[OSGeo-Edu] Edu committee calendar
Markus Neteler neteler.osgeo at gmail.com
Tue May 2 17:34:45 EDT 2006
On 5/2/06, P Kishor <punkish at eidesis.org> wrote:
> >> It asks me the SVN password which means that
> >> I need to request a role at
> >>  https://edu.osgeo.org/servlets/ProjectMembershipRequest
> >> Question is, which one is able to write to SVN?
> >> - Observer: Read-only access to project code; can also submit issues;
> >> 'observer' of project
> >> - Project Contributor: Developer/User that contributes code via
> >> Project Tracker
> >> - User: User or application developer that makes use of the software
> >> in the project
> >> I have requested 'Project Contributor' - we'll see if that's sufficient.
> > OK, thanks for grating the role.
> > BUT: It continues to ask me the password. Apparently I am not able
> > as 'Project Contributor' to modify the SVN alias ical file therein.
> I have made you a "Project co-owner/contributor." Try now and let me
> know.
Works!
Please reload your calendar now :-)
I have modified the title to "EduCom meeting" and added
an pop-up alarm one hour before (hope that's ok).
So, only "Project co-owner/contributor" level works for modifying
the calendar since it is stored in SVN.
Thanks again,
 Markus
> If this doesn't work then we will revert to my more sub-optimal
> approach... I will maintain the calendar, and everyone can send me the
> events and I will enter them. Not satisfying, but at least everyone
> will know what everyone else in the edu.osgeo world is up to. If
> someone else has any other bright ideas, let me know (cc-ing to the
> entire list)
> Many thanks,
> Puneet Kishor
Open Source Geospatial Foundation
http://www.osgeo.org/
More information about the Edu_discuss mailing list
