[OSGeo-Edu] Update on the Metadata Chapter of the Free GIS Book
Tyler Mitchell (OSGeo) tmitchell at osgeo.org
Wed Jan 23 14:33:25 EST 2008
I've recently started wondering about metadata standards for tracking
more technical dataset attributes.  It seems that some pretty
informative information doesn't make it into specifications for some
reason.
I've been modifying some scripts that Matt Perry and I wrote a while
ago that collects basic dataset/layer information.  The script
recursively walks through a set of directories/files and reports on
which ones GDAL/OGR can open.  I updated it to output the analysis in
a form of XML (instead of the delimited text I used to use) - so when
I had to start thinking about a schema I went searching for
standards.  Not finding any, I started to make my own.
If you are interested, have a look at the example below for the kinds
of elements I'm tracking.  Could these lower-level items make it into
a discussion on metadata at some point?  I find that these attributes
are ones that can really help automation of processes but are the
very ones usually ignored by standards.
Tyler
<?xml version="1.0" encoding="utf-8"?>
<DataCatalogue>
     <CatalogueProcess>
         <SearchPath>../</SearchPath>
         <LaunchPath>/Users/tyler/code/nme/cat</LaunchPath>
         <UserHome>/Users/tyler</UserHome>
         <IgnoredStrings>['.svn', '.shx', '.dbf']</IgnoredStrings>
         <DirCount>44</DirCount>
         <FileCount>119</FileCount>
         <Timestamp>Wed Jan 23 11:29:58 2008</Timestamp>
     </CatalogueProcess>
     <VectorData>
         <datasourceId>1</datasourceId>
         <name>../data_example/shp</name>
         <layercount>5</layercount>
         <format>ESRI Shapefile</format>
         <VectorLayer>
             <featurecount>1</featurecount>
             <name>buf_hull</name>
             <extent>(-5.2264717603724069, 143.19359180565968,
42.418215273515429, 287.96378357150178)</extent>
             <layerId>1</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>linebuf</name>
             <layerId>3</layerId>
         </VectorLayer>
         <VectorLayer>
             <featurecount>8</featurecount>
             <name>line</name>
             <extent>(-3.924027383409785, 141.77937824328657,
43.417968752500002, 286.96378357150178)</extent>
             <layerId>2</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>vanisland</name>
             <extent>(-128.31944636678202, -123.44387543252594,
48.161439446366785, 50.973176470588243)</extent>
             <layerId>5</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>vanisl_proj</name>
             <extent>(-127.48989349743159, -127.48984981726348,
0.00043438545857253316, 0.00045974550950280422)</extent>
             <layerId>4</layerId>
         </VectorLayer>
     </VectorData>
     <RasterData>
         <name>../data_example/img/bg.jpg</name>
         <RasterBand>
             <bandId>1</bandId>
             <max>255.0</max>
             <overviews>0</overviews>
             <min>88.0</min>
         </RasterBand>
         <RasterBand>
             <bandId>3</bandId>
             <max>255.0</max>
             <min>99.0</min>
         </RasterBand>
         <RasterBand>
             <bandId>2</bandId>
             <max>255.0</max>
             <min>99.0</min>
         </RasterBand>
         <rasterX>1280</rasterX>
         <rasterY>10</rasterY>
         <driver>JPEG JFIF</driver>
         <project></project>
         <boundcount>3</boundcount>
         <rasterId>1</rasterId>
         <geotrans>(0.0, 1.0, 0.0, 0.0, 0.0, 1.0)</geotrans>
     </RasterData>
  snip....
More information about the Edu_discuss mailing list
