[OSGeo-Edu] Update on the Metadata Chapter of the Free GIS Book
Landon Blake lblake at ksninc.com
Wed Jan 23 14:33:55 EST 2008
Tyler,
This is excellent! I was looking for a simple example to include in the
chapter. I didn't want to use something as complicated as the FGDC
metadata, and I was going to write some simple metadata for a DXF file.
I'll use this instead!
Thank you for contributing.
Landon
P.S. - I was worried the updates on the chapter would be an annoyance. I
can see now that they have some benefit by keeping others involved. If
there are no strong objections I will continue to send brief updates as
chunks of the chapter are completed.
-----Original Message-----
From: Tyler Mitchell [mailto:tmitchell.osgeo at gmail.com] On Behalf Of
Tyler Mitchell (OSGeo)
Sent: Wednesday, January 23, 2008 11:33 AM
To: Landon Blake
Cc: OSGeo-edu
Subject: Re: [OSGeo-Edu] Update on the Metadata Chapter of the Free GIS
Book
I've recently started wondering about metadata standards for tracking
more technical dataset attributes.  It seems that some pretty
informative information doesn't make it into specifications for some
reason.
I've been modifying some scripts that Matt Perry and I wrote a while
ago that collects basic dataset/layer information.  The script
recursively walks through a set of directories/files and reports on
which ones GDAL/OGR can open.  I updated it to output the analysis in
a form of XML (instead of the delimited text I used to use) - so when
I had to start thinking about a schema I went searching for
standards.  Not finding any, I started to make my own.
If you are interested, have a look at the example below for the kinds
of elements I'm tracking.  Could these lower-level items make it into
a discussion on metadata at some point?  I find that these attributes
are ones that can really help automation of processes but are the
very ones usually ignored by standards.
Tyler
<?xml version="1.0" encoding="utf-8"?>
<DataCatalogue>
     <CatalogueProcess>
         <SearchPath>../</SearchPath>
         <LaunchPath>/Users/tyler/code/nme/cat</LaunchPath>
         <UserHome>/Users/tyler</UserHome>
         <IgnoredStrings>['.svn', '.shx', '.dbf']</IgnoredStrings>
         <DirCount>44</DirCount>
         <FileCount>119</FileCount>
         <Timestamp>Wed Jan 23 11:29:58 2008</Timestamp>
     </CatalogueProcess>
     <VectorData>
         <datasourceId>1</datasourceId>
         <name>../data_example/shp</name>
         <layercount>5</layercount>
         <format>ESRI Shapefile</format>
         <VectorLayer>
             <featurecount>1</featurecount>
             <name>buf_hull</name>
             <extent>(-5.2264717603724069, 143.19359180565968,
42.418215273515429, 287.96378357150178)</extent>
             <layerId>1</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>linebuf</name>
             <layerId>3</layerId>
         </VectorLayer>
         <VectorLayer>
             <featurecount>8</featurecount>
             <name>line</name>
             <extent>(-3.924027383409785, 141.77937824328657,
43.417968752500002, 286.96378357150178)</extent>
             <layerId>2</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>vanisland</name>
             <extent>(-128.31944636678202, -123.44387543252594,
48.161439446366785, 50.973176470588243)</extent>
             <layerId>5</layerId>
         </VectorLayer>
         <VectorLayer>
             <name>vanisl_proj</name>
             <extent>(-127.48989349743159, -127.48984981726348,
0.00043438545857253316, 0.00045974550950280422)</extent>
             <layerId>4</layerId>
         </VectorLayer>
     </VectorData>
     <RasterData>
         <name>../data_example/img/bg.jpg</name>
         <RasterBand>
             <bandId>1</bandId>
             <max>255.0</max>
             <overviews>0</overviews>
             <min>88.0</min>
         </RasterBand>
         <RasterBand>
             <bandId>3</bandId>
             <max>255.0</max>
             <min>99.0</min>
         </RasterBand>
         <RasterBand>
             <bandId>2</bandId>
             <max>255.0</max>
             <min>99.0</min>
         </RasterBand>
         <rasterX>1280</rasterX>
         <rasterY>10</rasterY>
         <driver>JPEG JFIF</driver>
         <project></project>
         <boundcount>3</boundcount>
         <rasterId>1</rasterId>
         <geotrans>(0.0, 1.0, 0.0, 0.0, 0.0, 1.0)</geotrans>
     </RasterData>
  snip....
Warning:
Information provided via electronic media is not guaranteed against defects including translation and transmission errors. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this information in error, please notify the sender immediately.
More information about the Edu_discuss mailing list
