[OSGeo-Discuss] Maven repository is down
Andrea Aime
andrea.aime at geo-solutions.it
Mon Aug 17 11:20:23 PDT 2015
On Mon, Aug 17, 2015 at 5:28 PM, Petar Tahchiev <paranoiabla at gmail.com>
wrote:
> Hello,
> you maven repository is down :(
> http://download.osgeo.org/webdav/geotools/
> I wonder why are all the artifacts not synced with the maven central -
> it's uptime is really good, and I don't have to specify extra repositories
> in my build.
Getting them there is sometimes time consuming (we don't have the people
time to do it) and for some it's just impossible (e.g., JAI).
We also issue several MB worth of releases once a month, not sure if
central has policy against large and frequent releases,
and we would need to find a mechanism that avoids making releases more time
consuming.
If you want to help synching what's possible to maven central, you're more
than welcomed to so, many would appreciate
that work :-)
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20150817/2cf311c0/attachment.html>
More information about the Discuss
