[fdo-commits] r2654 - in trunk: . Providers/GDAL/Src/Provider Thirdparty
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Mar 7 15:49:29 EST 2007
Author: gregboone
Date: 2007-03-07 15:49:29 -0500 (Wed, 07 Mar 2007)
New Revision: 2654
   trunk/Providers/GDAL/Src/Provider/Makefile.am
   trunk/Thirdparty/Makefile.am
   trunk/Thirdparty/Thirdparty.sh
   trunk/Thirdparty/Thirdparty_gdal.sh
   trunk/Thirdparty/Thirdparty_wms.sh
   trunk/setenvironment.sh
Ticket #5: Update to GDAL 1.4.0
Modified: trunk/Providers/GDAL/Src/Provider/Makefile.am
--- trunk/Providers/GDAL/Src/Provider/Makefile.am	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/Providers/GDAL/Src/Provider/Makefile.am	2007-03-07 20:49:29 UTC (rev 2654)
@@ -118,6 +118,6 @@
   -I../Message/Inc/  \
   -I$(FDO)/Unmanaged/Inc \
   -I$(FDOUTILITIES)/Common/Inc \
-  -I$(FDOGDAL)/include
+  -I$(FDOGDAL)/include
 CXXFLAGS = @CXXFLAGS@ -D__USE_GNU -DLINUX -DLINUX_IA32
Modified: trunk/Thirdparty/Makefile.am
--- trunk/Thirdparty/Makefile.am	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/Thirdparty/Makefile.am	2007-03-07 20:49:29 UTC (rev 2654)
@@ -278,9 +278,10 @@
 thdlibdir = $(prefix)/lib
 thdlib_DATA = \
-  apache/xml-xalan/c/lib/libxalan-c.so.17.0  \
-  apache/xml-xalan/c/lib/libxalanMsg.so.17.0 \
-  apache/xml-xerces/c/lib/libxerces-c.so.25.0
+	apache/xml-xalan/c/lib/libxalan-c.so.17.0  \
+	apache/xml-xalan/c/lib/libxalanMsg.so.17.0 \
+	apache/xml-xerces/c/lib/libxerces-c.so.25.0 \
+	gdal/lib/libgdal.so.1.11.0
 install-data-hook :
 	@ln -s -f $(thdlibdir)/libxalan-c.so.17.0 $(thdlibdir)/libxalan-c.so.17
@@ -289,12 +290,16 @@
 	@ln -s -f $(thdlibdir)/libxalanMsg.so.17.0 $(thdlibdir)/libxalanMsg.so
 	@ln -s -f $(thdlibdir)/libxerces-c.so.25.0 $(thdlibdir)/libxerces-c.so.25
+	@ln -s -f $(thdlibdir)/libgdal.so.1.11.0 $(thdlibdir)/libgdal.so.1
 	@chmod a+x $(thdlibdir)/libxalan-c.so.17
 	@chmod a+x $(thdlibdir)/libxalanMsg.so.17
 	@chmod a+x $(thdlibdir)/libxerces-c.so.25
+	@chmod a+x $(thdlibdir)/libgdal.so.1
 uninstall :
 	@rm -f $(thdlibdir)/libxalan-c.so*
@@ -302,3 +307,4 @@
 	@rm -f $(thdlibdir)/libxerces-c.so*
 	@rm -f $(thdlibdir)/libgdal.so*
Modified: trunk/Thirdparty/Thirdparty.sh
--- trunk/Thirdparty/Thirdparty.sh	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/Thirdparty/Thirdparty.sh	2007-03-07 20:49:29 UTC (rev 2654)
@@ -81,23 +81,41 @@
 popd >& /dev/null
-## Thirdparty_WMS
-pushd . >& /dev/null
-cd gdal
-echo Building GDAL
-cd src
-chmod a+x ./configure
-echo Build GDAL library with the following settings:
-echo     gif support         - internal
-echo     jpeg support        - internal
-echo     png support         - internal
-echo     tiff support        - internal
-echo     geotiff support     - internal
-echo     libz support        - internal
-echo     python support      - no
-echo     OGR support         - no
-echo     postgreSQL support  - no
-./configure --with-gif=internal --with-jpeg=internal --with-png=internal --with-libtiff=internal --with-geotiff=internal --without-ogr --with-pg=no --with-python=no --with-libz=internal
-make
-make install
-popd >& /dev/null
+## Thirdparty_WMS/GDAL
+if test "$FDOGDAL" == "$FDOTHIRDPARTY/gdal"; then
+    pushd . >& /dev/null
+    cd gdal
+    echo Building gdal
+    mkdir -p lib
+    mkdir -p include
+    rm -f lib/*.libgdal.a
+    rm -f lib/*.libgdal.so
+    rm -f lib/*.libgdal.so.1
+    rm -f lib/*.libgdal.so.1.11.0
+    rm -f include/*
+    chmod a+x ./configure
+    echo Build GDAL library with the following settings:
+    echo     gif support         - internal
+    echo     jpeg support        - internal
+    echo     png support         - internal
+    echo     tiff support        - internal
+    echo     geotiff support     - internal
+    echo     libz support        - internal
+    echo     python support      - no
+    echo     OGR support         - no
+    echo     postgreSQL support  - no
+    ./configure --with-gif=internal --with-jpeg=internal --with-png=internal --with-libtiff=internal --with-geotiff=internal --without-ogr --with-pg=no --with-python=no --with-libz=internal
+    make
+    cp -f .libs/libgdal.a lib/
+    cp -f .libs/libgdal.la lib/
+    cp -f .libs/libgdal.so lib/
+    cp -f .libs/libgdal.so.1 lib/
+    cp -f .libs/libgdal.so.1.11.0 lib/
+    cp -f port/*.h include/
+    cp -f gcore/*.h include/
+    cp -f alg/*.h include/
+    cp -f ogr/*.h include/
+    popd >& /dev/null
+else
+    echo "Building of the Thirdparty/GDAL libraries has been skipped. Environment variable FDOGDAL points to a previously installed version of GDAL at $FDOGDAL. This version of GDAL will be used to build the FDO WMS and GDAL providers."
+fi
Modified: trunk/Thirdparty/Thirdparty_gdal.sh
--- trunk/Thirdparty/Thirdparty_gdal.sh	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/Thirdparty/Thirdparty_gdal.sh	2007-03-07 20:49:29 UTC (rev 2654)
@@ -21,23 +21,41 @@
 ## boost_1_32_0, libcurl, openssl, gdal    ##
-## Thirdparty_GDAL
-cd gdal
-echo Building gdal
-cd src
-make
-make install
-popd >& /dev/null
+    cd gdal
+    mkdir -p lib
+    mkdir -p include
+    rm -f include/*
+    make
+    popd >& /dev/null
+else
+fi
Modified: trunk/Thirdparty/Thirdparty_wms.sh
--- trunk/Thirdparty/Thirdparty_wms.sh	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/Thirdparty/Thirdparty_wms.sh	2007-03-07 20:49:29 UTC (rev 2654)
@@ -55,22 +55,41 @@
 mv -f ./libcrypto.a ./lib/linux/libcrypto.a
 popd >& /dev/null
-## Thirdparty_WMS
-cd gdal
-echo Building gdal
-cd src
-make
-popd >& /dev/null
+    cd gdal
+    mkdir -p lib
+    mkdir -p include
+    rm -f include/*
+    make
+    popd >& /dev/null
+else
+fi
Modified: trunk/setenvironment.sh
--- trunk/setenvironment.sh	2007-03-07 17:45:54 UTC (rev 2653)
+++ trunk/setenvironment.sh	2007-03-07 20:49:29 UTC (rev 2654)
@@ -54,7 +54,7 @@
 if test ! -e "$SDEHOME"; then
    echo ""
-   echo "OPTIONAL: The default location for the ArcSDE client SDK files"
+   echo "NOTE: The default location for the ArcSDE client SDK files"
    echo "was not found. The setenvironment script sets the default value to: "
    echo "$FDOTHIRDPARTY/ESRI/ArcSDEClient91/Linux. "
    echo "If you need to build the FDO ArcSDE Provider, modify the "
@@ -63,24 +63,26 @@
    echo ""
 fi
-export FDOGDAL=/usr/local
+export FDOGDAL=$FDOTHIRDPARTY/gdal
-if test ! -e "$FDOGDAL"; then
-   echo ""
-   echo "OPTIONAL: The default location for the GDAL SDK files"
-   echo "was not found. The setenvironment script sets the default value to: "
-   echo "user/local. "
-   echo "If you need to build the FDO GDAL or WMS Providers, modify the "
-   echo "setenvironment.sh script with a valid path and set FDOGDAL to "
-   echo "point to the location of the GDAL SDK files."
-   echo ""
-fi
+echo ""
+echo "NOTE: The setenvironment.sh script sets the installation location for "
+echo "the GDAL SDK files to $FDOTHIRDPARTY/gdal. "
+echo "If this value remains unchanged, the FDO build process will"
+echo "build the version of GDAL located in Thirdparty/gdal and will "
+echo "install the resulting libraries in /usr/local/fdo-3.3.0. The FDO build"
+echo "process will then use that location when building the GDAL and"
+echo "WMS providers. If you wish to build the FDO GDAL or WMS Providers"
+echo "using a previously installed version of GDAL, modify the setenvironment.sh "
+echo "script and set FDOGDAL to point to the existing GDAL installation."
+echo "For example: /user/local (The default GDAL installation path)."
+echo ""
 export FDOMYSQL=$FDOTHIRDPARTY/mysql/rhlinux
 if test ! -e "$FDOMYSQL"; then
    echo ""
-   echo "OPTIONAL: The default location for the MySQL SDK files "
+   echo "NOTE: The default location for the MySQL SDK files "
    echo "$FDOTHIRDPARTY/mysql/rhlinux "
    echo "If you need to build the FDO MySQL Provider, and have chosen not "
@@ -88,7 +90,7 @@
    echo "process, modify the setenvironment.sh script and set FDOMYSQL to point"
    echo "to the location of the MySQL client installation. If you have chosen "
    echo "to install the MySQL client using the RPM install, this environment "
-   echo "variable does not need to be set"
+   echo "variable does not need to be set and this warning can be ignored."
    echo ""
 fi
@@ -96,11 +98,11 @@
 if test ! -e "$FDOODBC"; then
    echo ""
-   echo "OPTIONAL: The default path for the ODBC SDK files was not found. "
+   echo "NOTE: The default path for the ODBC SDK files was not found. "
    echo "The setenvironment script sets the default value to: "
    echo "$FDOODBC"
    echo "If you need to build the ODBC prvovider, modify the setenvironment.sh "
-   echo "script and set FDOODBC to point to the location of the ODBC SDK"
+   echo "script and set FDOODBC to point to the location of the ODBC SDK."
    echo ""
 fi
More information about the fdo-commits mailing list
