[fdo-commits] r118 - branches/3.2.x/Providers/ArcSDE/Src/UnitTest
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Jan 26 07:32:08 EST 2007
Author: pierredalcourt
Date: 2007-01-26 07:32:08 -0500 (Fri, 26 Jan 2007)
New Revision: 118
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicUpdateTests.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/RecommitTest.cpp
   branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp
ArcSDE + GenericRDBMS: fix unit test errors
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.cpp	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.cpp	2007-01-26 12:32:08 UTC (rev 118)
@@ -203,8 +203,8 @@
 int ArcSDETests::Insert (FdoIConnection* connection, UnitTestClass* definition, size_t index)
-    wchar_t* id;
-    wchar_t* name;
+    FdoString* id;
+    FdoString* name;
     FdoPtr<FdoValueExpression> expression;
     FdoPtr<FdoPropertyValue> value;
     int ret;
@@ -264,7 +264,7 @@
     FdoPtr<FdoFilter> filter;
     FdoPtr<FdoIUpdate> update;
     FdoPtr<FdoPropertyValueCollection> values;
-    wchar_t* name;
+    FdoString* name;
     int count;
@@ -723,7 +723,7 @@
-void ArcSDETests::checkEqual(FdoPtr<FdoIFeatureReader> reader, wchar_t* propertyName, FdoDataType propertyType, const wchar_t* propertyData)
+void ArcSDETests::checkEqual(FdoPtr<FdoIFeatureReader> reader, FdoString* propertyName, FdoDataType propertyType, FdoString* propertyData)
     // Get the literal expression we're comparing against:
     FdoPtr<FdoExpression> expression = ArcSDETests::ParseByDataType(propertyData,propertyType);
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h	2007-01-26 12:32:08 UTC (rev 118)
@@ -23,13 +23,31 @@
 #pragma once
 #endif // _WIN32
+// Updates the given name based on whether the unit tests are being run in
+// release mode or debug mode.  This is necessary following recent performance
+// changes which cause the provider to behave differently if run in
+// debug vs release mode, namely that FDO metadata that impacts FDO class/property
+// names is only retrieved in debug mode since ApplySchema is only supported in debug mode.
+static FdoString* AdjustRdbmsName(FdoString* name)
+    static int bufferIndex=0;
+    static wchar_t buffer[10][1000];
+#ifdef _DEBUG
+    return name;
+#else
+    bufferIndex = (bufferIndex+1) % 10;
+    wcscpy(buffer[bufferIndex], name);
+    return wcsupr(buffer[bufferIndex]);
+#endif
 // Represents one FDO data property with a corresponding data value
 class UnitTestData
 public:
-    wchar_t*    mPropertyName;
-    wchar_t*    mPropertyDescription;
+    FdoString*  mPropertyName;
+    FdoString*  mPropertyDescription;
     FdoDataType mPropertyType;
     int         mPropertyLength;
     int         mPropertyPrecision;
@@ -40,8 +58,8 @@
     std::vector<const wchar_t*> mPropertyData;
     UnitTestData (
-        wchar_t*    property_name,
-        wchar_t*    property_description,
+        FdoString*  property_name,
+        FdoString*  property_description,
         FdoDataType property_type,
         int         property_length,
         int         property_precision,
@@ -62,6 +80,7 @@
         const wchar_t* data;
         va_list varArgs;
+        mPropertyName = AdjustRdbmsName(mPropertyName);
         // Handle random list of property data:
         va_start (varArgs, property_auto);
@@ -132,7 +151,7 @@
     static FdoExpression* ParseByDataType(const wchar_t* data, FdoDataType dataType);
     // Check that the given property in the given reader matches the given value:
-    void checkEqual(FdoPtr<FdoIFeatureReader> reader, wchar_t* propertyName, FdoDataType propertyType, const wchar_t* propertyData);
+    void checkEqual(FdoPtr<FdoIFeatureReader> reader, FdoString* propertyName, FdoDataType propertyType, FdoString* propertyData);
     // add the given class to the default schema
     static void CreateSchema (FdoIConnection* connection, UnitTestClass* cls);
@@ -528,7 +547,7 @@
 #define DECLARE_CLASS(DBMETHODNAME, USERMETHODNAME, CLASSMETHODNAME, REALCLASSNAME) \
 static FdoStringP ClassSchema##CLASSMETHODNAME() { return FdoStringP::Format(L"%ls%ls", (FdoString*)FdoSchemaPrefix##DBMETHODNAME(), (FdoString*)UserName##USERMETHODNAME()); } \
-static FdoStringP ClassName##CLASSMETHODNAME()  { return REALCLASSNAME; } \
+static FdoStringP ClassName##CLASSMETHODNAME()  { return AdjustRdbmsName(REALCLASSNAME); } \
 static FdoStringP QClassName##CLASSMETHODNAME() { return FdoStringP::Format(L"%ls:%ls", (FdoString*)ClassSchema##CLASSMETHODNAME(), (FdoString*)ClassName##CLASSMETHODNAME()); }
     DECLARE_CLASS(Sde, Metadcov, TestClassSimple, L"TESTA");
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicInsertTests.cpp	2007-01-26 12:32:08 UTC (rev 118)
@@ -890,6 +890,8 @@
 /* Test default values and read-only properties in insert operation. */
 void BasicInsertTests::defaults_insert ()
+// This test relies on metadata created by ApplySchema which is only available in Debug mode, so skip this test if not running in debug mode
+#ifdef _DEBUG
     if (CreateSchemaOnly())  return;
     try
@@ -909,7 +911,7 @@
             expression = (FdoValueExpression*)ArcSDETests::ParseByDataType (L"'Inserted String 1'", FdoDataType_String);
-            value = FdoPropertyValue::Create(L"StringWithDefault1", expression);
+            value = FdoPropertyValue::Create(AdjustRdbmsName(L"StringWithDefault1"), expression);
             values->Add(value);
         FdoPtr<FdoIFeatureReader> reader = insert->Execute ();
@@ -920,9 +922,9 @@
         selectCmd->SetFeatureClassName (ArcSDETestConfig::QClassNameTestClassNew());
         reader = selectCmd->Execute ();
         CPPUNIT_ASSERT_MESSAGE("Failed to read 1st inserted row", reader->ReadNext());
-        checkEqual(reader, L"ReadOnlyInt", FdoDataType_Int32, L"255");
-        checkEqual(reader, L"StringWithDefault1", FdoDataType_String, L"'Inserted String 1'");
-        checkEqual(reader, L"StringWithDefault2", FdoDataType_String, L"'Default String 2'");
+        checkEqual(reader, AdjustRdbmsName(L"ReadOnlyInt"), FdoDataType_Int32, L"255");
+        checkEqual(reader, AdjustRdbmsName(L"StringWithDefault1"), FdoDataType_String, L"'Inserted String 1'");
+        checkEqual(reader, AdjustRdbmsName(L"StringWithDefault2"), FdoDataType_String, L"'Default String 2'");
         CPPUNIT_ASSERT_MESSAGE("Shouldn't be anymore rows", !reader->ReadNext());
         reader->Close ();
@@ -936,7 +938,7 @@
             expression = (FdoValueExpression*)ArcSDETests::ParseByDataType (L"123", FdoDataType_Int32);
-            value = FdoPropertyValue::Create(L"ReadOnlyInt", expression);
+            value = FdoPropertyValue::Create(AdjustRdbmsName(L"ReadOnlyInt"), expression);
             values->Add(value);
         try
@@ -956,6 +958,7 @@
         fail (ge);
+#endif
@@ -1090,7 +1093,7 @@
             FdoPtr<FdoIGeometry> aGeometry = collection->GetItem(i);
             FdoPtr<FdoByteArray> byteArray = gf->GetFgf(aGeometry);
             FdoPtr<FdoGeometryValue> geomExpression = FdoGeometryValue::Create(byteArray);
-            FdoPtr<FdoPropertyValue> value = FdoPropertyValue::Create (L"MyGeometry", geomExpression);
+            FdoPtr<FdoPropertyValue> value = FdoPropertyValue::Create (AdjustRdbmsName(L"MyGeometry"), geomExpression);
             values->Add (value);
             // none returned: reader->Close ();
@@ -1100,7 +1103,7 @@
             selectCmd->SetFeatureClassName (ArcSDETestConfig::QClassNameTestClassGeomZm3());
             CPPUNIT_ASSERT_MESSAGE("Should have retrieved 1 row, got 0 rows", reader->ReadNext());
-            FdoPtr<FdoByteArray> fetched = reader->GetGeometry (L"MyGeometry");
+            FdoPtr<FdoByteArray> fetched = reader->GetGeometry (AdjustRdbmsName(L"MyGeometry"));
             FdoPtr<FdoByteArray> reference = geomExpression->GetGeometry ();
             FdoPtr<FdoIGeometry> fetchedGeom = gf->CreateGeometryFromFgf(fetched);
             FdoPtr<FdoIGeometry> referenceGeom = gf->CreateGeometryFromFgf(reference);
@@ -1188,7 +1191,7 @@
             propValues->Add (propVal);
             FdoPtr<FdoExpression> valueExpr1 = FdoExpression::Parse(geom1);
             FdoGeometryValue* geomVal1 = dynamic_cast<FdoGeometryValue*>(valueExpr1.p);
-            propVal = FdoPropertyValue::Create (L"MyGeometry", geomVal1);
+            propVal = FdoPropertyValue::Create (AdjustRdbmsName(L"MyGeometry"), geomVal1);
             reader = insert->Execute();
             CPPUNIT_ASSERT_MESSAGE("Expected to receive one id from FdoIInsert::Execute(), got none.", reader->ReadNext());
@@ -1204,7 +1207,7 @@
             propVal = propValues->GetItem(Data[5]->mPropertyName);
             FdoPtr<FdoInt32Value> intValId2 = FdoInt32Value::Create(int2);
             propVal->SetValue(intValId2);
-            propVal = propValues->GetItem(L"MyGeometry");
+            propVal = propValues->GetItem(AdjustRdbmsName(L"MyGeometry"));
             FdoPtr<FdoExpression> valueExpr2 = FdoExpression::Parse(geom2);
             FdoGeometryValue* geomVal2 = dynamic_cast<FdoGeometryValue*>(valueExpr2.p);
             propVal->SetValue(geomVal2);
@@ -1223,7 +1226,7 @@
             FdoPtr<FdoInt32Value> intValId3 = FdoInt32Value::Create(int2);
             propVal->SetValue(intValId3);
             FdoPtr<FdoExpression> valueExpr3 = FdoExpression::Parse(geom2);
             FdoGeometryValue* geomVal3 = dynamic_cast<FdoGeometryValue*>(valueExpr3.p);
             propVal->SetValue(geomVal3);
@@ -1435,7 +1438,7 @@
         selectCmd->SetFeatureClassName (ArcSDETestConfig::QClassNameTestClassNullable());
-        checkEqual(reader, L"String1", FdoDataType_String, L"NULL");
+        checkEqual(reader, AdjustRdbmsName(L"String1"), FdoDataType_String, L"NULL");
         reader->Close ();
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicUpdateTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicUpdateTests.cpp	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/BasicUpdateTests.cpp	2007-01-26 12:32:08 UTC (rev 118)
@@ -489,21 +489,21 @@
         insert->SetFeatureClassName (ArcSDETestConfig::QClassNameSample());
         FdoPtr<FdoPropertyValueCollection> values = insert->GetPropertyValues ();
         FdoPtr<FdoStringValue> expression = FdoStringValue::Create (L"Zozo");
-        FdoPtr<FdoPropertyValue> value = FdoPropertyValue::Create (L"LockProperty", expression);
+        FdoPtr<FdoPropertyValue> value = FdoPropertyValue::Create (AdjustRdbmsName(L"LockProperty"), expression);
         FdoInt32 newId = 0;
         if (reader->ReadNext())
-            newId = reader->GetInt32(L"Id");
+            newId = reader->GetInt32(AdjustRdbmsName(L"Id"));
         FdoPtr<FdoIUpdate> update = (FdoIUpdate*)mConnection->CreateCommand (FdoCommandType_Update);
         update->SetFeatureClassName (ArcSDETestConfig::QClassNameSample());
         wchar_t filter[1024];
-        FdoCommonOSUtil::swprintf(filter, ELEMENTS(filter), L"Id = %d", newId);
+        FdoCommonOSUtil::swprintf(filter, ELEMENTS(filter), L"%ls = %d", AdjustRdbmsName(L"Id"), newId);
         update->SetFilter (FdoPtr<FdoFilter>(FdoFilter::Parse (filter)));
 	    values = update->GetPropertyValues ();
 	    value = FdoPropertyValue::Create ();
-        value->SetName (L"LockProperty");
+        value->SetName (AdjustRdbmsName(L"LockProperty"));
 		value->SetValue (L"'All mimsy were the borogoves'");
         if (1 != update->Execute ())
@@ -515,7 +515,7 @@
         reader = select->Execute ();
         while (reader->ReadNext ())
-            CPPUNIT_ASSERT_MESSAGE ("incorrect value", 0 == wcscmp (L"All mimsy were the borogoves", reader->GetString (L"LockProperty")));
+            CPPUNIT_ASSERT_MESSAGE ("incorrect value", 0 == wcscmp (L"All mimsy were the borogoves", reader->GetString (AdjustRdbmsName(L"LockProperty"))));
         reader->Close();
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/RecommitTest.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/RecommitTest.cpp	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/RecommitTest.cpp	2007-01-26 12:32:08 UTC (rev 118)
@@ -240,7 +240,7 @@
     values->Add (area);
     reader->ReadNext();
-    iCityId1 = reader->GetInt32(L"Id");
+    iCityId1 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
     males->SetValue (L"254000");
@@ -248,7 +248,7 @@
     area->SetValue (L"'VANCOUVER, BC'");
     reader->ReadNext();
-    iCityId2 = reader->GetInt32(L"Id");
+    iCityId2 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
     insert->SetFeatureClassName (ArcSDETestConfig::QClassNameBeach());
@@ -263,14 +263,14 @@
     values->Add (county);
     reader->ReadNext();
-    iBeachId1 = reader->GetInt32(L"Id");
+    iBeachId1 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
     owner->SetValue (L"'LOFT PROPERTIES'");
     county->SetValue (L"'OO'");
     reader->ReadNext();
-    iBeachId2 = reader->GetInt32(L"Id");
+    iBeachId2 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
     transaction->Commit ();
@@ -394,7 +394,7 @@
     bool found = false;
-        if (iCityId2 == reader->GetInt32 (L"Id"))
+        if (iCityId2 == reader->GetInt32 (AdjustRdbmsName(L"Id")))
             CPPUNIT_ASSERT_MESSAGE ("LT1 edit missing", 0 == wcscmp (L"CALGARY, ALBERTA" , reader->GetString (L"AREANAME")));
             found = true;
@@ -408,11 +408,11 @@
     bool found4 = false;
-        if (iBeachId1 == reader->GetInt32 (L"Id"))
+        if (iBeachId1 == reader->GetInt32 (AdjustRdbmsName(L"Id")))
             CPPUNIT_FAIL ("child didn't win the delete");
-        else if (iBeachId3 == reader->GetInt32 (L"Id"))
+        else if (iBeachId3 == reader->GetInt32 (AdjustRdbmsName(L"Id")))
             found3 = true;
-        else if (iBeachId4 == reader->GetInt32 (L"Id"))
+        else if (iBeachId4 == reader->GetInt32 (AdjustRdbmsName(L"Id")))
             found4 = true;
     CPPUNIT_ASSERT_MESSAGE ("LT1 feature not found", found3);
@@ -554,7 +554,7 @@
 	properties->Add (value);
     reader->ReadNext();
-    iBeachId4 = reader->GetInt32(L"Id");
+    iBeachId4 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
     transaction->Commit();
@@ -609,7 +609,7 @@
     reader->ReadNext();
-    iBeachId3 = reader->GetInt32(L"Id");
+    iBeachId3 = reader->GetInt32(AdjustRdbmsName(L"Id"));
     reader->Close();
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp	2007-01-26 00:29:28 UTC (rev 117)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ThreadingTests.cpp	2007-01-26 12:32:08 UTC (rev 118)
@@ -325,10 +325,6 @@
 /* Test running a couple of threads */
 void ThreadingTests::a_few_threads ()
-#ifdef _WIN32
-    CPPUNIT_FAIL("ThreadingTests::a_few_threads disabled");
-#endif
     FdoPtr <FdoIConnection> connection;
     FDOCOMMON_THREAD_HANDLE* handles;
     bool success;
More information about the fdo-commits mailing list
