[fdo-commits] r713 - branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 29 15:35:05 EST 2007
Author: romicadascalescu
Date: 2007-01-29 15:35:04 -0500 (Mon, 29 Jan 2007)
New Revision: 713
   branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/connect.c
   branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/stdafx.h
   branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/xlt_status.c
Fixed MySQL: Raise FDO exception connection is made to an old MySql version (at connection time).
Modified: branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/connect.c
--- branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/connect.c	2007-01-29 20:25:50 UTC (rev 712)
+++ branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/connect.c	2007-01-29 20:35:04 UTC (rev 713)
@@ -57,6 +57,8 @@
     MYSQL *handle;
     int rows_processed;
     int ret;
+    unsigned long server_client_version = 0;
+    const wchar_t* server_client_msg = NULL;
     ret = mysql_xlt_status(context, MYSQL_SUCCESS, (MYSQL*) NULL, (MYSQL_STMT*) NULL);
@@ -123,32 +125,49 @@
                     else
-						if (context->mysql_current_connect == -1)
-							context->mysql_connect_count++;
-							context->mysql_current_connect = index;
-							context->mysql_connections[index] = handle;
+                        server_client_version = mysql_get_client_version();
+                        if ( server_client_version < MIN_CLIENT_VER )
+                            server_client_msg = mysql_nls_client_version( server_client_version );
+                        server_client_version = mysql_get_server_version( handle );
+                        if ( server_client_version < MIN_SERVER_VER )
+                            server_client_msg = mysql_nls_server_version( server_client_version );
-							*connect_id = index;
-                            // The following allows RDBMS object names to be double quote
-                            // delimited in SQL statements, thus allowing queries on tables
-                            // and columns with special characters in their names.
-                            ret = mysql_run_sql( context, "set sql_mode='ANSI_QUOTES'", false, &rows_processed );
-                            if ( ret == 0 )
-                                ret = set_characterset( context, false );
-						else if (context->mysql_current_connect2 == -1)
-							context->mysql_current_connect2 = index;
-                            // See note 10 lines above.
-                            ret = mysql_run_sql( context, "set sql_mode='ANSI_QUOTES'", true, &rows_processed );
-                            if ( ret == 0 )
-                                ret = set_characterset( context, true );
-							break;
+                        if ( server_client_msg != NULL)
+                            swprintf(context->mysql_last_err_msg, RDBI_MSG_SIZE, L"%ls", server_client_msg);
+                            mysql_close (handle);
+                            context->mysql_last_err_msg[RDBI_MSG_SIZE - 1] = 0;
+                            ret = RDBI_GENERIC_ERROR;
+                        else
+						    if (context->mysql_current_connect == -1)
+							    context->mysql_connect_count++;
+							    context->mysql_current_connect = index;
+							    context->mysql_connections[index] = handle;
+							    *connect_id = index;
+                                // The following allows RDBMS object names to be double quote
+                                // delimited in SQL statements, thus allowing queries on tables
+                                // and columns with special characters in their names.
+                                ret = mysql_run_sql( context, "set sql_mode='ANSI_QUOTES'", false, &rows_processed );
+                                if ( ret == 0 )
+                                    ret = set_characterset( context, false );
+						    else if (context->mysql_current_connect2 == -1)
+							    context->mysql_current_connect2 = index;
+                                // See note 10 lines above.
+                                ret = mysql_run_sql( context, "set sql_mode='ANSI_QUOTES'", true, &rows_processed );
+                                if ( ret == 0 )
+                                    ret = set_characterset( context, true );
+							    break;
Modified: branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/stdafx.h
--- branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/stdafx.h	2007-01-29 20:25:50 UTC (rev 712)
+++ branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/stdafx.h	2007-01-29 20:35:04 UTC (rev 713)
@@ -45,3 +45,8 @@
 // Helper macro that determines the number of elements in a statically-sized array
 // (this doesn't work for dynamically-sized arrays)
 #define ELEMENTS(x) (sizeof(x)/sizeof(x[0]))
+// defines minimum client version accepted
+#define MIN_CLIENT_VER 50000
+// defines minimum server version accepted
+#define MIN_SERVER_VER 50022
Modified: branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/xlt_status.c
--- branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/xlt_status.c	2007-01-29 20:25:50 UTC (rev 712)
+++ branches/3.2.x/Providers/GenericRdbms/Src/MySQL/Driver/xlt_status.c	2007-01-29 20:35:04 UTC (rev 713)
@@ -142,7 +142,7 @@
     // cryptic. Therefore, prepend more explanatory info when one of the other
     // is too old to work with the MySQL Provider.
-    if ( client_version < 50000 ) {
+    if ( client_version < MIN_CLIENT_VER ) {
         // Pre-version 5 clients can't handle some version 5 data types used in the
         // information_schema, so MySQL provider can't work with them.
         const wchar_t* client_msg = mysql_nls_client_version( client_version );
@@ -152,7 +152,7 @@
     if ( mysql ) {
         unsigned long server_version = mysql_get_server_version( mysql );
-        if ( server_version < 50022 ) {
+        if ( server_version < MIN_SERVER_VER ) {
             // Also, various errors can occur when database has too old a version.
             const wchar_t* server_msg = mysql_nls_server_version( server_version );
             cat_msg( err_msg, server_msg, err_msg_left );
More information about the fdo-commits mailing list
