[fdo-commits] r197 - trunk/Providers/SDF/Src/Provider
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 29 12:47:33 EST 2007
Author: badreddinekaroui
Date: 2007-01-29 12:47:32 -0500 (Mon, 29 Jan 2007)
New Revision: 197
   trunk/Providers/SDF/Src/Provider/SdfConnection.cpp
   trunk/Providers/SDF/Src/Provider/SdfConnection.h
   trunk/Providers/SDF/Src/Provider/SdfConnectionCapabilities.cpp
   trunk/Providers/SDF/Src/Provider/SdfIndexedScrollableFeatureReader.cpp
   trunk/Providers/SDF/Src/Provider/SdfInsert.cpp
   trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp
Merge the SDF provider changes 181 and 158 from branch 3.2.x to the trunk
Modified: trunk/Providers/SDF/Src/Provider/SdfConnection.cpp
--- trunk/Providers/SDF/Src/Provider/SdfConnection.cpp	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfConnection.cpp	2007-01-29 17:47:32 UTC (rev 197)
@@ -678,6 +678,10 @@
 //close feature data databases
 void SdfConnection::DestroyDatabases()
+    // Make sure that all updates are committed in an orderly fashion; one class at a time
+    // an with a proper low level transaction.
+    Flush();
     //iterate over hashmap and close Data databases here..
     //stdext::hash_map<FdoClassDefinition*, DataDb*>::iterator dblist;
     stdext::hash_map<void*, void*>::iterator dblist;
@@ -759,39 +763,20 @@
     m_hPropertyIndices.clear();
-void SdfConnection::ReSyncData()
+void SdfConnection::ReSyncData(FdoClassDefinition *clas)
-    stdext::hash_map<void*, void*>::iterator dblist;
-    for (dblist = m_hDataDbs.begin(); dblist != m_hDataDbs.end(); dblist++)
-        //only synch the ids for every base class
-        //child classes share the same db
-        FdoPtr<FdoClassDefinition> base = ((FdoClassDefinition*)dblist->first)->GetBaseClass();
-        if (base == NULL)
-            if (dblist->second != NULL)
-                ((DataDb*)dblist->second)->SyncIdPool();
+    DataDb  *dataDb = GetDataDb(clas);
+    SdfRTree* rt = GetRTree(clas);
-    stdext::hash_map<void*, void*>::iterator treelist;
-    for (treelist = m_hRTrees.begin(); treelist != m_hRTrees.end(); treelist++)
-        //Need to re-read the root node in case it was updated by a different connection.
-        FdoPtr<FdoClassDefinition> base = ((FdoClassDefinition*)treelist->first)->GetBaseClass();
-        if (base == NULL)
-            if (treelist->second != NULL)
-                ((SdfRTree*)treelist->second)->UpdateRootNode();
+    if( dataDb )
+        dataDb->SyncIdPool();
+    if( rt )
+        rt->UpdateRootNode();
 void SdfConnection::RegenIndex( FdoClassDefinition *clas, KeyDb* keys, DataDb  *dataDb )
     int ret = SQLiteDB_ERROR;
@@ -874,7 +859,7 @@
     // the database since the user is only reading this database.
     if( keys && forUpdate && keys->IndexNeedsRegen() )
         RegenIndex( clas, keys, dataDb );
         keys->Flush();
         keys->Regened();
@@ -991,36 +976,7 @@
         if (base == NULL)
-                ((DataDb*)dblist->second)->Flush();
+            FlushAll( (FdoClassDefinition*)dblist->first, true );
-    stdext::hash_map<void*, void*>::iterator keylist;
-    for (keylist = m_hKeyDbs.begin(); keylist != m_hKeyDbs.end(); keylist++)
-        FdoPtr<FdoClassDefinition> base = ((FdoClassDefinition*)keylist->first)->GetBaseClass();
-        if (base == NULL)
-            if (keylist->second != NULL)
-                ((KeyDb*)keylist->second)->Flush();
-        if (base == NULL)
-                ((SdfRTree*)treelist->second)->Flush();
Modified: trunk/Providers/SDF/Src/Provider/SdfConnection.h
--- trunk/Providers/SDF/Src/Provider/SdfConnection.h	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfConnection.h	2007-01-29 17:47:32 UTC (rev 197)
@@ -173,7 +173,7 @@
     // Used to re-sync with the data on disk. This is needed if 2 or more connections are writting to the same file
     // Before a new connection writes to the file it needs to re-synch with the id pool. Otherwise the ids may overlap
     // with the existing ids.
-    void ReSyncData();
+    void ReSyncData(FdoClassDefinition *clas);
     FdoConnectionState Open( SdfCompareHandler* cmpHandler );
Modified: trunk/Providers/SDF/Src/Provider/SdfConnectionCapabilities.cpp
--- trunk/Providers/SDF/Src/Provider/SdfConnectionCapabilities.cpp	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfConnectionCapabilities.cpp	2007-01-29 17:47:32 UTC (rev 197)
@@ -56,7 +56,7 @@
 // level of thread safety.
 FdoThreadCapability SdfConnectionCapabilities::GetThreadCapability()
-    return FdoThreadCapability_PerCommandThreaded;
+    return FdoThreadCapability_PerConnectionThreaded;
Modified: trunk/Providers/SDF/Src/Provider/SdfIndexedScrollableFeatureReader.cpp
--- trunk/Providers/SDF/Src/Provider/SdfIndexedScrollableFeatureReader.cpp	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfIndexedScrollableFeatureReader.cpp	2007-01-29 17:47:32 UTC (rev 197)
@@ -64,6 +64,7 @@
 	m_dataReader->Reset((unsigned char*)m_currentData->get_data(), m_currentData->get_size());
 	m_currentFeatureRecno = *(REC_NO*)(m_currentKey->get_data());
+    m_Sourcedata->SetTag((void*)this);
 	if (!m_stringPropsCache.empty())
Modified: trunk/Providers/SDF/Src/Provider/SdfInsert.cpp
--- trunk/Providers/SDF/Src/Provider/SdfInsert.cpp	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfInsert.cpp	2007-01-29 17:47:32 UTC (rev 197)
@@ -180,7 +180,7 @@
 		m_connection->FlushAll( clas, true );
 		// Re-synch with the on-disk id pool
-		m_connection->ReSyncData();
+		m_connection->ReSyncData(clas);
 		m_NeedSync = false;
@@ -271,7 +271,7 @@
 						rt->Insert(bounds, 0, rtkey);
Modified: trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp
--- trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp	2007-01-26 00:31:36 UTC (rev 196)
+++ trunk/Providers/SDF/Src/Provider/SdfSimpleFeatureReader.cpp	2007-01-29 17:47:32 UTC (rev 197)
@@ -912,6 +912,7 @@
                 throw FdoCommandException::Create(NlsMsgGetMain(FDO_NLSID(SDFPROVIDER_10_ERROR_ACCESSING_SDFDB)));
+            m_dbData->SetTag((void*)this);
             //we can skip the filter if the feature class
             //doesn't match the query base class
@@ -957,6 +958,7 @@
More information about the fdo-commits mailing list
