use any HTTP method
>     identified in the same table.
> but the test is then completely irrelevant. At the protocol level, all
> web services 'shall accept' request messages, so we are not discussing
> that. A functional test for this 'shall accept' is to construct all
> valid requests and see that the service never returns an exception to
> those requests. Even worse, the first test is a catch all 'please test
> the service here' test. This is *not* a well written specification of
> the tests for the injunctions of the Service for Maps.
> The requirements need a complete, systematic review to see that they
> work, they are testable, and have good tests.
> 4. The document has numerous other issues which need resolution
> * There is no discussion of the overlap of the f= parameter and of the
> HTTP format header. What happens if they conflict?
> * The lack of full integration of the four core HTTP verbs, notably
> DELETE and PUT, exists merely for backwards compatibility not for
> forwards progress.
> * Requirement~3 blocks forwards progress and experimentation with no
> explanation as to its importance.
> ~~~~This goes on and on. This is the work for an EDITOR.
>     I am not interested in doing that work.
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Discuss mailing list
