[fdo-commits] r828 - branches/3.2.x/Fdo/Docs
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Mar 8 14:52:52 EST 2007
Author: jacklee
Date: 2007-03-08 14:52:52 -0500 (Thu, 08 Mar 2007)
New Revision: 828
   branches/3.2.x/Fdo/Docs/Makefile.am
Install to the docs directory
Modified: branches/3.2.x/Fdo/Docs/Makefile.am
--- branches/3.2.x/Fdo/Docs/Makefile.am	2007-03-07 23:17:08 UTC (rev 827)
+++ branches/3.2.x/Fdo/Docs/Makefile.am	2007-03-08 19:52:52 UTC (rev 828)
@@ -25,19 +25,19 @@
 #install Docs
 install :
-	@if [ ! -d $(INSTALL_DIR)/Docs ]; then mkdir -p $(INSTALL_DIR)/Docs; fi
-	@if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema; fi
-	@if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/Gml ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/Gml; fi
-	@if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/Xlink ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/Xlink; fi
-	@if [ ! -d $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema; fi
-	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema $(INSTALL_DIR)/Docs/XmlSchema
-	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Gml $(INSTALL_DIR)/Docs/XmlSchema/Gml
-	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Xlink $(INSTALL_DIR)/Docs/XmlSchema/Xlink
-	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/XmlSchema $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema
-	@cp -u -f XmlSchema/Gml/CopyRight.txt $(INSTALL_DIR)/Docs/XmlSchema/Gml
-	@cp -u -f XmlSchema/Xlink/CopyRight.txt $(INSTALL_DIR)/Docs/XmlSchema/Xlink
-	@cp -u -f XmlSchema/XmlSchema/base.css $(INSTALL_DIR)/Docs/XmlSchema/XmlSchema
+	@if [ ! -d $(INSTALL_DIR)/docs ]; then mkdir -p $(INSTALL_DIR)/docs; fi
+	@if [ ! -d $(INSTALL_DIR)/docs/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema; fi
+	@if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/Gml ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/Gml; fi
+	@if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/Xlink ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/Xlink; fi
+	@if [ ! -d $(INSTALL_DIR)/docs/XmlSchema/XmlSchema ]; then mkdir -p $(INSTALL_DIR)/docs/XmlSchema/XmlSchema; fi
+	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema $(INSTALL_DIR)/docs/XmlSchema
+	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Gml $(INSTALL_DIR)/docs/XmlSchema/Gml
+	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/Xlink $(INSTALL_DIR)/docs/XmlSchema/Xlink
+	@../Install/XsdInstallPaths/XsdInstallPaths ./XmlSchema/XmlSchema $(INSTALL_DIR)/docs/XmlSchema/XmlSchema
+	@cp -u -f XmlSchema/Gml/CopyRight.txt $(INSTALL_DIR)/docs/XmlSchema/Gml
+	@cp -u -f XmlSchema/Xlink/CopyRight.txt $(INSTALL_DIR)/docs/XmlSchema/Xlink
+	@cp -u -f XmlSchema/XmlSchema/base.css $(INSTALL_DIR)/docs/XmlSchema/XmlSchema
 uninstall :
-	@rm -drf $(INSTALL_DIR)/Docs
+	@rm -drf $(INSTALL_DIR)/docs
More information about the fdo-commits mailing list
