[fdo-commits] r695 - in branches/3.2.x/Fdo/Managed/Src/OSGeo/Common: . Gml212 Io Xml Xsl
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Jan 31 18:03:05 EST 2007
Author: gregboone
Date: 2007-01-31 18:03:04 -0500 (Wed, 31 Jan 2007)
New Revision: 695
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/AssemblyVersion.cpp
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Gml212/mgSchema.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/VirtualFdoIoStream.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoByteStreamReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoCharStreamReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoFileStream.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoMemoryStream.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/VirtualSaxHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCharDataHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCopyHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSkipElementHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgException.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/AssemblyVersion.cpp
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/AssemblyVersion.cpp	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/AssemblyVersion.cpp	2007-01-31 23:03:04 UTC (rev 695)
@@ -34,4 +34,4 @@
 // by using the '*' as shown below:
-[assembly:AssemblyVersion("3.2.6108.0")];
+[assembly:AssemblyVersion("3.2.0.0")];
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Gml212/mgSchema.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Gml212/mgSchema.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Gml212/mgSchema.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -35,12 +35,14 @@
     /// an XML document containing the GML 2.1.2 and Xlinks schemas.
     /// \return
-    /// Returns XmlReader
+    /// Returns a new XmlReader
 	static NAMESPACE_OSGEO_COMMON_XML::XmlReader* CreateReader();
+/// \cond DOXYGEN-IGNORE
 private:
 	Schema(){}
+/// \endcond
 END_NAMESPACE_OSGEO_COMMON_GML212
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/VirtualFdoIoStream.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/VirtualFdoIoStream.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/VirtualFdoIoStream.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -22,6 +22,8 @@
 #include "Runtime\ProtocolExt.h"
 #include "Common\Io\mgIoStream.h"
 class VirtualFdoIoStream : public VirtualObject <NAMESPACE_OSGEO_COMMON_IO::IoStream, FdoIoStream>
 public:
@@ -67,4 +69,5 @@
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoByteStreamReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoByteStreamReader.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoByteStreamReader.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -26,16 +26,15 @@
 public __gc class IoStream;
 /// \brief
-///     IoByteStreamReader
+///     IoByteStreamReader is an FDO reader for a Byte stream.
 public __sealed __gc class IoByteStreamReader : public NAMESPACE_OSGEO_COMMON::IStreamReaderImp
 public:
     /// \brief
-    ///     Creates a Byte Stream reader. Reads binary data from
-    ///     an IoStream
+    ///     Creates a Byte Stream reader. Reads binary data from an IoStream
     /// \param stream
-    /// Input the stream to read from
+    ///     Input the stream to read from
 	IoByteStreamReader(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
@@ -43,14 +42,13 @@
     ///     Skips a number of items
     /// \param offset
-    /// Input number of items to skip
+    ///     Input number of items to skip
 	System::Void Skip(System::Int32 offset);
     /// \brief
-    ///     Reset the current index to the stream start. Allows re-reading.
+    ///     Resets the current index to the stream start. Allows re-reading.
 	System::Void Reset();
     /// \brief
@@ -59,23 +57,23 @@
     ///     enough to store data.
     /// \param buffer
-    /// Output array holding data read in.
+    ///     Output array holding data read in.
     /// \param offset
-    /// Input index in the array indicating the beginning of the output buffer.
-    /// If zero, then the buffer is reused. If the end of the buffer, then read in
-    /// appending mode. Throws "out-of-bounds" exception if not in this range.
+    ///     Input index in the array indicating the beginning of the output buffer.
+    ///     If zero, then the buffer is reused. If the end of the buffer, then read in
+    ///     appending mode. Throws "out-of-bounds" exception if not in this range.
     /// \param count
-    /// Input number of items to be read in. If -1 read the entire stream.
-    /// Throws "out-of-bounds"  exception if not a positive value or -1.
+    ///     Input number of items to be read in. If -1 read the entire stream.
+    ///     Throws "out-of-bounds"  exception if not a positive value or -1.
     /// \return
     ///     Returns the number of items actually read in. When 0 (zero) then the
     ///     end-of-stream was reached.
 	System::Int32 ReadNext(System::Byte buffer[]);
 	System::Int32 ReadNext(System::Byte buffer[], System::Int32 offset);
 	System::Int32 ReadNext(System::Byte buffer[], System::Int32 offset, System::Int32 count);
     /// \brief
@@ -96,10 +94,22 @@
 	__property System::Int64 get_Index();
+    /// \brief
+    ///     Constructs a stream reader based on an unmanaged instance of the object
+    /// \param unmanaged
+    ///     Input A Pointer to the unmanaged stream reader.
+    /// \param autoDelete
+    ///     Input Indicates if the constructed object should be automatically deleted
+    ///     once it no longer referenced.
 	IoByteStreamReader(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoIoByteStreamReader* GetImpObj();
+/// \endcond
 END_NAMESPACE_OSGEO_COMMON_IO
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoCharStreamReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoCharStreamReader.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoCharStreamReader.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -27,7 +27,7 @@
 /// \brief
-///     IoCharStreamReader
+///     IoCharStreamReader reads items from a stream of chars.
 public __sealed __gc class IoCharStreamReader : public NAMESPACE_OSGEO_COMMON::IStreamReaderImp
 public:
@@ -35,14 +35,13 @@
     /// \param offset
     /// \brief
     /// \brief
@@ -51,23 +50,23 @@
     /// \param buffer
     /// \param offset
     /// \param count
     /// \return
 	System::Int32 ReadNext(System::Char buffer[]);
 	System::Int32 ReadNext(System::Char buffer[], System::Int32 offset);
 	System::Int32 ReadNext(System::Char buffer[], System::Int32 offset, System::Int32 count);
     /// \brief
@@ -76,7 +75,6 @@
     /// \return
     ///     Returns the size of the data source in number of items
 	__property System::Int64 get_Length();
     /// \brief
@@ -88,10 +86,22 @@
+    /// \brief
 	IoCharStreamReader(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoIStreamReaderTmpl<FdoCharacter>* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoFileStream.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoFileStream.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoFileStream.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -33,17 +33,30 @@
     ///     creates the stream for a named file.
     /// \param fileName
-    /// Input the file name
+    ///     Input the file name
     /// \param accessModes
-    /// Input File access modes. Same as the fopen() C run-time library function
-    /// (mode parameter).
+    ///     Input File access modes. Same as the fopen() C run-time library function
+    ///     (mode parameter).
 	IoFileStream(System::String* fileName, System::String* accessModes);
+    /// \brief
 	IoFileStream(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoIoFileStream* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoMemoryStream.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoMemoryStream.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoMemoryStream.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -38,15 +38,27 @@
     ///     creates the memory stream. The stream manages its own storage.
     /// \param bufferSize
-    /// Input memory allocation increment. Amount of new memory to
-    /// allocated when the stream needs more memory.
+    ///     Input memory allocation increment. Amount of new memory to
+    ///     allocated when the stream needs more memory.
 	IoMemoryStream(System::UInt32 bufferSize);
+    /// \brief
+    ///     Constructs a stream based on an unmanaged instance of the object
+    ///     Input A Pointer to the unmanaged stream.
 	IoMemoryStream(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoIoMemoryStream* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoStream.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -38,16 +38,16 @@
     ///     The stream’s current position is moved ahead by the number of bytes read.
     /// \param buffer
-    /// Output read into this buffer
+    ///     Output read into this buffer
     /// \param count
-    /// Input read this number of bytes into the buffer.
-    /// The caller is responsible for allocating a buffer that is large enough to hold the bytes.
+    ///     Input read this number of bytes into the buffer.
+    ///     The caller is responsible for allocating a buffer that is large enough to hold the bytes.
     /// \return
     ///     Returns the number of bytes that were read. 0 if already at the
     ///     end of the stream.
 	virtual System::UInt32 Read(System::Byte buffer[], System::UInt32 count);
     /// \brief
@@ -60,9 +60,10 @@
     ///     if the current position is not at the end of the stream.
     /// \param buffer
-    /// Intput write from this buffer
+    ///     Intput write from this buffer
     /// \param count
-    /// Input number of bytes to write
+    ///     Input number of bytes to write
 	virtual System::Void Write(System::Byte buffer[], System::UInt32 count);
@@ -70,14 +71,14 @@
     ///     reads the number of bytes from the given stream, and writes them
     ///     to this stream.
-    /// \param buffer
-    /// Input write from this buffer
+    /// \param stream
+    ///     Input write from this buffer
     /// \param count
-    /// Input the maximum number of bytes to read and write.
-    /// When 0, all remaining bytes are read from the given stream.
+    ///     Input the maximum number of bytes to read and write.
+    ///     When 0, all remaining bytes are read from the given stream.
 	virtual System::Void Write(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
 	virtual System::Void Write(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream, System::UInt32 count);
     /// \brief
@@ -88,13 +89,13 @@
     /// \brief
     ///     skips over part of the stream.
-    /// \param offset
-    /// The number of bytes to skip. if position then
-    /// the current position is moved forward. If negative, the position is
-    /// moved backward. The position will remain between the start and end
-    /// of the stream. The position is set to the end of the stream if the
-    /// given offset would put it past the end. Similarily, the position is
-    /// set to the start if the offset would put it before the start.
+    /// \param count
+    ///     The number of bytes to skip. if positive then
+    ///     the current position is moved forward. If negative, the position is
+    ///     moved backward. The position will remain between the start and end
+    ///     of the stream. The position is set to the end of the stream if the
+    ///     given offset would put it past the end. Similarily, if the position is
+    ///     set to the start if the offset would put it before the start.
 	virtual System::Void Skip(System::Int64 count);
@@ -102,9 +103,9 @@
     ///     truncates the stream to the indicated length.
     /// \param length
-    /// Input the new length (in bytes) for the stream. If this is
-    /// longer than the current stream length then the stream's length
-    /// is not changed.
+    ///     Input the new length (in bytes) for the stream. If this is
+    ///     longer than the current stream length then the stream's length
+    ///     is not changed.
 	__property virtual System::Void set_Length(System::Int64 length);
@@ -122,27 +123,25 @@
     /// \return
     ///     Returns the position in bytes from the start. When 0, the
-    ///     the position is at the start of the stream. When GetIndex() ==
-    ///     GetLength() the position is at the end of the stream.
+    ///     the position is at the start of the stream. When Index() ==
+    ///     Length() the position is at the end of the stream.
 	__property virtual System::Int64 get_Index();
     /// \brief
-    ///     gets the reading capability.
+    ///     Gets the reading capability of the stream.
     /// \return
     ///     Returns true if the stream can be read.
     __property virtual System::Boolean get_CanRead();
     /// \brief
-    ///     gets the writing capability.
+    ///     Gets the writing capability of the stream.
     /// \return
     ///     Returns true if the stream can be written to.
 	__property virtual System::Boolean get_CanWrite();
     /// \brief
@@ -158,6 +157,16 @@
 	__property virtual System::Boolean get_HasContext();
+    /// \brief
 	IoStream(System::IntPtr unmanaged, System::Boolean autoDelete);
     /// \brief
@@ -170,6 +179,7 @@
 	System::Void Close();
 protected:
 	IoStream();
@@ -177,6 +187,7 @@
 public private:
 	inline FdoIoStream* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextReader.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -36,7 +36,7 @@
     ///     Constructs a text reader on a file
     /// \param fileName
-    /// Input name of the file to read.
+    ///     Input name of the file to read.
 	IoTextReader(System::String* fileName);
@@ -44,7 +44,7 @@
     ///     Constructs a text reader on a stream
     /// \param stream
-    /// Input the stream to read.
+    ///     Input the stream to read.
 	IoTextReader(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
@@ -60,13 +60,25 @@
 	__property NAMESPACE_OSGEO_COMMON_IO::IoStream* get_Stream();
+    /// \brief
+    ///     Constructs a text reader based on an unmanaged instance of the object
+    ///     Input A Pointer to the unmanaged reader.
 	IoTextReader(System::IntPtr unmanaged, System::Boolean autoDelete);
 protected:
 	System::Void ReleaseUnmanagedObject();
 public private:
 	inline FdoIoTextReader* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Io/mgIoTextWriter.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -35,12 +35,12 @@
     ///     Constructs a text writer on a file.
     /// \param fileName
-    /// Input name of the file to write to. The file is created
-    /// if it does not yet exist. If it already exists, its previous contents are
-    /// completely overwritten.
+    ///     Input name of the file to write to. The file is created
+    ///     if it does not yet exist. If it already exists, its previous contents are
+    ///     completely overwritten.
     /// \return
-    ///     Returns FdoIoTextWriter
+    ///     Returns IoTextWriter
 	IoTextWriter(System::String* fileName);
@@ -49,11 +49,11 @@
     ///     Constructs a text writer on a stream.
     /// \param stream
-    /// Input the stream to write to. Writing starts at the
-    /// stream's current position.
+    ///     Input the stream to write to. Writing starts at the
+    ///     stream's current position.
     /// \return
 	IoTextWriter(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
@@ -74,7 +74,7 @@
     ///     Writes to this text writer. The text is written in UTF8 format.
     /// \param data
-    /// The text to write.
+    ///     The text to write.
 	System::Void Write(System::String* data);
@@ -83,17 +83,29 @@
     ///     the text.
     /// \param data
 	System::Void WriteLine(System::String* data);
+    /// \brief
+    ///     Constructs a text writer based on an unmanaged instance of the object
+    ///     Input A Pointer to the unmanaged writer.
 	IoTextWriter(System::IntPtr unmanaged, System::Boolean autoDelete);
 protected:
 public private:
 	inline FdoIoTextWriter* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/VirtualSaxHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/VirtualSaxHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/VirtualSaxHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -36,6 +36,8 @@
 using namespace NAMESPACE_OSGEO_COMMON_XML;
 class VirtualSaxHandler : public VirtualObject <NAMESPACE_OSGEO_COMMON_XML::XmlSaxHandler, FdoXmlSaxHandler>
 public:
@@ -62,4 +64,4 @@
 	mutable FdoInt32 wrapperCallBits;
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgIXmlSaxHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -89,7 +89,7 @@
     /// \return
     /// Returning true causes the current parse to stop. Returning false
     /// cause the parse to continue. Return value is ignored if the current parse
-    /// is not an incremental parse ( see FdoXmlReader::Parse())
+    /// is not an incremental parse ( see XmlReader::Parse())
 	System::Boolean XmlEndElement(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* resourceLocation, System::String* name, System::String* qualifiedName);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttribute.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -56,7 +56,7 @@
     /// value is not namespace qualified.
     /// \return
-    /// Returns FdoXmlAttribute
+    /// Returns XmlAttribute
 	XmlAttribute(System::String* name, System::String* value, System::String* localName, System::String* attributeURI, System::String* prefix, System::String* valueURI, System::String* localValue, System::String* valuePrefix);
 	XmlAttribute(System::String* name, System::String* value, System::String* localName, System::String* attributeURI, System::String* prefix, System::String* valueURI, System::String* localValue);
@@ -66,8 +66,19 @@
 	XmlAttribute(System::String* name, System::String* value, System::String* localName);
 	XmlAttribute(System::String* name, System::String* value);
+    /// \brief
+    /// Constructs an XmlAttribute based on an unmanaged instance of the object
+    /// Input A Pointer to the unmanaged attribute.
 	XmlAttribute(System::IntPtr unmanaged, System::Boolean autoDelete);
 protected:
 	virtual System::Void ReleaseUnmanagedObject();
@@ -76,6 +87,7 @@
 private:
 	System::Void InitConstruct(String* name, String* value, String* localName, String* uri, String* prefix, String* valueUri, String* localValue, String* valuePrefix);
+/// \endcond
 END_NAMESPACE_OSGEO_COMMON_XML
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlAttributeCollection.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -31,9 +31,10 @@
 [System::Reflection::DefaultMemberAttribute("RealTypeItem")]
 public __sealed __gc class XmlAttributeCollection : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
 private:
     /// \brief
-    /// 		nested class defined to provide Enumerator.
+    /// nested class defined to provide Enumerator.
 	__gc class Enumerator : public System::Collections::IEnumerator
@@ -42,19 +43,52 @@
 		System::Int32 m_nIdx;
 	public:
+        /// \brief
+        ///     Constructs a new Collection Enumerator
+        /// \param elements
+        ///     Input The attribute collection to enumerate.
 		Enumerator(XmlAttributeCollection* elements) : m_pCol(elements), m_nIdx(-1)
+        /// \brief
+        ///     Retrieves the current object at the enumerator location
+        /// \return
+        /// 	Retuns the current object referenced by the enumerator
 		__property System::Object* get_Current();
+        /// \brief
+        ///     Initially, the enumerator is positioned before the first element in the collection.
+        ///     At this position, calling the Current property throws an exception.
+        ///     Therefore, you must call the MoveNext method to advance the enumerator
+        ///     to the first element of the collection before reading the value of Current.
+        //      If MoveNext passes the end of the collection, the enumerator is positioned
+        ///     after the last element in the collection and MoveNext returns false.
+        ///     When the enumerator is at this position, subsequent calls to MoveNext also return false.
+        ///     If the last call to MoveNext returned false, calling Current throws an exception.
+        //      To set Current to the first element of the collection again, you can call Reset
+        ///     followed by MoveNext.
+        /// \return
+        /// 	Retuns true if the Enumerator is able to move to a valid string element
+        ///     otherwise false.
 		System::Boolean MoveNext();
+        /// \brief
+        ///     The Reset method brings the enumerator back to this position.
 public private:
 	inline FdoXmlAttributeCollection* GetImpObj();
 protected:
@@ -84,10 +118,24 @@
 	__property Object* System::Collections::IList::get_Item(System::Int32 index);
 	__property System::Void  System::Collections::IList::set_Item(System::Int32 index, Object* value);
+/// \endcond
 public:
+    /// \brief
+    ///     Constructs a new empty attribute collection
 	XmlAttributeCollection();
+    /// \brief
+    ///     Constructs a collection based on an unmanaged instance of the object
+    ///     Input A Pointer to the unmanaged collection.
 	XmlAttributeCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
     /// \brief
@@ -104,7 +152,7 @@
     ///     Removes the index-th XmlAttribute from this collection.
     /// \param index
-    /// Input index of the element to remove.
+    ///     Input index of the element to remove.
 	System::Void RemoveAt(System::Int32 index);
@@ -117,7 +165,7 @@
     ///     Adds a XmlAttribute object into the collection.
     /// \param value
-    /// Input the XmlAttribute object to add.
+    ///     Input the XmlAttribute object to add.
     /// \return
     /// 		Returns the position into which the new element was inserted.
@@ -128,22 +176,32 @@
     ///     Determines the index of a specific XmlAttribute object.
     /// \param value
-    /// Input the XmlAttribute object to locate in the collection.
+    ///     Input the XmlAttribute object to locate in the collection.
     /// \return
-    /// 		The index of value if found in the collection; otherwise, -1.
+    ///     The index of value if found in the collection; otherwise, -1.
 	System::Int32 IndexOf(XmlAttribute* value);
+    /// \brief
+    ///     Determines the index of a specific XmlAttribute object.
+    /// \param value
+    ///     Input the name of the XmlAttribute object to locate in the collection.
+    /// \return
 	System::Int32 IndexOf(String* name);
     /// \brief
     ///     Inserts a XmlAttribute object into the collection at the specified position.
     /// \param index
-    /// Input the zero-based index at which value should be inserted.
+    ///     Input the zero-based index at which value should be inserted.
     /// \param value
-    /// Input the XmlAttribute object to insert.
+    ///     Input the XmlAttribute object to insert.
 	System::Void Insert(System::Int32 index, XmlAttribute* value);
@@ -151,7 +209,7 @@
     ///     Removes the first occurrence of a specific XmlAttribute object.
     /// \param value
-    /// Input the XmlAttribute object to remove from the collection.
+    ///     Input the XmlAttribute object to remove from the collection.
 	System::Void Remove(XmlAttribute* value);
@@ -159,22 +217,32 @@
     ///     Determines whether the collection contains a specific XmlAttribute object.
     /// \param value
-    /// Input The XmlAttribute object to search in the collection.
+    ///     Input The XmlAttribute object to search in the collection.
     /// \return
-    /// 		Returns true if the value is found in the collection; otherwise, false.
+    ///     Returns true if the value is found in the collection; otherwise, false.
 	System::Boolean Contains(XmlAttribute* value);
+    /// \brief
+    ///     Determines whether the collection contains a specific XmlAttribute object.
+    /// \param value
+    ///     Input The name of the XmlAttribute object to search in the collection.
+    /// \return
 	System::Boolean Contains(String* name);
     /// \brief
     ///     Copies the elements of the collection to an array.
     /// \param array
-    /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
+    ///     Output the one-dimensional Array that is the destination of the elements copied from this collection.
     /// \param startAt
-    /// Input an integer that represents the index in array at which copying begins.
+    ///     Input an integer that represents the index in array at which copying begins.
 	System::Void CopyTo(XmlAttribute* array[],System::Int32 size);
@@ -182,8 +250,11 @@
     ///     Gets or sets a XmlAttribute in the collection.
     /// \param index
-    /// Input index of the XmlAttribute to retrieve or set (System::Int32).
+    ///     Input index of the XmlAttribute to retrieve or set (System::Int32).
+    /// \param value
+    ///     Input the value of the XmlAttribute
 	__property XmlAttribute* get_RealTypeItem(System::Int32 index);
 	__property System::Void  set_RealTypeItem(System::Int32 index, XmlAttribute* value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCharDataHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCharDataHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCharDataHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -36,9 +36,6 @@
     /// \brief
     /// Constructs a Char Data Handler.
-    /// \return
-    /// Returns FdoXmlCharDataHandler
 	XmlCharDataHandler();
     /// \brief
@@ -50,10 +47,22 @@
 	__property System::String* get_RetString();
+    /// \brief
+    /// Constructs a DataHandler based on an unmanaged instance of the object
+    /// Input A Pointer to the unmanaged object.
 	XmlCharDataHandler(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoXmlCharDataHandler* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCopyHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCopyHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlCopyHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -48,7 +48,7 @@
     /// Input the sub-elements are written to this XML writer.
     /// \return
-    /// Returns FdoXmlCopyHandler
+    /// Returns XmlCopyHandler
 	XmlCopyHandler( NAMESPACE_OSGEO_COMMON_XML:: XmlWriter* writer );
@@ -80,10 +80,22 @@
 	NAMESPACE_OSGEO_COMMON_XML::XmlCopyHandler(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* writer, String* resourceLocation, String* name,  String* qualifiedName,  XmlAttributeCollection* attributes, DictionaryElementCollection* namespaces);
+    /// \brief
+    /// Constructs a CopyHandler based on an unmanaged instance of the object
 	XmlCopyHandler(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoXmlCopyHandler* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlReader.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -57,7 +57,7 @@
     /// \return
-    /// Returns FdoXmlReader
+    /// Returns XmlReader
 	XmlReader( System::String* fileName );
@@ -68,7 +68,7 @@
     /// \return
 	XmlReader(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
@@ -79,7 +79,7 @@
     /// Input the text reader.
     /// \return
 	XmlReader( NAMESPACE_OSGEO_COMMON_IO::IoTextReader* reader );
@@ -127,7 +127,7 @@
     /// or the end of the document is reached. On subsequent calls to Parse() the
     /// read continues where the previous call left off.
     /// false: the whole document is parsed in a single call to XmlReader::Parse().
-    /// The FdoXmlSaxHandler::EndElement() return value is ignored. If a previous call
+    /// The XmlSaxHandler::EndElement() return value is ignored. If a previous call
     /// was made to XmlReader::Parse(), with incremental = true, then the rest of the
     /// document is parsed ( the EndElement() return value is ignored ).
@@ -135,15 +135,12 @@
     /// Returns true if the end of the document has not yet been reached
     System::Boolean Parse();
     System::Boolean Parse(NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* saxHandler);
     System::Boolean Parse(NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* saxHandler, NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* saxContext);
     System::Boolean Parse(NAMESPACE_OSGEO_COMMON_XML::IXmlSaxHandler* saxHandler, NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* saxContext, System::Boolean incremental);
     /// \brief
-    /// utility function that is typically called for element names or
+    /// Utility function that is typically called for element names or
     /// name type attributes that were adjusted when they were written to XML.
     /// FDO names that correspond to XML names, but aren't valid XML names, are
     /// adjusted. This function undoes the name adjustment.
@@ -187,6 +184,7 @@
 	System::String* PrefixToUri( System::String* prefix );
 protected:
@@ -194,6 +192,7 @@
     XmlReader(System::IntPtr unmanaged, System::Boolean autoDelete);
 	inline FdoXmlReader* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxContext.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -39,7 +39,7 @@
     /// Constructs the default Sax Context
     /// \param reader
-    /// Input the FdoXmlReader that is parsing the XML document.
+    /// Input the XmlReader that is parsing the XML document.
     /// \return
     /// Returns XmlSaxContext
@@ -47,21 +47,33 @@
 	XmlSaxContext(NAMESPACE_OSGEO_COMMON_XML::XmlReader* reader);
     /// \brief
-    /// Gets the FdoXmlReader that is parsing the XML document.
+    /// Gets the XmlReader that is parsing the XML document.
     /// \return
 	__property NAMESPACE_OSGEO_COMMON_XML::XmlReader* get_Reader();
+    /// \brief
+    /// Constructs an XmlSaxContext obhject based on an unmanaged instance of the object
 	XmlSaxContext(System::IntPtr unmanaged, System::Boolean autoDelete);
 protected:
 public private:
 	inline FdoXmlSaxContext* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSaxHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -41,7 +41,7 @@
     /// Default Sax callback that is called when the XmlReader
     /// starts reading an XML document. Does nothing.
-    /// \param saxContext
+    /// \param context
     /// Input caller specified contextual information
     /// \return
@@ -54,7 +54,7 @@
     /// finishes reading an XML document. Does nothing.
 	virtual System::Void XmlEndDocument(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context);
@@ -63,15 +63,15 @@
     /// reads the start tag for an XML element in the document. Does nothing.
-    /// \param uri
+    /// \param resourceLocation
     /// Input the element's Universal Resource Indicator
     /// \param name
     /// Input the unqualified element name (doesn't include namespace)
-    /// \param qname
+    /// \param qualifiedName
     /// Input the qualified element name (includes namespace)
-    /// \param atts
+    /// \param attributes
     /// Input the attributes for the element.
     /// \return
@@ -84,13 +84,13 @@
     /// reads the end tag for an XML element in the document. Does nothing.
-    /// \param uri
     /// \param name
-    /// \param qname
     /// \return
@@ -107,20 +107,32 @@
     /// the content is long. Applications must not make any assumptions about the
     /// chunk size or number of chunks for each element
-    /// \param chars
+    /// \param characters
     /// Input the next chunk of simple content
 	virtual System::Void XmlCharacters(NAMESPACE_OSGEO_COMMON_XML::XmlSaxContext* context, System::String* characters);
+    /// \brief
+    /// Constructs a SaxHandler based on an unmanaged instance of the object
     XmlSaxHandler(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoXmlSaxHandler* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSkipElementHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSkipElementHandler.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlSkipElementHandler.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -26,7 +26,7 @@
 /// \brief
 /// XmlSkipHandler can be used to skip an XML element, when reading an
-/// XML document via FdoXmlReader. It is a XmlSaxHandler with no callback
+/// XML document via XmlReader. It is a XmlSaxHandler with no callback
 /// implementations. Therefore, if another XmlSaxHandler's XmlStartElement
 /// callback returns a XmlSkipElementHandler then there are no more SAX events
 /// until the end of the current element is reached.
@@ -41,10 +41,22 @@
 	XmlSkipElementHandler();
+    /// \brief
+    /// Constructs a XmlSkipElementHandler based on an unmanaged instance of the object
 	XmlSkipElementHandler(System::IntPtr unmanaged, System::Boolean autoDelete);
 public private:
 	inline FdoXmlSkipElementHandler* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xml/mgXmlWriter.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -75,7 +75,7 @@
     /// element written (via  WriteStartElement() ) becomes the root element.
     /// The caller is responsible for ensuring that only one root element is written
     /// (the XML standard disallows multiple root elements).
-    /// \param indent
+    /// \param lineFormat
     /// Input indentation string for XML elements. If NULL
     /// the XML document contains no line breaks and elements are not indented.
     /// if L"" then the XML document has a line break after every end element
@@ -108,7 +108,7 @@
-    /// \param indent
@@ -133,7 +133,7 @@
     /// \brief
     /// Constructs an XML writer on a text writer
-    /// \param reader
+    /// \param writer
     /// Input the text writer.
     /// \param defaultRoot
     /// true: all elements written are wrapped in a default root element, named "DataStore".
@@ -141,7 +141,7 @@
-    /// \param indent
@@ -223,13 +223,13 @@
     /// \brief
     /// Writes the end tag for the current element to the document.
-    /// An FdoException is thrown if there is no element to end.
+    /// An Exception is thrown if there is no element to end.
 	System::Void WriteEndElement();
     /// \brief
     /// Writes an attribute to the current element.
-    /// A FdoException is thrown if this function is called immediately after
+    /// An Exception is thrown if this function is called immediately after
     /// WriteEndElement().
     /// \param attributeName
@@ -243,7 +243,7 @@
     /// \brief
     /// Writes simple (character) content for the current element. This function
     /// can be called multiple times for the same element. The characters are appended
-    /// to the element's content. A FdoException is thrown if there is no current
+    /// to the element's content. An Exception is thrown if there is no current
     /// element.
@@ -285,9 +285,40 @@
     System::Boolean IsValidName(System::String* name);
+    /// \brief
+    /// Given an element's or attribute's globally unique name ( uri and local name ),
+    /// this function returns its fully qualified name as per the
+    /// XML document being written, or the unqualified name if the uri is
+    /// the default namespace. This is done by searching for the current
+    /// namespace declaration that references the uri.
+    /// \remarks
+    /// If a matching default namespace declaration ( "xmlns=<uri>" ) was
+    /// found and the name is for an element then the localName is returned.
+    /// \note
+	/// According to the XML 1.0 specification, default namespaces do
+    /// not apply to attribute names, so the default namespace is ignored when the
+    /// given name is not for an element.
+    /// \n
+    /// Otherwise, if a matching namespace declaration was found then
+    /// "[namespace]:[localName]" is returned.
+    /// \n
+    /// Otherwise, L"" is returned (unable to determine qualified name).
+    /// \param location
+    /// Input the URI corresponding to an element.
+    /// \param localName
+    /// Input the local name corresponding to an element.
+    /// \param isElement
+    /// Input a boolean flag indicating that the URI corresponds to an element.
+    /// \return
+    /// Returns the fully qualified name corresponding to the uri.
 	System::String* UriToQName( System::String* location, System::String* localName, System::Boolean isElement);
 	System::String* UriToQName( System::String* location, System::String* localName);
 protected:
@@ -295,6 +326,7 @@
     XmlWriter(System::IntPtr unmanaged, System::Boolean autoDelete);
 	inline FdoXmlWriter* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/Xsl/mgXslTransformer.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -57,13 +57,9 @@
     /// Input the logging object.
 	XslTransformer();
 	XslTransformer(NAMESPACE_OSGEO_COMMON_XML::XmlReader* inDoc);
 	XslTransformer(NAMESPACE_OSGEO_COMMON_XML::XmlReader* inDoc, NAMESPACE_OSGEO_COMMON_XML::XmlReader* stylesheet);
 	XslTransformer(NAMESPACE_OSGEO_COMMON_XML::XmlReader* inDoc, NAMESPACE_OSGEO_COMMON_XML::XmlReader* stylesheet, NAMESPACE_OSGEO_COMMON_XML::XmlWriter* outDoc);
     XslTransformer(NAMESPACE_OSGEO_COMMON_XML::XmlReader* inDoc, NAMESPACE_OSGEO_COMMON_XML::XmlReader* stylesheet, NAMESPACE_OSGEO_COMMON_XML::XmlWriter* outDoc, NAMESPACE_OSGEO_COMMON_IO::IoTextWriter* log);
     /// \brief
@@ -150,16 +146,28 @@
 	System::Void Transform();
+    /// \brief
+    /// Constructs an XslTransformer based on an unmanaged instance of the object
 	XslTransformer(System::IntPtr unmanaged, System::Boolean autoDelete) : NAMESPACE_OSGEO_RUNTIME::Disposable(unmanaged, autoDelete)
 public private:
 	inline FdoXslTransformer* GetImpObj();
 protected:
+/// \endcond
 END_NAMESPACE_OSGEO_COMMON_XSL
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionary.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -27,29 +27,81 @@
 /// \brief
 ///     DictionaryElementCollection is a collection of name-value pairs.
-public __sealed __gc class DictionaryElementCollection : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
+public __sealed __gc class DictionaryElementCollection :
+    public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
 private:
     /// \brief
+    /// 	A Nested class defined to provide enumeration of Dictionary elements
+    ///     Enumerators can be used to read the data in the collection,
+    ///     but they cannot be used to modify the underlying collection.
+    ///     An enumerator remains valid as long as the collection remains unchanged.
+    ///     If changes are made to the collection, such as adding, modifying, or deleting
+    ///     elements, the enumerator is irrecoverably invalidated and the next call to
+    ///     MoveNext or Reset throws an InvalidOperationException. If the collection is
+    ///     modified between MoveNext and Current, Current returns the element that it is
+    ///     set to, even if the enumerator is already invalidated.
+    ///     The enumerator does not have exclusive access to the collection; therefore,
+    ///     enumerating through a collection is intrinsically not a thread-safe procedure.
+    ///     Even when a collection is synchronized, other threads can still modify the
+    ///     collection, which causes the enumerator to throw an exception. To guarantee
+    ///     thread safety during enumeration, you can either lock the collection during
+    ///     the entire enumeration or catch the exceptions resulting from changes made
+    ///     by other threads.
-	__gc class Enumerator : public System::Collections::IEnumerator
+	__gc class Enumerator : public System::Collections::IEnumerator
 	private:
 		DictionaryElementCollection* m_pCol;
 	public:
+        /// \brief
+        ///     Constructs a new dictionary Enumerator
+        ///     Input The Dictionary collection to enumerate.
 		Enumerator(DictionaryElementCollection* elements) : m_pCol(elements), m_nIdx(-1)
+        /// \brief
+        ///     Retrieves the current dictionay element at the enumerator location
+        /// \return
+        /// 	Retuns the current dictionary element referenced by the enumerator
+        /// \brief
+        /// \return
+        /// 	Retuns true if the enumerator is able to move to a valid dictionary element
+        /// \brief
@@ -82,27 +134,47 @@
+/// \endcond
 public:
+    /// \brief
+    ///     Constructs a new empty dictionary element collection
 	DictionaryElementCollection();
+    /// \brief
+    ///     Constructs a dictionary object based on an unmanaged instance of the object
 	DictionaryElementCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
     /// \brief
     ///    Gets the count of items in collection.
+    /// \return
+    /// 	Returns the number of items in the collection.
 	__property System::Int32 get_Count(System::Void);
     /// \brief
     ///    Gets an enumerator that can iterate through a collection.
+    /// \return
+    /// 	Returns an enumerator on the dictionary.
 	__sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
     /// \brief
     ///     Removes the index-th DictionaryElement from this collection.
     /// \param index
@@ -115,10 +187,10 @@
     ///     Adds a DictionaryElement object into the collection.
     /// \param value
-    /// Input the DictionaryElement object to add.
+    ///     Input the DictionaryElement object to add.
     /// \return
-    /// 		Returns the position into which the new element was inserted.
+    /// 	Returns the position into which the new element was inserted.
 	System::Int32 Add(DictionaryElement* value);
@@ -126,22 +198,32 @@
     ///     Determines the index of a specific DictionaryElement object.
     /// \param value
-    /// Input the DictionaryElement object to locate in the collection.
+    ///     Input the DictionaryElement object to locate in the collection.
     /// \return
 	System::Int32 IndexOf(DictionaryElement* value);
+    /// \brief
+    ///     Determines the index of a specific DictionaryElement object.
+    /// \param name
+    ///     Input the name of the DictionaryElement object to locate in the collection.
+    /// \return
     /// \brief
     ///     Inserts a DictionaryElement object into the collection at the specified position.
     /// \param index
     /// \param value
-    /// Input the DictionaryElement object to insert.
+    ///     Input the DictionaryElement object to insert.
 	System::Void Insert(System::Int32 index, DictionaryElement* value);
@@ -149,7 +231,7 @@
     ///     Removes the first occurrence of a specific DictionaryElement object.
     /// \param value
-    /// Input the DictionaryElement object to remove from the collection.
+    ///     Input the DictionaryElement object to remove from the collection.
 	System::Void Remove(DictionaryElement* value);
@@ -157,43 +239,94 @@
     ///     Determines whether the collection contains a specific DictionaryElement object.
     /// \param value
-    /// Input The DictionaryElement object to search in the collection.
+    ///     Input The DictionaryElement object to find in the collection.
     /// \return
 	System::Boolean Contains(DictionaryElement* value);
+    /// \brief
+    ///     Determines whether the collection contains a specific DictionaryElement object.
+    /// \param value
+    ///     Input The name of the DictionaryElement object to find in the collection.
+    /// \return
     /// \brief
     /// \param array
-    /// \param startAt
+    /// \param size
 	System::Void CopyTo(DictionaryElement* array[],System::Int32 size);
     /// \brief
-    ///     Gets or sets a DictionaryElement in the collection.
+    ///     Gets a DictionaryElement in the collection.
     /// \param index
-    /// Input index of the DictionaryElement to retrieve or set (System::Int32).
+    ///     Input index of the DictionaryElement to retrieve.
+    /// \return
+    /// 	Returns the requested dictionary element.
 	__property DictionaryElement* get_RealTypeItem(System::Int32 index);
+    /// \brief
+    ///     Gets a named DictionaryElement in the collection.
+    /// \param index
+    ///     Input name of the DictionaryElement to retrieve.
+    /// \return
 	__property DictionaryElement* get_RealTypeItem(System::String* index);
+    /// \brief
+    ///     Sets a DictionaryElement in the collection.
+    /// \param index
+    ///     Input The index of the DictionaryElement to set.
+    /// \param value
+    /// 	The dictionary element to set at the specified index
 	__property System::Void  set_RealTypeItem(System::Int32 index, DictionaryElement* value);
+    /// \brief
+    /// \param index
+    /// \return
 	__property DictionaryElement* get_Item(System::Int32 index);
+    /// \brief
+    /// \param index
+    /// \param value
 	__property System::Void  set_Item(System::Int32 index, DictionaryElement* value);
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgDictionaryElement.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -30,28 +30,44 @@
 public __sealed __gc class DictionaryElement : public NAMESPACE_OSGEO_RUNTIME::Disposable
 public:
+    /// \brief
+    /// \param name
+    ///     The name of the element.
+    /// \param value
+    ///     The value of the element.
 	DictionaryElement(System::String* name, System::String* value);
+    /// \brief
+    ///     Constructs an elemnet based on an unmanaged instance of the object
 	DictionaryElement(System::IntPtr unmanaged, System::Boolean autoDelete);
     /// \brief
-    ///     Gets the name of this element
+    ///     Gets the name of this dictionary element
     /// \return
-    ///     Returns the element name
+    ///     Returns the dictionary element name
 	__property String* get_Name();
     /// \brief
-    ///     Indicates that this object does not allow its name
-    ///     to change. Not allowing name change allows more efficient
-    ///     random access to FdoDictionary.
+    ///     Indicates whether the name of the DictionaryElement can be changed once
+    ///     it has been created.
     /// \return
-    ///     Returns false
+    ///     Returns true if the DictionaryElement name can be changed; otherwise false.
 	__property System::Boolean get_CanSetName();
     /// \brief
@@ -60,22 +76,23 @@
     /// \return
     ///     Returns the element value
 	__property System::String* get_Value();
     /// \brief
     ///     Sets the value of this dictionary element
     /// \param value
-    /// Input the element value
+    ///     Input the value of the dictionary element
 	__property System::Void set_Value(String* value);
 protected:
 public private:
 	inline FdoDictionaryElement* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgException.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgException.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgException.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -29,19 +29,22 @@
 	static NAMESPACE_OSGEO_COMMON::Exception* Create(System::IntPtr ex);
 public:
+    /// \brief
+    /// Constructs a new empty Exception object
 	NAMESPACE_OSGEO_COMMON::Exception() : System::Exception()
     /// \brief
-    /// Returns an instance of a FdoException using the specified arguments.
+    /// Creates an instance of an Exception using the specified arguments.
     /// \param message
     /// Input the error message
     /// \return
-    /// Returns the FdoException object
+    /// Returns the newly created Exception object
 	NAMESPACE_OSGEO_COMMON::Exception(String* msg) : System::Exception(msg)
@@ -49,26 +52,29 @@
     /// \brief
+    ///  Returns an instance of a Exception using the specified arguments.
     /// \param message
     /// \param cause
     /// Input the cause of the error
     /// \return
+    /// Returns the Exception object
 	NAMESPACE_OSGEO_COMMON::Exception(System::String* msg, System::Exception* cause) : System::Exception(msg, cause)
 protected:
 	NAMESPACE_OSGEO_COMMON::Exception(System::Runtime::Serialization::SerializationInfo* info, System::Runtime::Serialization::StreamingContext context) : System::Exception(info, context)
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgGeometryType.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -79,7 +79,7 @@
 /// \brief
 ///  Enumeration for components of Geometry.
 /// \remarks
-///  This enumeration applies to certain helper types that are used to compose other types which derive from FdoIGeometry.
+///  This enumeration applies to certain helper types that are used to compose other types which derive from IGeometry.
 /// <param name="GeometryComponentType_LinearRing">
 /// LinearRing type
 /// </param>
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReader.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -22,6 +22,8 @@
 BEGIN_NAMESPACE_OSGEO_COMMON
+/// \brief
+/// Enumeration for datatypes used by stream readers.
 public __value enum StreamReaderType
 	StreamReaderType_Byte = FdoStreamReaderType_Byte,
@@ -29,11 +31,17 @@
 /// \brief
-///     The IStreamReader class is a top level interface for stream reader classes.
-///     The API it provides allows the user to read large streams of data in blocks of items.
+/// The IStreamReader class is a top level interface for stream reader classes.
+/// The API it provides allows the user to read large streams of data in blocks of items.
 public __gc __interface IStreamReader : public System::IDisposable
 public:
+    /// \brief
+    /// Gets the type of the Stream Reader
+    /// \return
+    /// Returns the Stream Reader type
 	__property StreamReaderType get_Type();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgIStreamReaderImp.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -28,18 +28,37 @@
 /// \brief
-public __gc class IStreamReaderImp : public NAMESPACE_OSGEO_RUNTIME::Disposable, public NAMESPACE_OSGEO_COMMON::IStreamReader
+public __gc class IStreamReaderImp :
+    public NAMESPACE_OSGEO_RUNTIME::Disposable, public NAMESPACE_OSGEO_COMMON::IStreamReader
 public:
+    /// \brief
+    ///     Constructs a IStreamReader object based on an unmanaged instance of the stream
+    ///     Input A Pointer to the unmanaged Stream Reader.
+    ///     Input Indicates if the constructed dictionary should be automatically deleted
 	IStreamReaderImp(System::IntPtr unmanaged, System::Boolean autoDelete);
+    /// \brief
+    /// \return
 protected:
 	__sealed System::Void ReleaseUnmanagedObject();
 public private:
 	inline  FdoIStreamReader* GetImpObj();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringCollection.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -30,9 +30,10 @@
 public __sealed __gc class StringCollection : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
 private:
     /// \brief
@@ -41,15 +42,47 @@
 	public:
+        /// \brief
+        ///     Input The String collection to enumerate.
 		Enumerator(StringCollection* elements) : m_pCol(elements), m_nIdx(-1)
+        /// \brief
+        ///     Retrieves the current String object at the enumerator location
+        /// \return
+        /// 	Retuns the current String referenced by the enumerator
+        /// \brief
+        /// \return
+        /// \brief
@@ -82,46 +115,83 @@
+/// \endcond
 public:
     /// \brief
     ///     Constructs a new empty string collection
-    /// \return
-    ///     Returns FdoStringCollection
 	StringCollection();
     /// \brief
     ///     Creates a copy of string collection
     /// \param src
-    /// Input the source collection
+    ///     Input the source collection
 	StringCollection(StringCollection* collection);
+    /// \brief
+    ///     Creates a string collection that is tokenized from a string.
+    ///     The collection contains an element for each token.
+    /// \param data
+    ///     Input the string to tokenize.
+    /// \param delimiters
+    ///     Input list of single character token delimiters.
 	StringCollection(String* data, String* delimiters);
+    /// \brief
+    /// \param data
+    /// \param bNullTokens
+    ///     true: include zero-length tokens in the collection.
+    ///     false: exclude zero-length tokens
 	StringCollection(String* data, String* delimiters, Boolean nullTokens);
+    /// \brief
+    ///     Constructs a String Collection based on an unmanaged instance of the object
+    ///     Input Indicates if the constructed collection should be automatically deleted
 	StringCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
     /// \brief
+    /// \return
     /// \brief
+    /// \return
     /// \brief
     ///     Removes the index-th StringElement from this collection.
     /// \param index
@@ -134,10 +204,10 @@
     ///     Adds a StringElement object into the collection.
     /// \param value
-    /// Input the StringElement object to add.
+    ///     Input the StringElement object to add.
     /// \return
 	System::Int32 Add(StringElement* value);
@@ -145,20 +215,29 @@
     ///     Appends the strings from src to the end of this collection.
     /// \param src
 	System::Void Append(StringCollection* col);
+    /// \brief
+    ///     Gets a String in the collection.
+    /// \param index
+    ///     Input index of the String to retrieve.
+    /// \return
+    /// 	Returns the requested String.
 	__property System::String* get_String(System::Int32 index);
     /// \brief
     ///     Determines the index of a specific StringElement object.
     /// \param value
-    /// Input the StringElement object to locate in the collection.
+    ///     Input the StringElement object to locate in the collection.
     /// \return
 	System::Int32 IndexOf(StringElement* value);
@@ -166,9 +245,10 @@
     ///     Inserts a StringElement object into the collection at the specified position.
     /// \param index
     /// \param value
-    /// Input the StringElement object to insert.
+    ///     Input the StringElement object to insert.
 	System::Void Insert(System::Int32 index, StringElement* value);
@@ -176,7 +256,7 @@
     ///     Removes the first occurrence of a specific StringElement object.
     /// \param value
-    /// Input the StringElement object to remove from the collection.
+    ///     Input the StringElement object to remove from the collection.
 	System::Void Remove(StringElement* value);
@@ -184,10 +264,10 @@
     ///     Determines whether the collection contains a specific StringElement object.
     /// \param value
-    /// Input The StringElement object to search in the collection.
+    ///     Input The StringElement object to search in the collection.
     /// \return
 	System::Boolean Contains(StringElement* value);
@@ -195,28 +275,61 @@
     /// \param array
     /// \param startAt
 	System::Void CopyTo(StringElement* array[],System::Int32 size);
     /// \brief
-    ///     Gets or sets a StringElement in the collection.
+    ///     Gets a StringElement in the collection.
     /// \param index
-    /// Input index of the StringElement to retrieve or set (System::Int32).
+    ///     Input index of the StringElement to retrieve.
+    /// \return
+    ///     Returns the StringElement at the specified index
 	__property StringElement* get_RealTypeItem(System::Int32 index);
+    /// \brief
+    ///     Sets the value of the StringElement at the specified index
+    /// \param index
+    ///     Input index of the StringElement to set.
+    /// \param value
+    ///     Input the value of the StringElement
 	__property System::Void  set_RealTypeItem(System::Int32 index, StringElement* value);
+    /// \brief
+    /// \param index
+    /// \return
 	__property StringElement* get_Item(System::Int32 index);
+    /// \brief
+    /// \param index
+    /// \param value
+    ///     Input the value of the string
 	__property System::Void  set_Item(System::Int32 index, StringElement* value);
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h	2007-01-31 22:56:42 UTC (rev 694)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Common/mgStringElement.h	2007-01-31 23:03:04 UTC (rev 695)
@@ -29,15 +29,33 @@
 public __sealed __gc class StringElement : public NAMESPACE_OSGEO_RUNTIME::Disposable
 public:
+    /// \brief
+    ///     Constructs a new string element based on an input string
+    /// \param value
+    ///     The string value of the element.
 	StringElement(System::String* value);
+    /// \brief
+    ///     Constructs a string elemnet based on an unmanaged instance of the object
+    ///     Input A Pointer to the unmanaged string element.
+    ///     Input Indicates if the constructed element should be automatically deleted
 	StringElement(System::IntPtr unmanaged, System::Boolean autoDelete);
 protected:
 public private:
 	inline FdoStringElement* GetImpObj();
+/// \endcond
More information about the fdo-commits mailing list
