svn commit: r66 - trunk/www
gregboone at osgeo.org gregboone at osgeo.org
Thu Oct 19 18:05:24 EDT 2006
Author: gregboone
Date: 2006-10-19 22:05:24+0000
New Revision: 66
Added:
   trunk/www/fdo32.html   (contents, props changed)
   trunk/www/index.html
FDO111: Update FDO documentation
Added: trunk/www/fdo32.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/fdo32.html?view=auto&rev=66
--- (empty file)
+++ trunk/www/fdo32.html	2006-10-19 22:05:24+0000
@@ -0,0 +1,3101 @@
+<html xmlns:o="urn:schemas-microsoft-com:office:office"
+xmlns:w="urn:schemas-microsoft-com:office:word"
+xmlns="http://www.w3.org/TR/REC-html40">
+<head>
+<meta http-equiv=Content-Type content="text/html; charset=us-ascii">
+<meta name=ProgId content=Word.Document>
+<meta name=Generator content="Microsoft Word 11">
+<meta name=Originator content="Microsoft Word 11">
+<link rel=File-List href="7EFFBFBD_files/filelist.xml">
+<link rel=Edit-Time-Data href="7EFFBFBD_files/editdata.mso">
+<!--[if gte mso 9]><xml>
+ <o:DocumentProperties>
+  <o:Author>GB</o:Author>
+  <o:Revision>1</o:Revision>
+  <o:TotalTime>0</o:TotalTime>
+  <o:Created>2006-10-19T21:58:00Z</o:Created>
+  <o:Pages>1</o:Pages>
+  <o:Words>2011</o:Words>
+  <o:Characters>11465</o:Characters>
+  <o:Company>Autodesk, Inc.</o:Company>
+  <o:Lines>95</o:Lines>
+  <o:Paragraphs>26</o:Paragraphs>
+  <o:CharactersWithSpaces>13450</o:CharactersWithSpaces>
+  <o:Version>11.6408</o:Version>
+ </o:DocumentProperties>
+</xml><![endif]--><!--[if gte mso 9]><xml>
+ <w:WordDocument>
+  <w:View>Normal</w:View>
+  <w:Zoom>0</w:Zoom>
+  <w:SpellingState>Clean</w:SpellingState>
+  <w:GrammarState>Clean</w:GrammarState>
+  <w:DocumentKind>DocumentEmail</w:DocumentKind>
+  <w:EnvelopeVis/>
+  <w:PunctuationKerning/>
+  <w:ValidateAgainstSchemas/>
+  <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
+  <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
+  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
+  <w:Compatibility>
+   <w:BreakWrappedTables/>
+   <w:SnapToGridInCell/>
+   <w:WrapTextWithPunct/>
+   <w:UseAsianBreakRules/>
+   <w:DontGrowAutofit/>
+   <w:UseFELayout/>
+  </w:Compatibility>
+  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
+ </w:WordDocument>
+ <w:LatentStyles DefLockedState="false" LatentStyleCount="156">
+ </w:LatentStyles>
+</xml><![endif]-->
+<style>
+ /* Font Definitions */
+ @font-face
+	{font-family:"MS Mincho";
+	panose-1:2 2 6 9 4 2 5 8 3 4;
+	mso-font-alt:"\FF2D\FF33 \660E\671D";
+	mso-font-charset:128;
+	mso-generic-font-family:modern;
+	mso-font-pitch:fixed;
+	mso-font-signature:-1610612033 1757936891 16 0 131231 0;}
+ at font-face
+	{font-family:"\@MS Mincho";
+ /* Style Definitions */
+ p.MsoNormal, li.MsoNormal, div.MsoNormal
+	{mso-style-parent:"";
+	margin:0in;
+	margin-bottom:.0001pt;
+	mso-pagination:widow-orphan;
+	font-size:12.0pt;
+	font-family:"Times New Roman";
+	mso-fareast-font-family:"MS Mincho";}
+h1
+	{margin-top:12.0pt;
+	margin-right:0in;
+	margin-bottom:3.0pt;
+	margin-left:0in;
+	page-break-after:avoid;
+	mso-outline-level:1;
+	font-size:16.0pt;
+	font-family:Arial;}
+h2
+	margin-right:0in;
+	margin-left:0in;
+	mso-outline-level:2;
+	font-size:14.0pt;
+h3
+	margin-right:0in;
+	margin-left:0in;
+	mso-outline-level:3;
+	font-size:12.0pt;
+a:link, span.MsoHyperlink
+	{color:blue;
+	text-decoration:underline;
+	text-underline:single;}
+a:visited, span.MsoHyperlinkFollowed
+	{color:purple;
+span.EmailStyle17
+	{mso-style-type:personal-compose;
+	mso-style-noshow:yes;
+	mso-ansi-font-size:10.0pt;
+	mso-bidi-font-size:10.0pt;
+	mso-ascii-font-family:Arial;
+	mso-hansi-font-family:Arial;
+	mso-bidi-font-family:Arial;
+	color:windowtext;}
+span.SpellE
+	{mso-style-name:"";
+	mso-spl-e:yes;}
+span.GramE
+	mso-gram-e:yes;}
+ at page Section1
+	{size:8.5in 11.0in;
+	margin:1.0in 1.25in 1.0in 1.25in;
+	mso-header-margin:.5in;
+	mso-footer-margin:.5in;
+	mso-paper-source:0;}
+div.Section1
+	{page:Section1;}
+ /* List Definitions */
+ @list l0
+	{mso-list-id:1903252227;
+	mso-list-type:hybrid;
+	mso-list-template-ids:-699084292 67698689 67698691 67698693 67698689 67698691 67698693 67698689 67698691 67698693;}
+ at list l0:level1
+	{mso-level-number-format:bullet;
+	mso-level-text:\F0B7;
+	mso-level-tab-stop:.25in;
+	mso-level-number-position:left;
+	margin-left:.25in;
+	text-indent:-.25in;
+	font-family:Symbol;}
+ at list l0:level2
+	{mso-level-tab-stop:1.0in;
+	text-indent:-.25in;}
+ at list l0:level3
+	{mso-level-tab-stop:1.5in;
+ at list l0:level4
+	{mso-level-tab-stop:2.0in;
+ at list l0:level5
+	{mso-level-tab-stop:2.5in;
+ at list l0:level6
+	{mso-level-tab-stop:3.0in;
+ at list l0:level7
+	{mso-level-tab-stop:3.5in;
+ at list l0:level8
+	{mso-level-tab-stop:4.0in;
+ at list l0:level9
+	{mso-level-tab-stop:4.5in;
+ol
+	{margin-bottom:0in;}
+ul
+</style>
+<!--[if gte mso 10]>
+<style>
+ table.MsoNormalTable
+	{mso-style-name:"Table Normal";
+	mso-tstyle-rowband-size:0;
+	mso-tstyle-colband-size:0;
+	mso-style-parent:"";
+	mso-padding-alt:0in 5.4pt 0in 5.4pt;
+	mso-para-margin:0in;
+	mso-para-margin-bottom:.0001pt;
+	font-size:10.0pt;
+	mso-ansi-language:#0400;
+	mso-fareast-language:#0400;
+	mso-bidi-language:#0400;}
+</style>
+<![endif]-->
+</head>
+<body lang=EN-US link=blue vlink=purple style='tab-interval:.5in'>
+<div class=Section1>
+<h1>FDO 3.0 vs. FDO 3.2<o:p></o:p></h1>
+<p class=MsoNormal>The naming conventions used in version 3.2 of the FDO API <span
+class=GramE>have been modified</span> from those exposed in version 3.0 of the
+API. These modifications <span class=GramE>were undertaken</span> to move the
+naming conventions used in the API away from its Autodesk roots and position
+itself within the <span class=SpellE>OSGeo</span> framework. As a result of
+implementing these changes, users will be required to modify their applications
+to use the new names of the FDO classes, enumerations<span class=GramE>,
+&nbsp;header</span> files, libraries, etc.<o:p></o:p></p>
+<p class=MsoNormal><o:p>&nbsp;</o:p></p>
+<p class=MsoNormal>The following sections provide an overview on the naming
+changes that <span class=GramE>were made</span> in FDO 3.2.<span
+style='font-size:10.0pt;font-family:Arial'><o:p></o:p></span></p>
+<h2>Removal of Unused FDO API Interfaces<o:p></o:p></h2>
+<p class=MsoNormal>There was a subset of the FDO API that <span class=GramE>had
+not been implemented</span> in any provider. These unimplemented interfaces <span
+class=GramE>were removed</span> from the FDO API. <o:p></o:p></p>
+<h3>Removal of the Topology API<o:p></o:p></h3>
+<p class=MsoNormal>Removing the Topology API meant that all the topology
+related classes, files and enumeration values <span class=GramE>were removed</span>
+from the FDO API. <o:p></o:p></p>
+<p class=MsoNormal>A summary of the changes are as follows:<o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.25in;text-indent:-.25in;mso-list:l0 level1 lfo1;
+tab-stops:list .25in'><![if !supportLists]><span style='font-family:Symbol;
+mso-fareast-font-family:Symbol;mso-bidi-font-family:Symbol'><span
+style='mso-list:Ignore'>&middot;<span style='font:7.0pt "Times New Roman"'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
+</span></span></span><![endif]>The <span class=SpellE>FdoITopologyCapabilities</span>
+interface <span class=GramE>was removed</span> from the FDO API. <o:p></o:p></p>
+</span></span></span><![endif]>The <span class=SpellE>FdoIConnection</span>
+interface <span class=GramE>was modified</span> to remove the topology related
+capabilities method.<o:p></o:p></p>
+<p class=MsoNormal style='text-indent:.5in'><span class=GramE><span
+style='font-size:10.0pt;font-family:"Courier New";color:blue'>virtual</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'> <span class=SpellE>FdoITopologyCapabilities</span>*
+<span class=SpellE>GetTopologyCapabilities</span>();<o:p></o:p></span></p>
+</span></span></span><![endif]>The <span class=SpellE>FdoCommandType</span>
+Enumeration <span class=GramE>was updated</span> to remove the Topology related
+enumeration values. <o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoCommandType_ActivateTopologyArea</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'><o:p></o:p></span></p>
+style='font-size:10.0pt;font-family:"Courier New"'>FdoCommandType_DeactivateTopologyArea</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoCommandType_ActivateTopologyInCommandResult</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoCommandType_DeactivateTopologyInCommandResults</span></span><span
+<p class=MsoNormal><span style='font-size:10.0pt;font-family:"Courier New"'><o:p>&nbsp;</o:p></span></p>
+</span></span></span><![endif]>The following command interfaces <span
+class=GramE>were removed</span> from the FDO API as well as their associated .h
+and .<span class=SpellE>cpp</span> files.<o:p></o:p></p>
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIActivateTopologyArea</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIDeactivateTopologyArea</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIActivateTopologyInCommandResults</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIDeactivateTopologyInCommandResults</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIMoveTopoNode</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoIReconnectTopoEdge</span></span><o:p></o:p></p>
+</span></span></span><![endif]>The following schema management classes <span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoTopoGeometryPropertyDefinition</span></span><span
+style='font-size:10.0pt;font-family:"Courier New"'>FdoTopology</span></span><span
+<h3>Removal of the Network API<o:p></o:p></h3>
+<p class=MsoNormal>Removing the Network API will mean that all the network
+<p class=MsoNormal>A summary of the required changes are as follows:<o:p></o:p></p>
+</span></span></span><![endif]>The <span class=SpellE>FdoISchemaCapabilities</span>
+interface <span class=GramE>was modified</span> to remove the following network
+related capabilities method.<o:p></o:p></p>
+style='color:blue'>virtual</span></span> <span class=SpellE><span
+style='color:blue'>bool</span></span> <span class=SpellE>SupportsNetworkModel</span>();<o:p></o:p></p>
+Enumeration <span class=GramE>was updated</span> to remove the FDO Network
+related enumeration values. <o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkShortestPath</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkAllPaths</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkReachableNodes</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkReachingNodes</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkNearestNeighbors</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkWithinCost</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoCommandType_NetworkTSP</span><o:p></o:p></p>
+</span></span></span><![endif]>The following command and reader interfaces <span
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkAllPathsCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkNearestNeighborsCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkPathReader</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkReachableNodesCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkReachingNodesCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkReader</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkShortestPathCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkTSPCommand</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoINetworkWithinCostCommand</span><o:p></o:p></p>
+</span></span></span><![endif]>The following enumeration values <span
+class=GramE>were removed</span> from the <span class=SpellE>FdoClassType</span>
+enumeration.<o:p></o:p></p>
+<p class=MsoNormal style='text-indent:.5in'><span class=SpellE>FdoClassType_NetworkClass</span>,<o:p></o:p></p>
+<p class=MsoNormal style='text-indent:.5in'><span class=SpellE>FdoClassType_NetworkLayerClass</span>,<o:p></o:p></p>
+<p class=MsoNormal style='text-indent:.5in'><span class=SpellE>FdoClassType_NetworkNodeClass</span>,<o:p></o:p></p>
+<p class=MsoNormal style='text-indent:.5in'><span class=SpellE>FdoClassType_NetworkLinkClass</span><o:p></o:p></p>
+class=GramE>were removed</span> from the API as well as their associated .h and
+.<span class=SpellE>cpp</span> files.<o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoNetworkClass</span>
+<o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoNetworkFeatureClass</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoNetworkLayerClass</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoNetworkLinkFeatureClass</span><o:p></o:p></p>
+<p class=MsoNormal style='margin-left:.5in'><span class=SpellE>FdoNetworkNodeFeatureClass</span><o:p></o:p></p>
+<h2>Naming Modifications for the FDO API Libraries<o:p></o:p></h2>
+<p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Renaming
+Library Components in the FDO API <o:p></o:p></span></p>
+<p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'><o:p>&nbsp;</o:p></span></p>
+<table class=MsoNormalTable border=0 cellspacing=0 cellpadding=0
+ style='border-collapse:collapse;mso-padding-alt:0in 0in 0in 0in'>
+ <tr style='mso-yfti-irow:0;mso-yfti-firstrow:yes'>
+  <td width=119 valign=top style='width:89.55pt;border:solid black 1.5pt;
+  border-right:none;background:gray;padding:0in 5.4pt 0in 5.4pt'>
+  <p class=MsoNormal style='mso-margin-top-alt:auto;mso-margin-bottom-alt:auto'><span
+  style='font-size:10.0pt;font-family:Arial;color:white'>Component<o:p></o:p></span></p>
+  </td>
+  <td width=504 valign=top style='width:377.65pt;border:solid black 1.5pt;
+  border-left:none;background:gray;padding:0in 5.4pt 0in 5.4pt'>
+  style='font-size:10.0pt;font-family:Arial;color:white'>Description<o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:1'>
+  <td width=119 valign=top style='width:89.55pt;border-top:none;border-left:
+  solid black 1.5pt;border-bottom:solid black 1.0pt;border-right:none;
+  padding:0in 5.4pt 0in 5.4pt'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>GisCommon</span></span><span
+  style='font-size:10.0pt;font-family:Arial'><o:p></o:p></span></p>
+  </td>
+  <td width=504 valign=top style='width:377.65pt;border-top:none;border-left:
+  none;border-bottom:solid black 1.0pt;border-right:solid black 1.5pt;
+  class=GramE><span style='font-size:10.0pt;font-family:Arial'>Common type
+  definition and templates.</span></span><span style='font-size:10.0pt;
+  font-family:Arial'> <span class=GramE>Renamed to <span class=SpellE><b>FDOCommon</b></span>.</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:2'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>GisGeometry</span></span><span
+  </td>
+  style='font-size:10.0pt;font-family:Arial'>Geometry interfaces and factory
+  for FGF. Renamed to <span class=SpellE><b>FDOGeometry</b></span><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:3'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>FdoMessage</span></span><span
+  </td>
+  class=GramE><span style='font-size:10.0pt;font-family:Arial'>Message
+  catalogue for FDO.</span></span><span style='font-size:10.0pt;font-family:
+  Arial'> Renamed to <span class=SpellE><b>FDOMessage</b></span><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:4'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>GisMessage</span></span><span
+  </td>
+  catalogue for <span class=SpellE>GisCommon</span> and <span class=SpellE>GisGeometry</span>
+  Integrated with <span class=SpellE><b>FDOMessage</b></span> to form a single
+  message catalogue.</span></span><span style='font-size:10.0pt;font-family:
+  Arial'><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:5'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>GisNLS</span></span><span
+  </td>
+  style='font-size:10.0pt;font-family:Arial'>Globalization utility Renamed to <b>FDONLS</b><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:6'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>GisSpatial</span></span><span
+  </td>
+  class=GramE><span style='font-size:10.0pt;font-family:Arial'>Utility
+  component around <span class=SpellE>GisGeometry</span>.</span></span><span
+  style='font-size:10.0pt;font-family:Arial'>&nbsp; <span class=GramE>Includes:
+  geometry validation, transformation of ordinate (integer to double),
+  approximation algorithm.</span> <span class=GramE>Renamed to <span
+  class=SpellE><b>FDOSpatial</b></span>.</span>&nbsp; <o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:7'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>MgCommon</span></span><span
+  </td>
+  class=GramE><span style='font-size:10.0pt;font-family:Arial'>Managed wrapper
+  for <span class=SpellE>GisCommon</span>.</span></span><span style='font-size:
+  10.0pt;font-family:Arial'> Renamed to <b>OSGeo.FDO.Common.dll</b><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:8'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>MgFDO</span></span><span
+  </td>
+  for <span class=SpellE>Fdo</span>.</span></span><span style='font-size:10.0pt;
+  font-family:Arial'>&nbsp; Renamed to <b>OSGeo.FDO.dll</b><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:9'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>MgGeometry</span></span><span
+  </td>
+  for <span class=SpellE>GisGeometry</span>.</span></span><span
+  style='font-size:10.0pt;font-family:Arial'> Renamed to <b>OSGeo.FDO.Geometry.dll</b><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:10'>
+  class=SpellE><span style='font-size:10.0pt;font-family:Arial'>MgSpatial</span></span><span
+  </td>
+  style='font-size:10.0pt;font-family:Arial'>Spatial utility based on <span
+  class=SpellE>GisGeometry</span>. Renamed to <b>OSGeo.FDO.Spatial.dll</b><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:11;mso-yfti-lastrow:yes'>
+  solid black 1.5pt;border-bottom:solid black 1.5pt;border-right:none;
+  style='font-size:10.0pt;font-family:Arial'><o:p>&nbsp;</o:p></span></p>
+  </td>
+  none;border-bottom:solid black 1.5pt;border-right:solid black 1.5pt;
+  </td>
+ </tr>
+</table>
+<h2>Open Source Code Naming Conventions<o:p></o:p></h2>
+<p class=MsoNormal>All class names in the FDO API will start with camel case
+&#8220;<span class=SpellE>Fdo</span>&#8221;. The FDO interface definitions will
+start with &#8220;<span class=SpellE>FdoI</span>&#8221;. Class members will be
+defined by getter and setter prefix with Get/Set.&nbsp; <o:p></o:p></p>
+<p class=MsoNormal>The FDO providers have been somewhat standardized to name
+their <span class=SpellE>Fdo</span> implementation classes following the <span
+class=GramE>pattern:</span> <span class=SpellE>Fdo</span>&lt;provider
+abbreviation&gt;Implementation.<o:p></o:p></p>
+<p class=MsoNormal>The current FDO API makes use of terms
+&#8216;Autodesk&#8217; and &#8216;<span class=SpellE>Gis</span>&#8217;. These
+terms <span class=GramE>will be replaced</span> in the Open Source release with
+&#8216;<span class=SpellE>OSGeo</span>&#8217; and &#8216;<span class=SpellE>Fdo</span>&#8217;.
+The following sections outline the major areas of change.<o:p></o:p></p>
+<h3>Managed API Namespaces Changes<o:p></o:p></h3>
+<p class=MsoNormal>The namespaces for the FDO Managed APIs currently refer to <span
+class=SpellE>Autodesk.Gis.Fdo</span>.&nbsp; These namespaces <span class=GramE>will
+be modified</span> to reference <span class=SpellE>OSGeo.FDO</span> as follows:<o:p></o:p></p>
+ style='margin-left:5.4pt;border-collapse:collapse;mso-padding-alt:0in 0in 0in 0in'>
+  <td width=262 valign=top style='width:196.35pt;border:solid black 1.5pt;
+  <p class=MsoNormal><b><span style='color:white'>3.0 API<o:p></o:p></span></b></p>
+  </td>
+  <td width=299 valign=top style='width:224.4pt;border:solid black 1.5pt;
+  <p class=MsoNormal><b><span style='color:white'>3.2 API<o:p></o:p></span></b></p>
+  </td>
+ </tr>
+  <td width=262 valign=top style='width:196.35pt;border-top:none;border-left:
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis</span><o:p></o:p></p>
+  </td>
+  <td width=299 valign=top style='width:224.4pt;border-top:none;border-left:
+  <p class=MsoNormal><span class=SpellE>OSGeo</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Runtime</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.Runtime</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Common</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.Common</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Geometry</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.Geometry</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Spatial</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.Spatial</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Utilities</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Utilities</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers.Shape</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers.SHP</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers.ODBC</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers.ODBC</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:11'>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers.MySQL</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers.MySQL</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:12'>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers.WMS</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers.WMS</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:13;mso-yfti-lastrow:yes'>
+  <p class=MsoNormal><span class=SpellE>Autodesk.Gis.Fdo.Providers.WFS</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>OSGeo.FDO.Providers.WFS</span><o:p></o:p></p>
+  </td>
+ </tr>
+</table>
+<h3>Macro/Preprocessor Name Changes<o:p></o:p></h3>
+<p class=MsoNormal>There are a number of FDO macro and preprocessor definitions
+that <span class=GramE>were renamed</span> to remove references to <span
+class=SpellE>Gis</span>.<o:p></o:p></p>
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_GIS<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_FDO<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_GISGEOM<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_GEOM<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GIS_API<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>FDO_API<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GISGEOM_API<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GEOM_API<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GISSPATIAL_STATIC<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>SPATIAL_STATIC<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_GISSPATIAL<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>EXP_SPATIAL<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GISSPATIAL_API<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>SPATIAL_API<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GIS_COLL_MAP_THRESHOLD<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>FDO_COLL_MAP_THRESHOLD<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GIS_NLSID<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>FDO_NLSID<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GIS_SAFE_RELEASE<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>FDO_SAFE_RELEASE<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt'>GIS_SAFE_ADDREF<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt'>FDO_SAFE_ADDREF<o:p></o:p></span></p>
+  </td>
+ </tr>
+</table>
+<h3>Type Name Changes<o:p></o:p></h3>
+  </td>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:1;height:7.8pt'>
+  padding:0in 5.4pt 0in 5.4pt;height:7.8pt'>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>GisDimensionality</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>FdoDimensionality</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryType</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryType</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryComponentType</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryComponentType</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisStreamReaderType</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStreamReaderType</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisSpatialGeometryValidity</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoSpatialGeometryValidity</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisToken</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoToken</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>gis_awkt_yytokentype</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>fdo_awkt_yytokentype</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE><span style='font-size:10.0pt;
+  font-family:Arial'>GisByte</span></span><span style='font-size:10.0pt;
+  font-family:Arial'> <o:p></o:p></span></p>
+  </td>
+  font-family:Arial'>FdoByte</span></span><span style='font-size:10.0pt;
+  font-family:Arial'><o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>GisInt8<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>FdoInt8<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>GisInt16<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>FdoInt16<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>GisInt32 <o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>FdoInt32<o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>GisInt64<o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>FdoInt64<o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:13'>
+  font-family:Arial'>GisCharacter</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoCharacter</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:14'>
+  font-family:Arial'>GisVoid</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoVoid</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:15'>
+  font-family:Arial'>GisDouble</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoDouble</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:16'>
+  font-family:Arial'>GisFloat</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoFloat</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:17'>
+  font-family:Arial'>GisSize</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoSize</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:18'>
+  font-family:Arial'>GisBoolean</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoBoolean</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:19'>
+  font-family:Arial'>GisString</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoString</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:20'>
+  font-family:Arial'>GisDateTime</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoDateTime</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:21;mso-yfti-lastrow:yes'>
+  font-family:Arial'>GisSpatialGeometryValidity</span></span><span
+  </td>
+  font-family:Arial'>FdoSpatialGeometryValidity</span></span><span
+  </td>
+ </tr>
+</table>
+<h3>Class/Interface Name Changes<o:p></o:p></h3>
+<p class=MsoNormal>The prefix of the FDO Common classes changed from <span
+class=SpellE>Gis</span> to <span class=SpellE>Fdo</span><o:p></o:p></p>
+  <p class=MsoNormal><b><span style='color:white'>3.0 Class Names<o:p></o:p></span></b></p>
+  </td>
+  <p class=MsoNormal><b><span style='color:white'>3.2 Class Names<o:p></o:p></span></b></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><o:p>&nbsp;</o:p></p>
+  </td>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:2;height:7.8pt'>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>GisArray</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>FdoArray</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:3;height:7.8pt'>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>GisIntArray</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal style='mso-line-height-alt:7.8pt'><span class=SpellE>FdoIntArray</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisArrayHelper</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoArrayHelper</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisDictionary</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDictionary</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisDictionaryElement</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDictionaryElement</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisDisposable</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDisposable</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIDisposable</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIDisposable</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisException</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoException</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisPtr</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoPtr</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisSemaphore</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoSemaphore</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisStringP</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStringP</span><o:p></o:p></p>
+  </td>
+ </tr>
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIStreamReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIStreamReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIStreamReaderTmpl</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIStreamReaderTmpl</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisNamedCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoNamedCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisReadOnlyNamedCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoReadOnlyNamedCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisRestrictedNamedCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoRestrictedNamedCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisStack</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStack</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:21'>
+  <p class=MsoNormal><span class=SpellE>GisStringElement</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStringElement</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:22'>
+  <p class=MsoNormal><span class=SpellE>GisStringCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStringCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:23'>
+  <p class=MsoNormal><span class=SpellE>GisStringsP</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoStringsP</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:24'>
+  <p class=MsoNormal><span class=SpellE>GisDateTime</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDateTime</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:25'>
+  <p class=MsoNormal><span class=SpellE>GisVectorElement</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoVectorElement</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:26'>
+  <p class=MsoNormal><span class=SpellE>GisVector</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoVector</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:27'>
+  <p class=MsoNormal><span class=SpellE>GisVectorP</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoVectorP</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:28'>
+  <p class=MsoNormal>GisGml212<o:p></o:p></p>
+  </td>
+  <p class=MsoNormal>FdoGml212<o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:29'>
+  <p class=MsoNormal>GisGml212Schema<o:p></o:p></p>
+  </td>
+  <p class=MsoNormal>FdoGml212Schema<o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:30'>
+  <p class=MsoNormal><span class=SpellE>GisIoBufferStream</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoBufferStream</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:31'>
+  <p class=MsoNormal><span class=SpellE>GisIoByteStreamReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoByteStreamReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:32'>
+  <p class=MsoNormal><span class=SpellE>GisIoFileStream</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoFileStream</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:33'>
+  <p class=MsoNormal><span class=SpellE>GisIoMemoryStream</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoMemoryStream</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:34'>
+  <p class=MsoNormal><span class=SpellE>GisIoObjectStreamReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoObjectStreamReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:35'>
+  <p class=MsoNormal><span class=SpellE>GisIoObjectStream</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoObjectStream</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:36'>
+  <p class=MsoNormal><span class=SpellE>GisIoStream</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoStream</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:37'>
+  <p class=MsoNormal><span class=SpellE>GisIoTextReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoTextReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:38'>
+  <p class=MsoNormal><span class=SpellE>GisIoTextWriter</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIoTextWriter</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:39'>
+  <p class=MsoNormal><span class=SpellE>GisXmlAttribute</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlAttribute</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:40'>
+  <p class=MsoNormal><span class=SpellE>GisXmlAttributeCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlAttributeCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:41'>
+  <p class=MsoNormal><span class=SpellE>GisXmlCharDataHandler</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlCharDataHandler</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:42'>
+  <p class=MsoNormal><span class=SpellE>GisXmlCopyHandler</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlCopyHandler</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:43'>
+  <p class=MsoNormal><span class=SpellE>GisXmlReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:44'>
+  <p class=MsoNormal><span class=SpellE>GisXmlSaxContext</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlSaxContext</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:45'>
+  <p class=MsoNormal><span class=SpellE>GisXmlSaxHandler</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlSaxHandler</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:46'>
+  <p class=MsoNormal><span class=SpellE>GisXmlSkipElementHandler</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlSkipElementHandler</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:47'>
+  <p class=MsoNormal><span class=SpellE>GisXmlUtilXrcs</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlUtilXrcs</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:48'>
+  <p class=MsoNormal><span class=SpellE>GisXmlWriter</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXmlWriter</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:49'>
+  <p class=MsoNormal><span class=SpellE>GisXml</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXml</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:50'>
+  <p class=MsoNormal><span class=SpellE>GisXslTransformer</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXslTransformer</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:51'>
+  <p class=MsoNormal><span class=SpellE>GisXslTransformerXalan</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoXslTransformerXalan</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:52;mso-yfti-lastrow:yes'>
+  </td>
+  </td>
+ </tr>
+</table>
+<p class=MsoNormal>Note: Class <span class=SpellE><b>GisException</b></span>
+and class <span class=SpellE><b>FdoException</b></span> were merged together to
+form a single <span class=SpellE><b>FdoException</b></span> exception class.<i><span
+style='font-size:10.0pt;font-family:Arial'><o:p></o:p></span></i></p>
+<p class=MsoNormal><i><span style='font-size:10.0pt;font-family:Arial'><o:p>&nbsp;</o:p></span></i></p>
+<p class=MsoNormal><i><span style='font-size:10.0pt;font-family:Arial'>The
+prefix of the FDO Geometry classes changed from <span class=SpellE><span
+class=GramE>Gis</span></span> to <span class=SpellE>Fdo</span><o:p></o:p></span></i></p>
+  </td>
+  </td>
+ </tr>
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisDirectPositionImpl</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDirectPositionImpl</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisEnvelopeImpl</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoEnvelopeImpl</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryFactoryAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryFactoryAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIArcSegmentAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIArcSegmentAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisICircularArcSegment</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoICircularArcSegment</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisICurveAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoICurveAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisICurvePolygon</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoICurvePolygon</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisCurvePolygonCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoCurvePolygonCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisICurveSegmentAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoICurveSegmentAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisCurveSegmentCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoCurveSegmentCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisICurveString</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoICurveString</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisCurveStringCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoCurveStringCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIDirectPosition</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIDirectPosition</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisDirectPositionCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoDirectPositionCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIEnvelope</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIEnvelope</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIGeometricAggregateAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIGeometricAggregateAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIGeometry</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIGeometry</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisILinearRing</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoILinearRing</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisLinearRingCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoLinearRingCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisILineString</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoILineString</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisLineStringCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoLineStringCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisILineStringSegment</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoILineStringSegment</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiCurvePolygon</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiCurvePolygon</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiCurveString</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiCurveString</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiGeometry</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiGeometry</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiLineString</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiLineString</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiPoint</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiPoint</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIMultiPolygon</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIMultiPolygon</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIPoint</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIPoint</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisPointCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoPointCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIPolygon</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIPolygon</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisPolygonCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoPolygonCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIRing</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIRing</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisRingCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoRingCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisIRingAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoIRingAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisISurfaceAbstract</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoISurfaceAbstract</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisAgfGeometryFactory</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoFgfGeometryFactory</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryStreamFactory</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryStreamFactory</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryStreamReader</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryStreamReader</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisGeometryStreamWriter</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoGeometryStreamWriter</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:43;mso-yfti-lastrow:yes'>
+  </td>
+  </td>
+ </tr>
+</table>
+prefix of the FDO Spatial classes changed from <span class=SpellE><span
+  <p class=MsoNormal><b><span style='color:white'>3.0 Class Name<o:p></o:p></span></b></p>
+  </td>
+  <p class=MsoNormal><b><span style='color:white'>3.2 Class Name<o:p></o:p></span></b></p>
+  </td>
+ </tr>
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisSpatialGridTransform</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoSpatialGridTransform</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GisSpatialUtility</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoSpatialUtility</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:4;mso-yfti-lastrow:yes'>
+  </td>
+  </td>
+ </tr>
+</table>
+<h3>AGF to FGF Name Change<o:p></o:p></h3>
+<p class=MsoNormal>The FDO API uses the term AGF or Autodesk Geometry Format in
+<span class=GramE>it&#8217;s</span> API. This term will be replaced with <span
+class=GramE>FGF which</span> shall represent <span class=SpellE>Fdo</span>
+Geometry Format or Feature Geometry Format. <o:p></o:p></p>
+<p class=MsoNormal>In order to make this change the geometry class that handles
+the creation of AGF geometry <span class=SpellE>GisAgfGeometryFactory</span>
+and GisAgfGeometryFactory2, will have to be renamed <span class=SpellE>GisFgfGeometryFactory</span>
+and GisFgfGeometryFactory2. There are also factory methods such as <span
+class=SpellE>CreateGeometryFromAgf</span> and <span class=SpellE>GetAgf</span>
+that will need to <span class=GramE>be modified</span>.<o:p></o:p></p>
+  <td width=295 valign=top style='width:221.4pt;border:solid black 1.5pt;
+  <p class=MsoNormal><b><span style='color:white'>3.0 Factory Method Name<o:p></o:p></span></b></p>
+  </td>
+  <p class=MsoNormal><b><span style='color:white'>3.2 Factory Method Name<o:p></o:p></span></b></p>
+  </td>
+ </tr>
+  <td width=295 valign=top style='width:221.4pt;border-top:none;border-left:
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>CreateGeometryFromFgf</span><o:p></o:p></p>
+  </td>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>GetFgf</span><o:p></o:p></p>
+  </td>
+  </td>
+ </tr>
+  </td>
+  </td>
+ </tr>
+</table>
+<h3>SHP Override API Class Naming Conventions<o:p></o:p></h3>
+<p class=MsoNormal>Physical Overrides APIs <span class=GramE>are defined</span>
+for SHP, ODBC, <span class=SpellE>MySQL</span> and WMS providers. At this <span
+class=GramE>point</span> the naming conventions for the APIs have not been
+standardized. As a part of the Open Source preparedness effort, these APIs will
+be standardized to use a common prefix of <span class=SpellE><span class=GramE><b>Fdo</b></span></span><span
+class=GramE><b>[</b></span><b>Provider]<span class=SpellE>Ov</span></b>. This
+naming convention is already in use for the ODBC, <span class=SpellE>MySQL</span>
+and WMS providers. The SHP provider <span class=GramE>will be updated</span> to
+also follow this standard. The following table outlines the Open Source class
+names that <span class=GramE>will be used</span> for the SHP Provider. <o:p></o:p></p>
+  <td width=286 valign=top style='width:214.85pt;border:solid black 1.5pt;
+  </td>
+  <td width=312 valign=top style='width:233.95pt;border:solid black 1.5pt;
+  </td>
+ </tr>
+  <td width=286 valign=top style='width:214.85pt;border-top:none;border-left:
+  </td>
+  <td width=312 valign=top style='width:233.95pt;border-top:none;border-left:
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpClassCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvClassCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpClassDefinition</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvClassDefinition</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpColumnDefinition</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvColumnDefinition</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpPhysicalSchemaMapping</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvPhysicalSchemaMapping</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpPropertyDefinition</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvPropertyDefinition</span><o:p></o:p></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span class=SpellE>FdoShpPropertyDefinitionCollection</span><o:p></o:p></p>
+  </td>
+  <p class=MsoNormal><span class=SpellE>FdoShpOvPropertyDefinitionCollection</span><o:p></o:p></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:8;mso-yfti-lastrow:yes'>
+  </td>
+  </td>
+ </tr>
+</table>
+<h3>File Name Changes<o:p></o:p></h3>
+<p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Several FDO
+API files have had their names changes to conform to the common file naming
+convention or to remove GIS from their filenames. <o:p></o:p></span></p>
+  <p class=MsoNormal><b><span style='color:white'>3.0 File Name<o:p></o:p></span></b></p>
+  </td>
+  <p class=MsoNormal><b><span style='color:white'>3.2 File Name<o:p></o:p></span></b></p>
+  </td>
+ </tr>
+  font-family:Arial'>GisCommon.h</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoCommon.h</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+  font-family:Arial'>GisGeometry.h</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoGeometry.h</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+  font-family:Arial'>GisMessage.h</span></span><span style='font-size:10.0pt;
+  </td>
+  font-family:Arial'>FdoMessage.h</span></span><span style='font-size:10.0pt;
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>common/<span
+  class=SpellE>Types.h</span><o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Common/<span
+  class=SpellE>FdoTypes.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisPtr.h</span><o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Common /<span
+  class=SpellE>Ptr.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisSemaphore.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>Semaphore.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisStd.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>Std.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisStringp.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>Stringp.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  font-family:Arial'>fdo/FdoCollection.h</span></span><span style='font-size:
+  10.0pt;font-family:Arial'> <o:p></o:p></span></p>
+  </td>
+  class=SpellE>Collection.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  font-family:Arial'>fdo/FdoException.h</span></span><span style='font-size:
+  10.0pt;font-family:Arial'><o:p></o:p></span></p>
+  </td>
+  class=SpellE>Exception.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>geometry\<span
+  class=SpellE>AgfGeometry\AgfGeometryFactory.h</span><o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Geometry\<span
+  class=SpellE>Fgf\Factory.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>spatial\<span
+  class=SpellE>GisSpatialGeometryValidity.h</span><o:p></o:p></span></p>
+  </td>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>Spatial\<span
+  class=SpellE>FdoSpatialGeometryValidity.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisSpatialGridTransform.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>FdoSpatialGridTransform.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisSpatialStd.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>SpatialStd.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+  class=SpellE>GisSpatialUtility.h</span><o:p></o:p></span></p>
+  </td>
+  class=SpellE>SpatialUtility.h</span><o:p></o:p></span></p>
+  </td>
+ </tr>
+ <tr style='mso-yfti-irow:16;mso-yfti-lastrow:yes'>
+  <p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'><o:p>&nbsp;</o:p></span></p>
+  </td>
+  </td>
+ </tr>
+</table>
+<h2>Documentation<o:p></o:p></h2>
+<p class=MsoNormal>In Version 3.2, FDO Open Source API reference documentation <span
+class=GramE>will be generated</span> using <span class=SpellE>Doxygen</span>.
+API documentation content will retrieved directly from the header files that
+constitute the public FDO API.<o:p></o:p></p>
+</div>
+</body>
+</html>
Modified: trunk/www/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/index.html?view=diff&rev=66&p1=trunk/www/index.html&p2=trunk/www/index.html&r1=65&r2=66
--- trunk/www/index.html	(original)
+++ trunk/www/index.html	2006-10-19 22:05:24+0000
@@ -79,7 +79,7 @@
 					<a href="history.html">History</a><br>
 					<a href="productsUsingFdo.html">Products Using FDO</a><br>
 					<a href="featureDescriptions.html">Feature Descriptions</a><br>
-               <a href="OSProviderOverviews.html">Provider Overviews</a><br>
+					<a href="OSProviderOverviews.html">Provider Overviews</a><br>
 					<a href="OSFeatureMatrix.html">Feature Matrix</a><br>
 					<a href="enterpriseProviderOverviews.html">Enterprise Provider Overviews</a><br>
@@ -88,12 +88,13 @@
 					<a href="roadMap.html">Road Map</a><br>
 					<a href="systemRequirements.html">Requirements</a><br>
 					<a href="gettingStarted.html">Getting Started</a><br>
-               <a href="faq.html">FAQ</a><br>
+					<a href="faq.html">FAQ</a><br>
 					<a href="HOWTOWriteAProvider.html">HOWTO: Write a Provider</a><br>
 					<a href="licenceAndGovernance.html">Licence and Governance</a><br>
-					<a href="glossary.html">Glossary</a>
+					<a href="glossary.html">Glossary</a><br>
+					<a href="fdo32.html">FDO 3.0 vs. FDO 3.2</a>
               </div
             ></td>
           </tr>
@@ -102,8 +103,8 @@
             <td align="left" valign="top">
               <div class="h2">
 					<h2>Releases</h2>
-                <a href="downloads.html">Downloads</a><br>
-					 <a href="documentation.html">Documentation</a><br>
+					<a href="downloads.html">Downloads</a><br>
+					<a href="documentation.html">Documentation</a><br>
               </div>
               <div class="h2">
More information about the Fdo-commits mailing list
