[fdo-commits] r777 - in branches/3.2.x/Providers/GenericRdbms/Src/Fdo: FeatureCommands Pvc
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Mar 5 12:38:02 EST 2007
Author: brentrobinson
Date: 2007-03-05 12:38:01 -0500 (Mon, 05 Mar 2007)
New Revision: 777
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsInsertCommand.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
Handle missing system properties for externally created tables
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsInsertCommand.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsInsertCommand.cpp	2007-03-03 19:03:07 UTC (rev 776)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsInsertCommand.cpp	2007-03-05 17:38:01 UTC (rev 777)
@@ -131,6 +131,9 @@
             // check Feat Id property
             const FdoSmLpDataPropertyDefinition *lpFeatIdProp = classDefinition->RefFeatIdProperty();
+            if ( (lpFeatIdProp != NULL) && (lpFeatIdProp->RefColumn() == NULL) )
+                lpFeatIdProp = NULL;
             if( lpFeatIdProp != NULL ) {
                 const wchar_t *featId = lpFeatIdProp->GetName();
@@ -162,29 +165,34 @@
                     addedIndentProperties = true;
-                    FdoPtr<FdoPropertyValue>classId = FdoPropertyValue::Create();
-                    FdoPtr<FdoDataValue>clidValue = FdoDataValue::Create((FdoInt64) feat_info.classid );
-                    classId->SetValue( clidValue );
-                    classId->SetName( L"ClassId" );
-                    mPropertyValues->Add( classId );
+                    const FdoSmLpDataPropertyDefinition *lpSystemProp = FdoSmLpDataPropertyDefinition::Cast(classDefinition->RefProperties()->RefItem(L"ClassId"));
+                    if ( lpSystemProp && lpSystemProp->RefColumn() ) {
+                        FdoPtr<FdoPropertyValue>classId = FdoPropertyValue::Create();
+                        FdoPtr<FdoDataValue>clidValue = FdoDataValue::Create((FdoInt64) feat_info.classid );
+                        classId->SetValue( clidValue );
+                        classId->SetName( lpSystemProp->GetName() );
+                        mPropertyValues->Add( classId );
-                    FdoPtr<FdoPropertyValue>revNum = FdoPropertyValue::Create();
-                    FdoPtr<FdoDataValue>revValue = FdoDataValue::Create((FdoInt64) 0 );
-                    revNum->SetValue( revValue );
-                    revNum->SetName( L"RevisionNumber" );
-                    mPropertyValues->Add( revNum );
 			        FdoPtr<FdoPropertyValue>featIdProp = FdoPropertyValue::Create();
                     FdoPtr<FdoIdentifier>featIdIdentifier = FeatIdProp->GetName();
                     featIdProp->SetName( featIdIdentifier );
 			        featInfoCol->Add(featIdProp);
-			        FdoPtr<FdoPropertyValue>chgSeqProp = FdoPropertyValue::Create();
-                    FdoPtr<FdoDataValue>chgSeqValue = FdoDataValue::Create((FdoInt64) feat_info.changeseq );
-                    chgSeqProp->SetValue( chgSeqValue );
-                    chgSeqProp->SetName( L"RevisionNumber" );
-                    featInfoCol->Add(chgSeqProp);
+                    lpSystemProp = FdoSmLpDataPropertyDefinition::Cast(classDefinition->RefProperties()->RefItem(L"RevisionNumber"));
+                        FdoPtr<FdoPropertyValue>revNum = FdoPropertyValue::Create();
+                        FdoPtr<FdoDataValue>revValue = FdoDataValue::Create((FdoInt64) 0 );
+                        revNum->SetValue( revValue );
+                        revNum->SetName( lpSystemProp->GetName() );
+                        mPropertyValues->Add( revNum );
+			            FdoPtr<FdoPropertyValue>chgSeqProp = FdoPropertyValue::Create();
+                        FdoPtr<FdoDataValue>chgSeqValue = FdoDataValue::Create((FdoInt64) feat_info.changeseq );
+                        chgSeqProp->SetValue( chgSeqValue );
+                        chgSeqProp->SetName( lpSystemProp->GetName() );
+                        featInfoCol->Add(chgSeqProp);
                     // Set the featID value in the Property value collections
                     if( FeatIdProp.p != NULL && !isFeatIdAutoincremented)
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp	2007-03-03 19:03:07 UTC (rev 776)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsUpdateCommand.cpp	2007-03-05 17:38:01 UTC (rev 777)
@@ -201,13 +201,16 @@
         if ( isFeatClass ) {
             featIdProp = classDefinition->RefFeatIdProperty();
             if( featIdProp != NULL ) {
-                prmPrtName = featIdProp->GetName();
-                if ( (prmPrtName == NULL) || (wcslen(prmPrtName) == 0) )
-                    throw FdoCommandException::Create( NlsMsgGet( FDORDBMS_15, "Feature ID does not exist") );
+                const FdoSmPhColumn* featIdCol = featIdProp->RefColumn();
-                const wchar_t *colName = mConnection->GetSchemaUtil()->Property2ColName( className->GetText(), prmPrtName );
-                prmColName = (wchar_t*)alloca ((wcslen(colName) + 1)*sizeof( wchar_t ) );
-                wcscpy(prmColName, colName);
+                if ( featIdCol != NULL ) {
+                    const wchar_t *colName = featIdCol->GetName();
+                    prmColName = (wchar_t*)alloca ((wcslen(colName) + 1)*sizeof( wchar_t ) );
+                    wcscpy(prmColName, colName);
+                else {
+                    featIdProp = NULL;
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp	2007-03-03 19:03:07 UTC (rev 776)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcInsertHandler.cpp	2007-03-05 17:38:01 UTC (rev 777)
@@ -1088,10 +1088,20 @@
                 const FdoSmPhColumn *column = dataProp->RefColumn();
                 if (NULL == column)
-                    throw FdoRdbmsException::Create(NlsMsgGet1(
-                            FDORDBMS_485,
-                            "No column for property '%1$ls'.",
-                            dataProp->GetName()));
+                    if ( dataProp->GetIsSystem() )
+                        // It is possible for externally defined tables to not have
+                        // columns for certain system properties. In this case,
+                        // skip these properties.
+                        continue;
+                    else
+                        throw FdoRdbmsException::Create(NlsMsgGet1(
+                                FDORDBMS_485,
+                                "No column for property '%1$ls'.",
+                                dataProp->GetName()));
                 const wchar_t *colName = column->GetName();
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp	2007-03-03 19:03:07 UTC (rev 776)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Pvc/FdoRdbmsPvcUpdateHandler.cpp	2007-03-05 17:38:01 UTC (rev 777)
@@ -77,7 +77,10 @@
     const FdoSmLpDbObject* table = classDefinition->RefDbObject();
     FdoStringP tableName = table->RefDbObject()->GetDbQName();
 	FdoStringP updateString;
-	const FdoSmLpPropertyDefinition *pDef = classDefinition->RefProperties()->RefItem(L"RevisionNumber");
+    const FdoSmLpDataPropertyDefinition *pDef = FdoSmLpDataPropertyDefinition::Cast(classDefinition->RefProperties()->RefItem(L"RevisionNumber"));
+    if ( (pDef != NULL) && (pDef->RefColumn() == NULL) )
+        pDef = NULL;
 	if (pDef && revisionNumberUpdate)
 		updateString = FdoStringP::Format(L"update %ls set revisionnumber = revisionnumber+1, ", (FdoString *) tableName );
 	else
More information about the fdo-commits mailing list
