[fdo-commits] r2655 - trunk/www/docs
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Mar 8 16:12:06 EST 2007
Author: gregboone
Date: 2007-03-08 16:12:06 -0500 (Thu, 08 Mar 2007)
New Revision: 2655
   trunk/www/docs/OpenSourceBuild__README.html
Ticket #31: Update FDO documentation
Modified: trunk/www/docs/OpenSourceBuild__README.html
--- trunk/www/docs/OpenSourceBuild__README.html	2007-03-07 20:49:29 UTC (rev 2654)
+++ trunk/www/docs/OpenSourceBuild__README.html	2007-03-08 21:12:06 UTC (rev 2655)
@@ -205,7 +205,7 @@
      This script can be modifed and used to set the correct environment variables
      and PATH settings.
- 10. The build_thirdparty.bat file is ude to build the FDO Thirdparty binaries. The following
+ 10. The build_thirdparty.bat file is used to build the FDO Thirdparty binaries. The following
      is a general guideline on how to use the build_thirdparty.bat build script.
@@ -411,7 +411,7 @@
      Thirdparty SDK components and build tools. (Refer to the Build Notes
      below)
-  3.  Source set environment script (bash or bourne compatible shells)
+  3.  Source the setenvironment.sh script (bash or bourne compatible shells)
       source ./setenvironment.sh
@@ -746,7 +746,7 @@
             initialization file, create your the file with valid values for username,
             password and the service names. Run the unit test by specifying the
             initialization file on the command line when executing the unit tests.
             e.g. ./UnitTestOdbc initfiletest=OdbcInitEx.txt
             NOTE: The initialization file must contain values for service, username and password.
More information about the fdo-commits mailing list
