[fdo-commits] r788 - in branches/3.2.x/Providers/GenericRdbms/Src/UnitTest: . Common Odbc
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Mar 8 16:24:38 EST 2007
Author: brentrobinson
Date: 2007-03-08 16:24:38 -0500 (Thu, 08 Mar 2007)
New Revision: 788
Added:
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/tm_802102.xml
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.h
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.h
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.h
Added another XML test case.
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.cpp	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.cpp	2007-03-08 21:24:38 UTC (rev 788)
@@ -18,6 +18,7 @@
 #include "Pch.h"
 #include "ConnectionUtil.h"
+#include <FdoCommonFile.h>
 #ifndef RDBI_DEF_SA_ORA
 extern    void ut_thread_mutex_init ();
@@ -275,29 +276,32 @@
+char *ConnectionUtil::CommandFilesDirectory;
 ConnectionUtil::ConnectionUtil(void)
 	m_SetupDone = false;
+    CommandFilesDirectory = NULL;
 ConnectionUtil::~ConnectionUtil(void)
+    if (NULL != CommandFilesDirectory)
+        delete[] CommandFilesDirectory;
-wchar_t *ConnectionUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix)
+wchar_t *ConnectionUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix, bool bAddExtraneousSpaces)
     FdoStringP service = UnitTestUtil::GetEnviron("service");
     FdoStringP username = UnitTestUtil::GetEnviron("username");
     FdoStringP password = UnitTestUtil::GetEnviron("password");
     FdoStringP datastore = UnitTestUtil::GetEnviron("datastore", suffix);
-	static wchar_t connectString[200];
-	connectString[0] = L'\0';
+    FdoStringP     connectString;
+	static wchar_t retConnectString[200];
     if (Connection_WithDatastore == pTypeReq)
-        swprintf( connectString,
-            sizeof(connectString)/sizeof(wchar_t),
+        connectString = FdoStringP::Format(
             L"service=%ls;username=%ls;password=%ls;datastore=%ls",
             (FdoString*) service,
             (FdoString*) username,
@@ -305,16 +309,19 @@
             (FdoString*) datastore
 	else
-        swprintf(
-            connectString,
             L"service=%ls;username=%ls;password=%ls;",
             (FdoString*) password
-	return connectString;
+    if ( bAddExtraneousSpaces )
+        connectString = FdoStringP(L"  ") + connectString.Replace(L"=",L"  =  ").Replace(L";",L"  ;  ") + L"  ";
+    wcscpy(retConnectString, connectString);
+	return retConnectString;
 FdoStringP ConnectionUtil::GetEnviron(const char *name, FdoString *suffix)
@@ -358,6 +365,54 @@
         return GetEnv("dsnname");
+    else if (_stricmp(name, "comdir") == 0)
+#ifdef _WIN32
+        char com_dir[MAX_PATH];
+        wchar_t wcom_dir[MAX_PATH];
+        DWORD result;
+        char* last;
+        char buffer[1024];
+        if (NULL == CommandFilesDirectory)
+            strcpy (com_dir, ".\\");
+            result = GetModuleFileName (
+                NULL, // handle to module
+                com_dir, // path buffer
+                MAX_PATH // size of buffer
+            if (0 != result)
+                // scan the string for the last occurrence of a slash
+                last = strrchr (com_dir, '\\');
+                if (NULL != last)
+                    last++; // move past the slash
+                    *last = '\0'; // null terminate it there
+            strcat (com_dir, "com\\");
+            swprintf (wcom_dir, MAX_PATH - 1, L"%hs", com_dir );
+            if ( (!FdoCommonFile::FileExists(wcom_dir)) || (!FdoCommonFile::IsDirectory(wcom_dir)) )
+                sprintf (buffer, "Command files directory '%s' doesn't exist.", com_dir);
+                CPPUNIT_FAIL (buffer);
+            else
+                CommandFilesDirectory = new char[strlen (com_dir) + 1];
+                strcpy (CommandFilesDirectory, com_dir);
+        return (CommandFilesDirectory);
+#else
+	char* getComDir ();
+	return getComDir();
+#endif
     return L"";
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.h
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.h	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/ConnectionUtil.h	2007-03-08 21:24:38 UTC (rev 788)
@@ -72,7 +72,7 @@
 public:
 	ConnectionUtil(void);
-	virtual wchar_t *GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"");
+	virtual wchar_t *GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"", bool bAddExtraneousSpaces = false);
 	virtual FdoStringP GetEnviron( const char *name, FdoString *suffix = L"" );
     virtual FdoStringP GetEnv( const char* name );
 	virtual StaticConnection* NewStaticConnection() = 0;
@@ -85,6 +85,9 @@
 	virtual ~ConnectionUtil(void);
 protected:
 	bool m_SetupDone;
+private:
+    static char *CommandFilesDirectory;
 #endif // CPP_UNIT_CONNECTIONUTIL_H
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoDatastoreTest.cpp	2007-03-08 21:24:38 UTC (rev 788)
@@ -121,6 +121,7 @@
 		connection->SetConnectionString ( connectString);
 		connection->Open();
+        FdoPtr<FdoIConnectionCapabilities> connectionCapabilities = connection->GetConnectionCapabilities();
         FdoPtr<FdoIListDataStores>		pListDataStoresCmd = (FdoIListDataStores*) connection->CreateCommand(FdoCommandType_ListDataStores);
@@ -147,12 +148,15 @@
 				FdoPtr<FdoIDataStorePropertyDictionary> dictionary = pReader->GetDataStoreProperties();
 				ListDatabaseProperties( dictionary );
-				//FdoStringP ltmode = dictionary->GetProperty(L"LtMode");
-				//FdoStringP lckmode = dictionary->GetProperty(L"LockMode");
+                if ( connectionCapabilities->SupportsLongTransactions() )
+    				FdoStringP ltmode = dictionary->GetProperty(L"LtMode");
+    				CPPUNIT_ASSERT_MESSAGE("Wrong LT mode", ( wcscmp( ltmode, get_lt_mode() ) == 0 ));
+       			//FdoStringP lckmode = dictionary->GetProperty(L"LockMode");
 				CPPUNIT_ASSERT_MESSAGE("Description doesn't match", ( wcscmp( string2, UNIT_TEST_DB_DESCRIPTION) == 0));
 				CPPUNIT_ASSERT_MESSAGE("Database is not FDO enabled", bVal == true );
-				//CPPUNIT_ASSERT_MESSAGE("Wrong LT mode", ( wcscmp( ltmode, get_lt_mode() ) == 0 ));
 				//CPPUNIT_ASSERT_MESSAGE("Wrong LT mode", ( wcscmp( lckmode, get_lt_mode()) == 0 ));
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.cpp	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.cpp	2007-03-08 21:24:38 UTC (rev 788)
@@ -991,4 +991,20 @@
+void FdoSchemaTest::Test_Defect802102()
+    try
+        FdoSchemaMappingsP mappings = FdoPhysicalSchemaMappingCollection::Create();
+        mappings->ReadXml( L"tm_802102.xml" );
+        mappings->WriteXml( L"tm_802102_2.xml" );
+        mappings->Clear();
+        mappings->ReadXml( L"tm_802102_2.xml" );
+        mappings->WriteXml( L"tm_802102_3.xml" );
+        UnitTestUtil::CheckOutput( "tm_802102_3.xml", "tm_802102_2.xml" );
+	catch ( FdoException* e )
+		UnitTestUtil::FailOnException( e );
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.h
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.h	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/FdoSchemaTest.h	2007-03-08 21:24:38 UTC (rev 788)
@@ -32,6 +32,7 @@
   CPPUNIT_TEST( OverrideXmlAllTest );
   CPPUNIT_TEST( OverrideXmlErrTest );
   CPPUNIT_TEST( OverrideTablesWithOddAsciiChars );
+  CPPUNIT_TEST( Test_Defect802102 );
   CPPUNIT_TEST_SUITE_END();
 public:
@@ -49,6 +50,7 @@
 	virtual void OverrideXmlAllTest();
 	virtual void OverrideXmlErrTest();
     virtual void OverrideTablesWithOddAsciiChars();
+    void Test_Defect802102();
     // Helper methods:
     virtual void CreateFreshDb();
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.cpp	2007-03-08 21:24:38 UTC (rev 788)
@@ -666,7 +666,7 @@
     // If it does, check if it has the current version. The version is kept in
     // the Schema Attribute dictionary.
     if ( pSchema ) {
         if ( (!FdoSADP(pSchema->GetAttributes())->ContainsAttribute(L"version")) ||
              (wcscmp(FdoSADP(pSchema->GetAttributes())->GetAttributeValue(L"version"), currVersion) != 0) ) {
@@ -679,7 +679,7 @@
             pSchema = NULL;
     if ( !pSchema )
         FdoPtr<FdoIApplySchema>  pCmd = (FdoIApplySchema*) connection->CreateCommand(FdoCommandType_ApplySchema);
@@ -861,9 +861,13 @@
 char *UnitTestUtil::w2a(const wchar_t* wString)
-	char* retVal = NULL;
-	wide_to_multibyte(retVal, wString);
-    return retVal;
+    static char string[2048];
+    FdoCommonThreadMutex mutex;
+    mutex.Enter();
+    wcstombs(string, wString, sizeof(string));
+    mutex.Leave();
+    return string;
 FdoIConnection* UnitTestUtil::GetProviderConnectionObject()
@@ -890,9 +894,9 @@
     return (ret);
-wchar_t *UnitTestUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix)
+wchar_t *UnitTestUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix, bool bAddExtraneousSpaces)
-	return UnitTestUtil::InfoUtilConnection->GetConnectionString(pTypeReq, suffix);
+	return UnitTestUtil::InfoUtilConnection->GetConnectionString(pTypeReq, suffix, bAddExtraneousSpaces);
 void UnitTestUtil::CreateDB(bool addSchema, bool useBaseMapping, FdoString *suffix, int lt_method, bool lt_method_fixed)
@@ -1238,12 +1242,12 @@
     return(connection);
-void UnitTestUtil::DropDb()
+void UnitTestUtil::DropDb(FdoString *suffix)
-    FdoStringP datastore = UnitTestUtil::GetEnviron("datastore");
+    FdoStringP datastore = UnitTestUtil::GetEnviron("datastore", suffix);
     bool bExists = DatastoreExists();
     if (bExists)
@@ -1290,14 +1294,14 @@
     FdoStringP datastore = GetEnviron("datastore", suffix);
     bool found = false;
-    FdoSchemaManagerP mgr = staticConn->CreateSchemaManager();
-    FdoSmPhMgrP ph = mgr->GetPhysicalSchema();
+        FdoSchemaManagerP mgr = staticConn->CreateSchemaManager();
+        FdoSmPhMgrP ph = mgr->GetPhysicalSchema();
-    if ( FdoSmPhOwnerP(ph->FindOwner(datastore, L"", false)) )
-        found = true;
+        if ( FdoSmPhOwnerP(ph->FindOwner(datastore, L"", false)) )
+            found = true;
-    ph = NULL;
-    mgr = NULL;
     staticConn->disconnect();
     delete staticConn;
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Common/UnitTestUtil.h	2007-03-08 21:24:38 UTC (rev 788)
@@ -81,9 +81,9 @@
     static const char* GetEnv( const char* pVar, const char* pDefault );
 	static FdoIConnection* GetProviderConnectionObject();
-	static wchar_t *GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"");
+	static wchar_t *GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"", bool bAddExtraneousSpaces = false);
     static void CreateDB(bool addSchema = true, bool useBaseMapping=false, FdoString *suffix = L"", int lt_method = 0, bool lt_method_fixed = false );
-	static void CreateDB( FdoIConnection* connection, FdoString *username, FdoString *description, FdoString *password, char *schemaType, int local_lt_method );
+	static void CreateDB( FdoIConnection* connection, FdoString *datastore, FdoString *description, FdoString *password, char *schemaType, int local_lt_method );
 	static FdoStringP GetEnviron(const char *name, FdoString *suffix = L"");
 	static void SetProvider( const char *providerName );
@@ -137,7 +137,7 @@
         bool bDelete,
         FdoString *suffix
-	static void DropDb();
+	static void DropDb(FdoString *suffix = L"" );
 	static void DropDb( FdoIConnection *connection, FdoString* pDatastore, FdoString* pPassword, FdoString* pService );
 	// Check if the given connect contains the given datastore.
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.cpp	2007-03-08 21:24:38 UTC (rev 788)
@@ -412,7 +412,7 @@
-wchar_t *OdbcConnectionUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix)
+wchar_t *OdbcConnectionUtil::GetConnectionString(StringConnTypeRequest pTypeReq, FdoString *suffix, bool bAddExtraneousSpaces)
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.h
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.h	2007-03-08 19:52:19 UTC (rev 787)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcConnectionUtil.h	2007-03-08 21:24:38 UTC (rev 788)
@@ -53,7 +53,7 @@
 	virtual StaticConnection* NewStaticConnection ();
 	virtual FdoInsertTest* GetInsertTest ();
 	virtual FdoStringP GetOutputFileName (FdoString* pBaseFileName);
-	virtual wchar_t* GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"");
+	virtual wchar_t* GetConnectionString(StringConnTypeRequest pTypeReq = Connection_WithDatastore, FdoString *suffix = L"", bool bAddExtraneousSpaces = false);
 	virtual const char* GetSuffixTest(){return "_odbc";};
 protected:
Added: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/tm_802102.xml
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/tm_802102.xml	                        (rev 0)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/tm_802102.xml	2007-03-08 21:24:38 UTC (rev 788)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<fdo:DataStore xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:gml="http://www.opengis.net/gml" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:fds="http://fdo.osgeo.org/schemas/fds">
+		<SchemaMapping xmlns:rdb="http://fdordbms.osgeo.org/schemas" xmlns="http://www.autodesk.com/isd/fdo/OracleProvider" provider="Autodesk.Oracle.3.1" name="OverridesA" database="oxy" owner="fdo_br_apply_overrides">
+		<complexType name="OvClassDType" tableMapping="Base">
+			<Table pkeyName="PK_OV_TABLE_C" name="OV_TABLE_C"/>
+			<element name="DataD">
+				<Column name="OV_COL_D" sequenceName="OV_SEQ_1"/>
+			</element>
+		</complexType>
+	</SchemaMapping>
+</fdo:DataStore>
More information about the fdo-commits mailing list
