[fdo-commits] r116 - in branches/3.2.x/Providers/WMS/Src: Overrides Provider UnitTest
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Jan 30 18:04:06 EST 2007
Author: romicadascalescu
Date: 2007-01-30 18:04:06 -0500 (Tue, 30 Jan 2007)
New Revision: 116
Added:
   branches/3.2.x/Providers/WMS/Src/UnitTest/WMSOverrideClass3.xml
   branches/3.2.x/Providers/WMS/Src/Overrides/FdoWmsOvRasterDefinition.cpp
   branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsBoundingBox.cpp
   branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsConnection.cpp
   branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsLayer.cpp
   branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.cpp
   branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.h
   branches/3.2.x/Providers/WMS/Src/UnitTest/UnitTest.vcproj
   branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.cpp
   branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.h
Fixed WMS externalizes invalid SRS (lowercase values)
Modified: branches/3.2.x/Providers/WMS/Src/Overrides/FdoWmsOvRasterDefinition.cpp
--- branches/3.2.x/Providers/WMS/Src/Overrides/FdoWmsOvRasterDefinition.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/Overrides/FdoWmsOvRasterDefinition.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -102,6 +102,7 @@
 void FdoWmsOvRasterDefinition::SetSpatialContextName(FdoString* value)
     m_spatialContext = value;
+    m_spatialContext = m_spatialContext.Upper();
 FdoWmsOvLayerCollection* FdoWmsOvRasterDefinition::GetLayers(void) const
Modified: branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsBoundingBox.cpp
--- branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsBoundingBox.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsBoundingBox.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -175,4 +175,5 @@
 void FdoWmsBoundingBox::SetCRS(FdoString* value)
     mCRS = value;
+    mCRS = mCRS.Upper();
Modified: branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsConnection.cpp
--- branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsConnection.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsConnection.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -540,6 +540,7 @@
 void FdoWmsConnection::SetActiveSpatialContext (FdoString* value)
 	mActiveSpatialContext = value;
+    mActiveSpatialContext = mActiveSpatialContext.Upper();
 /// <summary>Get the active spatial context.</summary>
Modified: branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsLayer.cpp
--- branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsLayer.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/Provider/FdoWmsLayer.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -231,7 +231,8 @@
                      FdoCommonOSUtil::wcsicmp(name, FdoWmsXmlGlobals::WmsCapabilitiesCRS) == 0)
                 FdoStringsP layerCoordSystems = GetCoordinateReferenceSystems();
-                FdoStringsP coordSystems = FdoStringCollection::Create(mXmlContentHandler->GetString(), FdoWmsXmlGlobals::WmsCapabilitiesSRSDelimiter);
+                FdoStringP SRSList = mXmlContentHandler->GetString();
+                FdoStringsP coordSystems = FdoStringCollection::Create(SRSList.Upper(), FdoWmsXmlGlobals::WmsCapabilitiesSRSDelimiter);
                 layerCoordSystems += coordSystems;
Modified: branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.cpp
--- branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -697,3 +697,96 @@
         fail(ex);
+// configuration file contains an invalid SRS (lowercase name)
+// an exception will be thrown if we don't handle it
+void OverridesTest::TestSetConfiguration4()
+    try
+        FdoPtr<FdoIConnection> connection = WmsTests::GetConnection();
+        if (connection == NULL) {
+            CPPUNIT_FAIL("FAILED - CreateConnection returned NULL\n");
+        connection->SetConnectionString(L"FeatureServer=http://wms.jpl.nasa.gov/wms.cgi");
+        FdoIoFileStreamP fileStream = FdoIoFileStream::Create(L"WMSOverrideClass3.xml", L"r");
+        connection->SetConfiguration(fileStream);
+        connection->Open();
+        FdoPtr<FdoIDescribeSchema> cmd =
+            static_cast<FdoIDescribeSchema *> (connection->CreateCommand (FdoCommandType_DescribeSchema));
+        FdoPtr<FdoFeatureSchemaCollection> schemas = cmd->Execute ();
+        FdoInt32 cntSchemas = schemas->GetCount ();
+        for (FdoInt32 i=0; i<cntSchemas; i++)
+            FdoPtr<FdoFeatureSchema> schema = schemas->GetItem (i);
+            FdoStringP schemaName = schema->GetName();
+#ifdef _DEBUG
+            wprintf (L"    Schema: %ls\n", (FdoString *) schemaName);
+#endif
+            FdoPtr<FdoClassCollection> classes = schema->GetClasses ();
+            FdoInt32 cntClasses = classes->GetCount();
+            for (FdoInt32 j=0; j<cntSchemas; j++)
+                FdoPtr<FdoClassDefinition> clsDef = classes->GetItem(j);
+                FdoStringP className = clsDef->GetName();
+#ifdef _DEBUG
+                wprintf (L"    Class: %ls\n", (FdoString *) className);
+#endif
+                FdoPtr<FdoPropertyDefinitionCollection> props = clsDef->GetProperties ();
+                FdoInt32 cntProps = props->GetCount();
+                for (FdoInt32 i=0; i<cntProps; i++)
+                    FdoPtr<FdoPropertyDefinition> prop = props->GetItem (i);
+                    FdoStringP propName = prop->GetName ();
+#ifdef _DEBUG
+                    wprintf (L"        Property: %ls\n", (FdoString *) propName);
+#endif
+                FdoPtr<FdoISelect> cmdSelect =
+                    static_cast<FdoISelect *> (connection->CreateCommand (FdoCommandType_Select));
+                cmdSelect->SetFeatureClassName (clsDef->GetName ());
+                FdoPtr<FdoIFeatureReader> featReader = cmdSelect->Execute ();
+                while (featReader->ReadNext ())
+#ifdef _DEBUG
+                    wprintf (L"            Id: %ls\n", featReader->GetString (L"Id"));
+#endif
+                    FdoPtr<FdoIRaster> raster = featReader->GetRaster (L"Image");
+                    FdoInt32 xSize = raster->GetImageXSize ();
+                    FdoInt32 ySize = raster->GetImageYSize ();
+                    FdoPtr<FdoIStreamReader> streamReader = raster->GetStreamReader ();
+                    CPPUNIT_ASSERT (streamReader != NULL);
+                    FdoIStreamReaderTmpl<FdoByte> * byteStreamReader =
+                        static_cast<FdoIStreamReaderTmpl<FdoByte>*> (streamReader.p);
+                    FdoByte buff[4096];
+                    FdoInt64 cntTotal = 0;
+                    FdoInt32 cntRead = 0;
+                    do
+                        cntRead = byteStreamReader->ReadNext (buff, 0 , 4096);
+                        cntTotal += cntRead;
+                    while (cntRead);
+        connection->Close();
+	catch (FdoException* e)
+        fail (e);
Modified: branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.h
--- branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.h	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/OverridesTest.h	2007-01-30 23:04:06 UTC (rev 116)
@@ -35,6 +35,7 @@
   CPPUNIT_TEST( TestSetConfiguration2);
 #endif
   CPPUNIT_TEST( TestSetConfiguration3);
+  CPPUNIT_TEST( TestSetConfiguration4);
   CPPUNIT_TEST( TestNoDefaultDataModel );
   CPPUNIT_TEST( TestQualifiedName );
   CPPUNIT_TEST_SUITE_END();
@@ -49,6 +50,7 @@
     void TestSetConfiguration();
 	void TestSetConfiguration2();
     void TestSetConfiguration3();
+    void TestSetConfiguration4();
     void TestNoDefaultDataModel();
     void TestQualifiedName();
Modified: branches/3.2.x/Providers/WMS/Src/UnitTest/UnitTest.vcproj
--- branches/3.2.x/Providers/WMS/Src/UnitTest/UnitTest.vcproj	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/UnitTest.vcproj	2007-01-30 23:04:06 UTC (rev 116)
@@ -736,8 +736,8 @@
 					<Tool
 						Name="VCCustomBuildTool"
 						Description="Performing fake install"
-						CommandLine="copy providers.xml $(OutDir)&#x0D;&#x0A;copy WmsOverridesConfig.xml $(OutDir)&#x0D;&#x0A;copy WmsSchemaConfig.xml $(OutDir)&#x0D;&#x0A;copy WmsSchemaConfig_Jake_MapServer.xml $(OutDir)&#x0D;&#x0A;copy NASA_WMS_Config.xml $(OutDir)&#x0D;&#x0A;copy WMSOverrideClass2.xml $(OutDir)&#x0D;&#x0A;copy CubeServer_WMS_Config.xml $(OutDir)&#x0D;&#x0A;copy MultiLayers_Config.xml $(OutDir)&#x0D;&#x0A;"
-						AdditionalDependencies="providers.xml;WmsOverridesConfig.xml;WmsSchemaConfig.xml;WmsSchemaConfig_Jake_MapServer.xml;NASA_WMS_Config.xml;WMSOverrideClass2.xml;CubeServer_WMS_Config.xml;MultiLayers_Config.xml"
+						CommandLine="copy providers.xml $(OutDir)&#x0D;&#x0A;copy WmsOverridesConfig.xml $(OutDir)&#x0D;&#x0A;copy WmsSchemaConfig.xml $(OutDir)&#x0D;&#x0A;copy WmsSchemaConfig_Jake_MapServer.xml $(OutDir)&#x0D;&#x0A;copy NASA_WMS_Config.xml $(OutDir)&#x0D;&#x0A;copy WMSOverrideClass2.xml $(OutDir)&#x0D;&#x0A;copy WMSOverrideClass3.xml $(OutDir)&#x0D;&#x0A;copy CubeServer_WMS_Config.xml $(OutDir)&#x0D;&#x0A;copy MultiLayers_Config.xml $(OutDir)&#x0D;&#x0A;"
+						AdditionalDependencies="providers.xml;WmsOverridesConfig.xml;WmsSchemaConfig.xml;WmsSchemaConfig_Jake_MapServer.xml;NASA_WMS_Config.xml;WMSOverrideClass2.xml;WMSOverrideClass3.xml;CubeServer_WMS_Config.xml;MultiLayers_Config.xml"
 						Outputs="$(OutDir)\providers.xml"
 				</FileConfiguration>
@@ -747,8 +747,8 @@
 					<Tool
@@ -758,8 +758,8 @@
 					<Tool
@@ -769,8 +769,8 @@
 					<Tool
Added: branches/3.2.x/Providers/WMS/Src/UnitTest/WMSOverrideClass3.xml
--- branches/3.2.x/Providers/WMS/Src/UnitTest/WMSOverrideClass3.xml	                        (rev 0)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/WMSOverrideClass3.xml	2007-01-30 23:04:06 UTC (rev 116)
@@ -0,0 +1,42 @@
+<?xml version="1.0" encoding="UTF-8" ?><fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:fds="http://fdo.osgeo.org/schemas/fds">
+  <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/WMSLayers" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:WMSLayers="http://fdo.osgeo.org/schemas/feature/WMSLayers" elementFormDefault="qualified" attributeFormDefault="unqualified">
+    <xs:element name="us_landsat_wgs84_1" type="WMSLayers:us_landsat_wgs84_1Type" abstract="false" substitutionGroup="gml:_Feature">
+      <xs:key name="us_landsat_wgs84_1Key">
+        <xs:selector xpath=".//us_landsat_wgs84_1"/>
+        <xs:field xpath="Id"/>
+      </xs:key>
+    </xs:element>
+    <xs:complexType name="us_landsat_wgs84_1Type" abstract="false" fdo:hasGeometry="false">
+      <xs:complexContent>
+        <xs:extension base="gml:AbstractFeatureType">
+          <xs:sequence>
+            <xs:element name="Id">
+              <xs:annotation>
+                <xs:documentation/>
+              </xs:annotation>
+              <xs:simpleType>
+                <xs:restriction base="xs:string">
+                  <xs:maxLength value="256"/>
+                </xs:restriction>
+              </xs:simpleType>
+            </xs:element>
+            <xs:element name="Image" type="fdo:RasterPropertyType" fdo:defaultImageXSize="1024" fdo:defaultImageYSize="1024"/>
+          </xs:sequence>
+        </xs:extension>
+      </xs:complexContent>
+    </xs:complexType>
+  </xs:schema>
+  <SchemaMapping provider="OSGeo.WMS.3.2" name="WMSLayers" xmlns="http://fdowms.osgeo.org/schemas">
+    <complexType name="us_landsat_wgs84_1Type">
+      <RasterDefinition name="Image">
+        <Format>PNG</Format>
+        <Transparent>false</Transparent>
+        <BackgroundColor></BackgroundColor>
+        <Time></Time>
+        <Elevation></Elevation>
+        <SpatialContext>epsg:4326</SpatialContext>
+        <Layer name="us_landsat_wgs84"/>
+      </RasterDefinition>
+    </complexType>
+  </SchemaMapping>
+</fdo:DataStore>
Modified: branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.cpp
--- branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.cpp	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.cpp	2007-01-30 23:04:06 UTC (rev 116)
@@ -56,6 +56,18 @@
+void WmsTestSpatialContext::testServer3 ()
+	try
+		testServer (L"http://wms1.ccgis.de/cgi-bin/mapserv?map=/data/umn/germany/germany.map&VERSION=1.1.1", 2);
+        fail(e);
 void WmsTestSpatialContext::testServer (FdoString* featureServer, FdoInt32 cntSpatialContexts)
 	FdoPtr<FdoIConnection> conn = this->GetConnection ();
Modified: branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.h
--- branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.h	2007-01-26 00:30:48 UTC (rev 115)
+++ branches/3.2.x/Providers/WMS/Src/UnitTest/WmsTestSpatialContexts.h	2007-01-30 23:04:06 UTC (rev 116)
@@ -32,6 +32,7 @@
 	CPPUNIT_TEST (testServer1);
 #endif
 	CPPUNIT_TEST (testServer2);
+	CPPUNIT_TEST (testServer3);
 	CPPUNIT_TEST_SUITE_END ();
 public:
@@ -42,6 +43,7 @@
 	void _tearDown () {}
 	void testServer1 ();
 	void testServer2 ();
+	void testServer3 ();
 private:
 	void testServer (FdoString* feaureServer, FdoInt32 cntSpatialContexts);
More information about the fdo-commits mailing list
