[fdo-commits] r670 - branches/fdordbms-postgis/Providers/GenericRdbms/Src/Gdbi
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 22 20:53:58 EST 2007
Author: mloskot
Date: 2007-01-22 20:53:58 -0500 (Mon, 22 Jan 2007)
New Revision: 670
   branches/fdordbms-postgis/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp
Include column name of missing column, in exception message.
Modified: branches/fdordbms-postgis/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp
--- branches/fdordbms-postgis/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp	2007-01-22 22:24:44 UTC (rev 669)
+++ branches/fdordbms-postgis/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp	2007-01-23 01:53:58 UTC (rev 670)
@@ -92,13 +92,21 @@
     int  idx = 1;
 	bool status = false;
-    while( m_pGdbiCommands->desc_slct( m_QueryId->GetQueryId(), idx++, name_length, colName, &colInfo->type, &colInfo->size, &colInfo->null_allowed) == RDBI_SUCCESS )
+    while (m_pGdbiCommands->desc_slct(m_QueryId->GetQueryId(), idx++, name_length,
+           colName, &colInfo->type, &colInfo->size, &colInfo->null_allowed) == RDBI_SUCCESS)
         FdoStringP  upperName = FdoStringP(colName).Upper();
         const wchar_t* name = (const wchar_t*)upperName;
         if (mColMap->find (name) != mColMap->end())
-            continue; // TODO: throw new GdbiException(FdoCommonNlsUtil::NLSGetMessage( FDORDBMS_495, "Duplicate columns of name '%1$ls' found in query result.", fdordbms_cat, name));
+            // TODO: throw new GdbiException(FdoCommonNlsUtil::NLSGetMessage(
+            // FDORDBMS_495, "Duplicate columns of name '%1$ls' found in query result.",
+            // fdordbms_cat, name));
+            continue;
         mColMap->insert( std::pair<std::wstring,GdbiColumnInfoType*> ( name, colInfo ) );
         colInfo->original_type = colInfo->type;
         colInfo->index = idx-1;
@@ -128,12 +136,13 @@
 				for (int i = 0; i < m_pGdbiCommands->get_array_size(); i++)
-					m_pGdbiCommands->lob_create_ref( m_QueryId->GetQueryId(), (void **)&(colInfo->value));
+					m_pGdbiCommands->lob_create_ref(m_QueryId->GetQueryId(), (void **)&(colInfo->value));
 			else
-				if( ( m_pGdbiCommands->SupportsUnicode() && colInfo->type == RDBI_STRING ) || colInfo->type == RDBI_WSTRING  )
+				if((m_pGdbiCommands->SupportsUnicode() && colInfo->type == RDBI_STRING)
+                    || colInfo->type == RDBI_WSTRING)
 					int size =  colInfo->size * m_pGdbiCommands->get_array_size();
 					colInfo->value = new wchar_t[size];
@@ -145,11 +154,15 @@
 					colInfo->value = new char[size];
-					memset( colInfo->value, '\0', size );
+					memset(colInfo->value, '\0', size );
-			m_pGdbiCommands->define( m_QueryId->GetQueryId(), FdoCommonOSUtil::itoa(colInfo->index, buffer), colInfo->type, colInfo->size, (colInfo->type == RDBI_BLOB_REF) ? (char *)&(colInfo->value) : (char*)colInfo->value, colInfo->isNull );
+			m_pGdbiCommands->define(m_QueryId->GetQueryId(),
+                FdoCommonOSUtil::itoa(colInfo->index, buffer),
+                colInfo->type, colInfo->size,
+                (colInfo->type == RDBI_BLOB_REF) ? (char*)&(colInfo->value) : (char*)colInfo->value,
+                colInfo->isNull);
@@ -309,7 +322,11 @@
         return RDBI_SUCCESS;
-    throw new GdbiException(L"Column X not selected");
+    // TODO: mloskot - Change for easier debugging
+    // Original code: throw new GdbiException(L"Column X not selected");
+    throw new GdbiException(
+        FdoStringP::Format(L"Column %ls not selected", upperName));
 int GdbiQueryResult::GetAsciiValue( const wchar_t *colName, int length, char *address, bool *null_ind, int *ccode )
@@ -385,7 +402,11 @@
 template<typename T> T GdbiQueryResult::GetNumber(
@@ -478,7 +499,12 @@
         return val;
 FdoDouble GdbiQueryResult::GetDouble( const wchar_t *ColName, bool *isnull, int *ccode )
@@ -575,23 +601,30 @@
         return mUnicodeBuffer;
 FdoString* GdbiQueryResult::GetString( int index, bool *isnull, int *ccode )
-   if( mColMap )
+    typedef std::map<std::wstring, GdbiColumnInfoType*> ColumnsMap;
+    if( mColMap )
-        for (std::map <std::wstring,GdbiColumnInfoType*>::iterator i = mColMap->begin(); i != mColMap->end(); ++i )
+        for (ColumnsMap::iterator i = mColMap->begin(); i != mColMap->end(); ++i)
             GdbiColumnInfoType *colInfo = i->second;
             if( colInfo->index == index )
-				return GetString( i->first.c_str() , isnull, ccode );
+                return GetString( i->first.c_str() , isnull, ccode );
+    throw new GdbiException(L"Column X not selected");
 FdoBoolean GdbiQueryResult::GetBoolean( const wchar_t *ColName, bool *isnull, int *ccode )
@@ -616,7 +649,12 @@
         return ( m_pGdbiCommands->is_null( colInfo->isNull, mArrayPos ) == 1 );
 void GdbiQueryResult::do_copy(char *ascii_I, char *ascii_O, int len, int *ccode)
More information about the fdo-commits mailing list
