svn commit: r3 - trunk/www: . docs
robertbray at osgeo.org robertbray at osgeo.org
Mon Mar 6 16:24:01 EST 2006
Author: robertbray
Date: 2006-03-06 21:24:01+0000
New Revision: 3
Added:
   trunk/www/docs/
   trunk/www/docs/FDG_FDODevGuide.pdf   (contents, props changed)
   trunk/www/docs/FET_TheEssentialFDO.pdf   (contents, props changed)
   trunk/www/documentation.html
   trunk/www/downloads.html
   trunk/www/index.html
Content updates.
Added: trunk/www/docs/FDG_FDODevGuide.pdf
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/FDG_FDODevGuide.pdf?view=auto&rev=3
Binary file. No diff available.
Added: trunk/www/docs/FET_TheEssentialFDO.pdf
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/FET_TheEssentialFDO.pdf?view=auto&rev=3
Added: trunk/www/documentation.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/documentation.html?view=auto&rev=3
--- (empty file)
+++ trunk/www/documentation.html	2006-03-06 21:24:01+0000
@@ -0,0 +1,19 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
+<title>Feature Data Objects - Documentation</title>
+</head>
+<body>
+<h1>Feature Data Objects  - Documentation</h1>
+<div class="h2">
+<h2>Getting Started </h2>
+<p><a href="docs/FET_TheEssentialFDO.pdf" target="_blank">The Essential FDO</a>&nbsp;[PDF]</p>
+</div>
+<div class="h2">
+<h2>Developer Reference</h2>
+<p><a href="docs/FDG_FDODevGuide.pdf" target="_blank">FDO Developers Guide</a>&nbsp;[PDF]</p>
+<p><a href="nonav/docs/webapi/index.html" target="_blank">MapGuide Web API Reference</a>&nbsp;[HTML]</p>
+</div>
+</body>
+</html>
Added: trunk/www/downloads.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/downloads.html?view=auto&rev=3
--- (empty file)
+++ trunk/www/downloads.html	2006-03-06 21:24:01+0000
@@ -0,0 +1,25 @@
+<head>
+<title>Feature Data Objects - Downloads</title>
+</head>
+<body>
+<h1>Feature Data Objects  - Downloads</h1>
+<div class="h2">
+<h2>Feature Data Objects 3.0.0 G001 - Preview </h2>
+      <h3>Source Code</h3>
+      Use these links to configure, make, and install FDO on Linux or to build FDO on Windows.
+	  <ul type="square">
+	    <li><a href="https://fdo.osgeo.org/files/documents/13/23/fdo-3.0.0_G001.tar.gz">fdo-3.0.0_G001.tar.gz</a>&nbsp;[8,591 kb]<br />
+	    md5: C80F69A6920E65FE48E2399F6767F0AA<br />
+		Compressed tar file that contains source code for FDO, the ESRI SHP provider, and the SDF provider with configure / make / make install scripts.</li>
+      </ul>
+	    <li><a href="https://fdo.osgeo.org/files/documents/13/24/fdo-3.0.0_data_G001.tar.gz">fdo-3.0.0_data_G001.tar.gz</a>&nbsp;[32,729 kb]<br />
+	    md5: A908467A77B06985CC34B9FECDC9D01E<br />
+		Compressed tar file that contains data files required to run the FDO unit tests.</li>
+  </ul>
+</div>
+</body>
+</html>
Modified: trunk/www/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/index.html?view=diff&rev=3&p1=trunk/www/index.html&p2=trunk/www/index.html&r1=2&r2=3
--- trunk/www/index.html	(original)
+++ trunk/www/index.html	2006-03-06 21:24:01+0000
@@ -32,7 +32,7 @@
   <h1>Feature Data Objects - Project Home</h1>
   Welcome to the home of Feature Data Objects.
   <div class="h2"><h2>Description</h2>
-  <p>Feature Data Objects (FDO) is an API for manipulating, defining, and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically provides support for a particular data format or data store.</p>
+  <p>Feature Data Objects (FDO) is an API for manipulating, defining, and analyzing geospatial information regardless of where it is stored. FDO uses a provider-based model for supporting a variety of geospatial data sources, where each provider typically supports a particular data format or data store.</p>
   <p>At this point Feature Data Objects is being offered as a preview for use with MapGuide Open Source. The links below  allow you to download a full copy of the source code with FDO providers for ESRI SHP and a new format created for MapGuide called the Spatial Database Format (SDF). FDO will become a full open-source project in the coming months, so stay tuned to this page for more information, additional providers, and the launch of FDO as an active open source project. </p>
   <p>Feature Data Objects is free, open source software licensed under the <a href="lgpl.html">LGPL</a>.</p>
   </div>
More information about the Fdo-commits mailing list
