[OSGeo-Discuss] OSGeo guidelines for code hosting ?
Andreas Hocevar andreas.hocevar at gmail.com
Sun Oct 18 00:07:52 PDT 2015
Very well said Andrea, and I can back this up with very similar experiences from when the OpenLayers project moved to Github.
That said, if OSGeo considers setting up a Git infrastructure, please keep an alternative in mind: pay for an OSGeo Github account for projects that want to use Git. Will burn some money, but won't burn out volunteers who have to keep OSGeo's own infrastructure up and running. See https://github.com/locationtech as an example.
Andreas.
> On 18 Oct 2015, at 08:41, Andrea Aime <andrea.aime at geo-solutions.it> wrote:
> Hi,
> just wanted to chime in saying that if OSGeo starts setting said guidelines,
> it should also have some benefits comparison so that projects can
> see what they might not get by avoiding Github.
> In particular, looking at GeoServer experience from the switch, it's rather
> evident we got more people contributing right the moment we did the
> switch, here is the contributors per month diagram, the red line
> is the date we switched from svn to GitHub:
> <Selezione_095.png>
> Most of this is due to two factors:
> - availability of pull requests (which I believe you can get with other tools too)
> - critical mass on the platform (which arguably you will not get an a OsGeo hosting)
> There is however a downside of that, most of these contributions are "one time gigs",
> people help addressing the particular pitfall concerning them and then they move on:
> github did not change the number of core developers, it just increased a lot the
> number of other contributors.
> There is another benefit of moving to Github, which is build checks on pull requests,
> we now have Travis (Linux, OSX) building all pull requests and running the test suite against
> them, so we instantly know if the change breaks tests or not, and we planning on adding
> test coverage checks (Coveralls, already used by OpenLayers for example) and Windows builds
> (already used by MapServer for example).
> This kind of automation is also rather beneficial to filter our bad contributions... which is
> the dark side of lower contribution barrier, core devs have to spend quite some time evaluating
> pull requests... but ending up with a long queue of them gives a bad impression about the project
> openness. So yeah, another bit to consider I guess, is the project ready to take on them?
> So.... I'm not saying "everybody move to github" but I believe the above should be
> part of the many considerations made when evaluating a move to a different version control.
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V <http://goo.gl/it488V> for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313 <tel:%2B39%200584%20962313>
> fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
> mob: +39  339 8844549 <tel:%2B39%20%C2%A0339%208844549>
> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20151018/fbe027c4/attachment-0002.html>
More information about the Discuss mailing list
