[fdo-commits] r724 - in branches/3.2.x/Providers/GenericRdbms/Src: Fdo/Connection ODBC/Fdo
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Jan 31 21:24:12 EST 2007
Author: jacklee
Date: 2007-01-31 21:24:12 -0500 (Wed, 31 Jan 2007)
New Revision: 724
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.h
   branches/3.2.x/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp
Revert Fixed ODBC(Oracle) provider describe schema is slow fix
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.cpp	2007-01-31 23:52:59 UTC (rev 723)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.cpp	2007-02-01 02:24:12 UTC (rev 724)
@@ -81,7 +81,8 @@
     mFilterProcessor( NULL ),
     mSchemaUtil( NULL ),
     mIndex(0),
-    mContext(NULL)
+    mContext(NULL),
+    mParsedConnection(NULL)
     // Set the flag that indicates whether or not the RDBMS user has a Workspace
     // Manager environment.
@@ -91,8 +92,8 @@
     //       Workspace Manager or Alternate API.
     mIsWorkspaceManagerEnvironment = FALSE;
-    mParsedConnection = new ParseInfo();
 DbiConnection::~DbiConnection(void)
@@ -180,6 +181,8 @@
             mGdbiConnection->SetIsGeometryFromOrdinatesWanted((char*)(const char*)(mParsedConnection->mIsGeometryFromOrdinatesWanted));
+    mDbSchemaName = mParsedConnection->mSchema;
     return mOpen;
@@ -201,7 +204,7 @@
         rdbi_disconnect( mContext );
         mOpen = FdoConnectionState_Closed;
 		mGdbiConnection->Close();
-        mParsedConnection->mSchema = L"";
+        mDbSchemaName = L"";
         mDbiContextId  = -1;
@@ -261,29 +264,25 @@
 FdoStringP DbiConnection::GetUser()
-    return mParsedConnection->mUser;
+    return (NULL == mParsedConnection) ? L"" : mParsedConnection->mUser;
 FdoStringP DbiConnection::GetPassword()
-    return mParsedConnection->mPassword;
+    return (NULL == mParsedConnection) ? L"" : mParsedConnection->mPassword;
 FdoStringP DbiConnection::GetSchema()
-    return mParsedConnection->mSchema;
+    return (NULL == mParsedConnection) ? L"" : mParsedConnection->mSchema;
 FdoStringP DbiConnection::GetDataSource()
-    return mParsedConnection->mDataSource;
+    return (NULL == mParsedConnection) ? L"" : mParsedConnection->mDataSource;
-FdoStringP DbiConnection::GetConnectionString()
-    return mParsedConnection->mConnectionStringProperty;
 void DbiConnection::SetConnectData (FdoString *datasource, FdoString *user, FdoString *password, FdoString *schema, FdoString *connectionString, FdoString *defaultGeometryWanted)
     if ( !mParsedConnection )
@@ -761,12 +760,12 @@
 FdoStringP DbiConnection::GetDbSchemaName()
+    return mDbSchemaName;
 void DbiConnection::SetDbSchemaName(const wchar_t * schemaName)
-    mParsedConnection->mSchema = schemaName;
+    mDbSchemaName = schemaName;
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.h
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.h	2007-01-31 23:52:59 UTC (rev 723)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Connection/DbiConnection.h	2007-02-01 02:24:12 UTC (rev 724)
@@ -62,8 +62,7 @@
             FdoStringP mConnectionStringProperty;    // A connection property actually named "ConnectionString"
             FdoStringP mIsGeometryFromOrdinatesWanted;   // Unspecified if empty.  Can be "true" or "false".
-            ParseInfo (FdoString *datasource = L"", FdoString *user = L"", FdoString *password = L"", FdoString *schema = L"",
-                FdoString *connectionString = L"", FdoString *defaultGeometryWanted = L"");
+            ParseInfo (FdoString *datasource, FdoString *user, FdoString *password, FdoString *schema, FdoString *connectionString, FdoString *defaultGeometryWanted);
             virtual ~ParseInfo ();
@@ -71,6 +70,8 @@
     ParseInfo* mParsedConnection;
+    FdoStringP mDbSchemaName;
     FdoConnectionState     mOpen;     // if the database is open
     bool    mIsWorkspaceManagerEnvironment;
@@ -105,7 +106,6 @@
     FdoStringP GetPassword();
     FdoStringP GetSchema ();
     FdoStringP GetDataSource ();
-    FdoStringP GetConnectionString ();
     FDORDBMS_TEST  void Close ();
     //dbi_context_def *GetCtxt() { return mContext; }
Modified: branches/3.2.x/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp	2007-01-31 23:52:59 UTC (rev 723)
+++ branches/3.2.x/Providers/GenericRdbms/Src/ODBC/Fdo/FdoRdbmsOdbcConnection.cpp	2007-02-01 02:24:12 UTC (rev 724)
@@ -22,15 +22,8 @@
 #ifdef _WIN32
 #include <tchar.h>
-#include<odbcinst.h>
-#else
-// remove #if 0 when FdoRdbmsOdbcConnection::GetSchemaNameFromDsn is active on Linux
-#if 0
 #endif
-#endif
 #include <Inc/ut.h>
 #include "FdoRdbmsOdbcConnectionInfo.h"
 #include "FdoRdbmsOdbcConnection.h"
@@ -52,7 +45,6 @@
 #include "FdoRdbmsOdbcSpatialManager.h"
 #include "DbiConnection.h"
-#include <FdoCommonConnStringParser.h>
 #include <Inc/Rdbi/proto.h>
 #include "../../ODBCDriver/context.h"
@@ -183,37 +175,16 @@
 FdoSchemaManagerP FdoRdbmsOdbcConnection::CreateSchemaManager()
     FdoStringP userName = GetDbiConnection()->GetUser();
-    FdoStringP schemaName = GetDbiConnection()->GetDbSchemaName();
-    if (schemaName.GetLength() == 0)
+    FdoStringP schemaName = GetSchemaNameFromDsn();
+    if (schemaName.GetLength() > 0)
-        FdoStringP connectionStringProperty = GetDbiConnection()->GetConnectionString();
-        if (connectionStringProperty.GetLength() != 0)
-            FdoCommonConnStringParser parser (NULL, connectionStringProperty);
-            if (parser.IsConnStringValid())
-                FdoStringP drvName = parser.GetPropertyValueW(L"DRIVER");
-                if (drvName.Contains(L"Oracle") && drvName.Contains(L"10g"))
-                    schemaName = parser.GetPropertyValueW(L"XSM");
-                    if (schemaName == L"Default")
-                        schemaName = L"";
-            schemaName = GetSchemaNameFromDsn();
-        if (schemaName.GetLength() > 0)
-            // If the DSN contained a schema name, take that as the only one that
-            // we want to see, and which will be specified in all future requests
-            // from this provider.
-            // If this is not set, all schemas will be visible (occasionally more
-            // useful, but also can be slow).
-            GetDbiConnection()->SetDbSchemaName(schemaName);
+        // If the DSN contained a schema name, take that as the only one that
+        // we want to see, and which will be specified in all future requests
+        // from this provider.
+        // If this is not set, all schemas will be visible (occasionally more
+        // useful, but also can be slow).
+        GetDbiConnection()->SetDbSchemaName(schemaName);
 #if 0
@@ -448,48 +419,86 @@
 #ifdef _WIN32
-#define ODBC_FODBC_INI        L"ODBC.INI"
+static HKEY GetRegistryKey(HKEY topkey, const char * subkeyName)
+    HKEY hkey = NULL;
+    TCHAR value[ODBCDR_CONNECTION_SIZE];
+    DWORD size = sizeof(value) / sizeof(value[0]);;
+    LONG errStatus = ERROR_SUCCESS;
+    int status = FALSE;
+    if (ERROR_SUCCESS != RegOpenKeyEx (
+        topkey,
+        _T(subkeyName),     /* subkey name */
+        0L,                 /* reserved */
+        KEY_QUERY_VALUE,    /* security access mask */
+        &hkey))             /* handle to open key */
+        hkey = NULL;
+    return hkey;
+static FdoStringP GetRegistryValue(HKEY hkey, const char * name)
+    DWORD type;
+    FdoStringP valueP;
+    errStatus = RegQueryValueEx (
+        hkey,         /* handle to key */
+        _T(name),     /* value name */
+        NULL,         /* reserved */
+        &type,        /* type buffer */
+        (LPBYTE)value,/* data buffer */
+        &size);       /* size of data buffer */
+    if (ERROR_SUCCESS == errStatus)
+        valueP = FdoStringP::Format(L"%hs", (char *) value);
+    return valueP;
+#endif
+#define SUBKEYNAME_PREFIX           "Software\\ODBC\\ODBC.INI\\"
+#define KEYNAME_DRIVER              "Driver"
+#define KEYNAME_USERID_ORACLENATIVE "UserID"
+#define DRIVER_NAME_ORACLENATIVE    L"SQORA32"
 FdoStringP FdoRdbmsOdbcConnection::GetSchemaNameFromDsn()
     FdoStringP schemaName;
+#ifdef _WIN32
     // For Oracle on Windows, get the UserId field.
     // This field is normally just a default for the username, so this use does overload
     // it.  However, Oracle's driver does not offer a separate "schema" field as other
     // drivers do.
     FdoStringP dsn = GetDbiConnection()->GetDataSource();
-    wchar_t buffValue[ODBCDR_CONNECTION_SIZE];
-    if(0 != ::SQLGetPrivateProfileStringW( L"ODBC Data Sources", dsn, L"", buffValue, ODBCDR_CONNECTION_SIZE, ODBC_FODBC_INI ))
+    HKEY hkey = NULL;
+    char subkeyName[ODBCDR_CONNECTION_SIZE];
+    size_t subkeyNameSize = sizeof(subkeyName) / sizeof(subkeyName[0]);
+    (void) _snprintf(subkeyName, subkeyNameSize-1, "%s%ls", SUBKEYNAME_PREFIX, (const wchar_t *)dsn);
+    hkey = GetRegistryKey(HKEY_CURRENT_USER, subkeyName);
+    if (NULL == hkey)
+        hkey = GetRegistryKey(HKEY_LOCAL_MACHINE, subkeyName);
+    if (NULL != hkey)
-        FdoStringP drvName = buffValue;
+        FdoStringP driver = GetRegistryValue(hkey, KEYNAME_DRIVER);
+        if (driver.Contains(DRIVER_NAME_ORACLENATIVE))
-	        if(0 != ::SQLGetPrivateProfileStringW( dsn, L"UserID", L"", buffValue, ODBCDR_CONNECTION_SIZE, ODBC_FODBC_INI ))
-		        schemaName = buffValue;
+            FdoStringP userId = GetRegistryValue(hkey, KEYNAME_USERID_ORACLENATIVE);
+            if (userId.GetLength() > 0)
+                schemaName = userId;
-    return schemaName;
-#else
-#define ODBC_FODBC_INI        "ODBC.INI"
-FdoStringP FdoRdbmsOdbcConnection::GetSchemaNameFromDsn()
-    FdoStringP schemaName;
-#if 0
-    // this code is intended for Linux but is untested.
-    // not sure if SQLGetPrivateProfileString is implemented on Linux
-    FdoStringP dsn = GetDbiConnection()->GetDataSource();
-    char buffValue[ODBCDR_CONNECTION_SIZE];
-    if(0 != ::SQLGetPrivateProfileString( "ODBC Data Sources", dsn, "", buffValue, ODBCDR_CONNECTION_SIZE, ODBC_FODBC_INI ))
-        if (drvName.Contains("Oracle") && drvName.Contains("10g"))
-	        if(0 != ::SQLGetPrivateProfileString( dsn, "UserID", "", buffValue, ODBCDR_CONNECTION_SIZE, ODBC_FODBC_INI ))
 #endif
     return schemaName;
-#endif
More information about the fdo-commits mailing list
