[OSGeo-Edu] Comments and Questions on Docbook
Landon Blake lblake at ksninc.com
Tue Jan 22 14:09:35 EST 2008
I took some time to look over Docbook last night. This included skimming
a Docbook crash course and messing around with XMLMind.
XMLMind definitely seems to be the most fully featured Docbook editor,
and would be a good choice for authors not familiar with XML.
I personally found it a bit awkward, and figured I would be more
comfortable working in a text editor. I'd probably still write the
content in OpenOffice and would then cut and paste to a XML template
file. My comfort with the raw text editor may be a result of my
programming background.
I think Docbook would be a workable solution, but I think some templates
would be key. (For example, we could set up a template for Free GIS Book
chapters or for OSGeo Journal Articles.)
I'd like to check out the PDF format generated from Docbook. Can anyone
get me started with that conversion as quickly as possible? What
conversion tool would you recommend?
Landon
Warning:
Information provided via electronic media is not guaranteed against defects including translation and transmission errors. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this information in error, please notify the sender immediately.
URL: http://lists.osgeo.org/pipermail/edu_discuss/attachments/20080122/8d237420/attachment.html
More information about the Edu_discuss mailing list
