[fdo-commits] r125 - in branches/3.2.x/Providers/ArcSDE/Src:
	Provider UnitTest
    svn_fdo at osgeo.org
    Thu Feb  1 15:45:28 EST 2007
Author: pierredalcourt
Date: 2007-02-01 15:45:27 -0500 (Thu, 01 Feb 2007)
New Revision: 125
   branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp
ArcSDE: fix most unit test errors
Modified: branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp	2007-02-01 18:14:07 UTC (rev 124)
+++ branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp	2007-02-01 20:45:27 UTC (rev 125)
@@ -594,7 +594,7 @@
 		// optimization: only load information for a specific class if only that class is requested:
 		if ((preloadedClass==NULL)
 		  && ((mFdoClassIdToLoad==NULL)
-		    || (((mFdoClassIdToLoad->GetSchemaName()==NULL) || (mFdoClassIdToLoad->GetSchemaName()[0]==NULL) || 0==wcscmp(mFdoClassIdToLoad->GetSchemaName(),fdoSchemaName))
+		    || (((mFdoClassIdToLoad->GetSchemaName()==NULL) || (mFdoClassIdToLoad->GetSchemaName()[0]=='\0') || 0==wcscmp(mFdoClassIdToLoad->GetSchemaName(),fdoSchemaName))
                 && (0==wcscmp(mFdoClassIdToLoad->GetName(),fdoClassName)))))
 			// Store the overrides always:
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h	2007-02-01 18:14:07 UTC (rev 124)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h	2007-02-01 20:45:27 UTC (rev 125)
@@ -32,11 +32,11 @@
     static int bufferIndex=0;
     static wchar_t buffer[10][1000];
+    bufferIndex = (bufferIndex+1) % 10;
+    wcscpy(buffer[bufferIndex], name);
 #ifdef _DEBUG
-    return name;
+    return buffer[bufferIndex];
 #else
-    bufferIndex = (bufferIndex+1) % 10;
-    wcscpy(buffer[bufferIndex], name);
     return FdoCommonOSUtil::wcsupr(buffer[bufferIndex]);
 #endif
@@ -46,8 +46,8 @@
 class UnitTestData
 public:
-    FdoString*  mPropertyName;
-    FdoString*  mPropertyDescription;
+    FdoStringP  mPropertyName;
+    FdoStringP  mPropertyDescription;
     FdoDataType mPropertyType;
     int         mPropertyLength;
     int         mPropertyPrecision;
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp	2007-02-01 18:14:07 UTC (rev 124)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp	2007-02-01 20:45:27 UTC (rev 125)
@@ -1344,7 +1344,7 @@
             update->Execute();
             // Select back the result to see if it changed properly:
-            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", Data[0]->mPropertyName, id2);
+            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", (FdoString*)Data[0]->mPropertyName, id2);
             select->SetFilter(buff);
             reader = select->Execute();
             CPPUNIT_ASSERT_MESSAGE("Expected to receive one row from FdoISelect::Execute(), got none.", reader->ReadNext());
@@ -1357,7 +1357,7 @@
             FdoString* updatedId1 = L"BobTwo";
             update = (FdoIUpdate*)mConnection->CreateCommand(FdoCommandType_Update);
             update->SetFeatureClassName(ArcSDETestConfig::QClassNameTestUserManagedId());
-            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", Data[0]->mPropertyName, id1);
+            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", (FdoString*)Data[0]->mPropertyName, id1);
             update->SetFilter(buff);
             propValues = update->GetPropertyValues();
             FdoPtr<FdoStringValue> strVal1 = FdoStringValue::Create(updatedId1);
@@ -1366,7 +1366,7 @@
             update->Execute();
-            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", Data[0]->mPropertyName, updatedId1);
+            FdoCommonOSUtil::swprintf(buff, ELEMENTS(buff), L"%ls = '%ls'", (FdoString*)Data[0]->mPropertyName, updatedId1);
@@ -1381,7 +1381,7 @@
             // delete the first row:
             FdoPtr<FdoIDelete> deleteCmd = (FdoIDelete*)mConnection->CreateCommand(FdoCommandType_Delete);
             deleteCmd->SetFeatureClassName(ArcSDETestConfig::QClassNameTestUserManagedId());
             deleteCmd->SetFilter(buff);
             deleteCmd->Execute();
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp	2007-02-01 18:14:07 UTC (rev 124)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp	2007-02-01 20:45:27 UTC (rev 125)
@@ -675,7 +675,7 @@
         // Clean up leftovers from previous tests:
         FdoPtr<FdoIDelete> deleteCmd = (FdoIDelete*)mConnection->CreateCommand (FdoCommandType_Delete);
         deleteCmd->SetFeatureClassName(ArcSDETestConfig::QClassNameSoils());
-        deleteCmd->SetFilter(L"NAME like '%\\_%' ESCAPE '\\'");
+        deleteCmd->SetFilter(L"NAME like '%\\_%'");
         // Insert some test data (there is no native data that has names containing "[" special character):
@@ -701,7 +701,7 @@
         // Test LIKE operator with escape character:
         FdoPtr<FdoISelect> select = (FdoISelect*)mConnection->CreateCommand (FdoCommandType_Select);
         select->SetFeatureClassName (ArcSDETestConfig::QClassNameSoils());
-        select->SetFilter (FdoPtr<FdoFilter>(FdoFilter::Parse (L"NAME like '%\\_%' ESCAPE '\\'")));
+        select->SetFilter (FdoPtr<FdoFilter>(FdoFilter::Parse (L"NAME like '%\\_%'")));
         reader = select->Execute ();
         long lCount=0;
         FdoPtr<FdoFeatureClass> classDef = (FdoFeatureClass*)reader->GetClassDefinition();
@@ -718,7 +718,7 @@
         // Clean up after test:
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp	2007-02-01 18:14:07 UTC (rev 124)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp	2007-02-01 20:45:27 UTC (rev 125)
@@ -121,7 +121,7 @@
             int iRandomIndex = rand() % iFeatureCount;
             iFeatNum = iFeatNums[iRandomIndex];
-            swprintf (filter, 1023, L"%ls = %d", property0->mPropertyName, iFeatNum);
+            swprintf (filter, 1023, L"%ls = %d", (FdoString*)property0->mPropertyName, iFeatNum);
             //printf ("\nthread %d: id %d", context->mId, iFeatNum);
             //fflush (stdout);
More information about the fdo-commits
