[OSGeo-Discuss] Shapefile to GPX conversion
Andrea Giacomelli pibinko at gmail.com
Thu Sep 7 01:09:38 PDT 2017
Hi - I initially posted this to qgis-user, but in fact there will be a
broader solution so I am relaying this here.
I need to provide GPX data, derived from some shapefiles, to be used and
edited in the Garmin Basecamp package.
I have tried with the basic export option via "Save as GPX" from QGIS
(2.16)..
the resulting GPX is uploaded, but each feature of my initial layer in
interpreted as a separate track, which makes usability on the base camp
side difficult.
I would like to ask if you have encountered the same issue (with that
package or other GPX viewers) and if you have identified a solution, either
with specific flags via the QGIS Save as GPX option, or with a different
workflow.
TIA for any feedback, and best regards
Andrea Giacomelli
http://www.pibinko.org
info at pibinko.org
+39 331 7539228
P. IVA: 01582480537
URL: <http://lists.osgeo.org/pipermail/discuss/attachments/20170907/9c864cd6/attachment.html>
More information about the Discuss mailing list
