[fdo-commits] r2670 - in trunk/Providers/SDF/Src: . Provider UnitTest Utils
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Mar 9 14:14:44 EST 2007
Author: badreddinekaroui
Date: 2007-03-09 14:14:44 -0500 (Fri, 09 Mar 2007)
New Revision: 2670
   trunk/Providers/SDF/Src/Makefile.am
   trunk/Providers/SDF/Src/Provider/SDF.vcproj
   trunk/Providers/SDF/Src/Provider/SdfImpExtendedSelect.cpp
   trunk/Providers/SDF/Src/UnitTest/MasterTest.cpp
   trunk/Providers/SDF/Src/UnitTest/MasterTest.h
   trunk/Providers/SDF/Src/UnitTest/UnitTest.vcproj
   trunk/Providers/SDF/Src/Utils/DataValue.h
   trunk/Providers/SDF/Src/Utils/FDOUtils.vcproj
   trunk/Providers/SDF/Src/Utils/FilterExecutor.cpp
   trunk/Providers/SDF/Src/Utils/FilterExecutor.h
   trunk/Providers/SDF/Src/Utils/Makefile.am
   trunk/Providers/SDF/Src/Utils/NullValue.cpp
Merge ticket #32 fix from 2.1.x branch to the trunk
Modified: trunk/Providers/SDF/Src/Makefile.am
--- trunk/Providers/SDF/Src/Makefile.am	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Makefile.am	2007-03-09 19:14:44 UTC (rev 2670)
@@ -35,7 +35,6 @@
   ./Utils/libSDFUtils.la \
   ./Provider/libSDFProviderSrc.la  \
   $(FDO)/Unmanaged/Src/libFDO.la \
-  $(FDO)/Unmanaged/Src/Spatial/libFDOSpatial.la \
   $(FDOUTILITIES)/SQLiteInterface/libSQLiteInterface.la \
   $(FDOTHIRDPARTY)/Sqlite3.1.5/linux/lib/sqlite3.a \
   $(FDOUTILITIES)/Common/libProvidersCommon.la \
Modified: trunk/Providers/SDF/Src/Provider/SDF.vcproj
--- trunk/Providers/SDF/Src/Provider/SDF.vcproj	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Provider/SDF.vcproj	2007-03-09 19:14:44 UTC (rev 2670)
@@ -53,7 +53,7 @@
 				ProgramDataBaseFileName="$(IntDir)/SDFProvider.pdb"
 				WarningLevel="3"
 				Detect64BitPortabilityProblems="true"
-				DebugInformationFormat="4"
+				DebugInformationFormat="3"
 			<Tool
 				Name="VCManagedResourceCompilerTool"
@@ -69,7 +69,7 @@
 				Name="VCLinkerTool"
 				AdditionalDependencies="FDOUtils.lib FDO.lib FDOCommon.lib FDOGeometry.lib FDONLS.lib ProvidersCommon.lib FDOSpatial.lib SQLiteInterface.lib Sqlite3.lib Advapi32.lib"
 				OutputFile="$(OutDir)/SDFProvider.dll"
-				LinkIncremental="2"
+				LinkIncremental="1"
 				AdditionalLibraryDirectories="$(FDO)\Unmanaged\Lib\Win32\Debug\;$(FDOUTILITIES)\Common\Lib\Win32\Debug;..\..\Lib\Win32\Debug;$(FDOTHIRDPARTY)\Sqlite3.1.5\Debug;$(FDOUTILITIES)\SQLiteInterface\Lib\Win32\Debug"
 				IgnoreDefaultLibraryNames="libcmtd.lib"
 				GenerateDebugInformation="true"
Modified: trunk/Providers/SDF/Src/Provider/SdfImpExtendedSelect.cpp
--- trunk/Providers/SDF/Src/Provider/SdfImpExtendedSelect.cpp	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Provider/SdfImpExtendedSelect.cpp	2007-03-09 19:14:44 UTC (rev 2670)
@@ -244,7 +244,7 @@
 		realpath(cpath, cfullpath);
 		mbstowcs(fullpath, cfullpath, 1024);
-		FILE *fp = fopen((const char*)FdoString(fullpath), "r");
+		FILE *fp = fopen((const char*)FdoStringP(fullpath), "r");
 		if( fp )
 			fclose(fp);
Modified: trunk/Providers/SDF/Src/UnitTest/MasterTest.cpp
--- trunk/Providers/SDF/Src/UnitTest/MasterTest.cpp	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/UnitTest/MasterTest.cpp	2007-03-09 19:14:44 UTC (rev 2670)
@@ -1270,3 +1270,74 @@
         TestCommonFail( ex );
+void MasterTest::selectFunctionTest()
+	try
+		FdoPtr<FdoIConnection> conn = CreateConnection();
+		openConnection(conn, SHP_PATH, true);
+		FdoPtr<FdoISelect> select = (FdoISelect*)(conn->CreateCommand(FdoCommandType_Select));
+		select->SetFeatureClassName(L"World_Countries");
+		select->SetFilter(L"Upper(NAME) LIKE '%TU%'");
+		FdoPtr<FdoIReader> rdr = select->Execute();
+		int count = 0;
+		while (rdr->ReadNext())
+			//printf("%ls\n", rdr->GetString(L"NAME"));
+			count++;
+		rdr->Close();
+		//printf("Upper count: %d\n", count);
+		CPPUNIT_ASSERT_MESSAGE("Unexpected number of records returned by a Upper filter", count==14);
+		select->SetFilter(L"Lower(NAME) LIKE '%tu%'");
+		rdr = select->Execute();
+		count = 0;
+			count++;
+		rdr->Close();
+		CPPUNIT_ASSERT_MESSAGE("Unexpected number of records returned by a Lower filter", count==14);
+		select->SetFilter(L"Ceil(Autogenerated_ID) < 10");
+		count = 0;
+			count++;
+		rdr->Close();
+		//printf("Ceil count: %d\n", count);
+		CPPUNIT_ASSERT_MESSAGE("Unexpected number of records returned by a Lower filter", count==9);
+		select->SetFilter(L"Floor(Autogenerated_ID) < 10");
+		count = 0;
+			count++;
+		rdr->Close();
+		//printf("Floor count: %d\n", count);
+		CPPUNIT_ASSERT_MESSAGE("Unexpected number of records returned by a Floor filter", count==9);
+		conn->Close();
+	catch(FdoException *exp )
+		printf("Function test failed: %ls\n", exp->GetExceptionMessage() );
+		exp->Release();
+		CPPUNIT_FAIL("Function test failed");
Modified: trunk/Providers/SDF/Src/UnitTest/MasterTest.h
--- trunk/Providers/SDF/Src/UnitTest/MasterTest.h	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/UnitTest/MasterTest.h	2007-03-09 19:14:44 UTC (rev 2670)
@@ -96,6 +96,7 @@
 	CPPUNIT_TEST(concurencyTest);
     CPPUNIT_TEST(descReadOnly);
     CPPUNIT_TEST(test_aggregates_datetime_string);
+	CPPUNIT_TEST(selectFunctionTest);
     CPPUNIT_TEST_SUITE_END();
     // You may define any private variables that are used in your test
@@ -131,6 +132,7 @@
     void selectSpatialExtentsTest();
     void descReadOnly();
     void test_aggregates_datetime_string();
+	void selectFunctionTest();
 #endif
Modified: trunk/Providers/SDF/Src/UnitTest/UnitTest.vcproj
--- trunk/Providers/SDF/Src/UnitTest/UnitTest.vcproj	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/UnitTest/UnitTest.vcproj	2007-03-09 19:14:44 UTC (rev 2670)
@@ -52,7 +52,7 @@
 				UsePrecompiledHeader="0"
 				WarningLevel="3"
 			<Tool
@@ -67,7 +67,7 @@
 				Name="VCLinkerTool"
 				AdditionalDependencies="cppunitd.lib FDO.lib FDOCommon.lib FDOGeometry.lib FDOSpatial.lib ProvidersCommon.lib"
 				OutputFile="$(OutDir)/UnitTest.exe"
 				AdditionalLibraryDirectories="&quot;$(FDOTHIRDPARTY)\CppUnit\lib\&quot;;&quot;$(FDO)\Unmanaged\Lib\Win32\Debug&quot;;&quot;$(FDOUTILITIES)\TestCommon\Lib\Win32\Debug&quot;;&quot;$(FDOUTILITIES)\Common\Lib\Win32\Debug&quot;"
Modified: trunk/Providers/SDF/Src/Utils/DataValue.h
--- trunk/Providers/SDF/Src/Utils/DataValue.h	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/DataValue.h	2007-03-09 19:14:44 UTC (rev 2670)
@@ -18,16 +18,15 @@
 #define MAX_STRING_LENGTH 256
-enum DataValueType
-    Dvt_Int64,
-    Dvt_Double,
-    Dvt_String,
-    Dvt_Boolean,
-    Dvt_DateTime,
-	Dvt_Null
+#define DataValueType		FdoDataType
+#define Dvt_Boolean			FdoDataType_Boolean
+#define Dvt_Int64			FdoDataType_Int64
+#define Dvt_Double			FdoDataType_Double
+#define Dvt_String			FdoDataType_String
+#define Dvt_DateTime		FdoDataType_DateTime
+#define Dvt_Null			(-1) // A null value indicator
 //forward declare
 class DataValuePool;
Modified: trunk/Providers/SDF/Src/Utils/FDOUtils.vcproj
--- trunk/Providers/SDF/Src/Utils/FDOUtils.vcproj	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/FDOUtils.vcproj	2007-03-09 19:14:44 UTC (rev 2670)
@@ -41,7 +41,7 @@
 			<Tool
 				Name="VCCLCompilerTool"
 				Optimization="0"
-				AdditionalIncludeDirectories="$(FDO)\Unmanaged\Inc;$(FDO)\Unmanaged\Src\NLS"
+				AdditionalIncludeDirectories="&quot;$(FDO)\Unmanaged\Inc&quot;;&quot;$(FDO)\Unmanaged\Src\NLS&quot;;&quot;$(FDOUTILITIES)\Common\inc&quot;"
 				PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;FDOUTILS_EXPORTS;GISSPATIAL_STATIC;_CRT_SECURE_NO_DEPRECATE"
 				MinimalRebuild="true"
 				BasicRuntimeChecks="3"
@@ -53,7 +53,7 @@
 				ProgramDataBaseFileName="$(IntDir)/FDOUtils.pdb"
 				WarningLevel="3"
 			<Tool
@@ -114,7 +114,7 @@
 				EnableIntrinsicFunctions="true"
 				FavorSizeOrSpeed="1"
 				OmitFramePointers="true"
 				PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;FDOUTILS_EXPORTS;GISSPATIAL_STATIC;_CRT_SECURE_NO_DEPRECATE"
 				RuntimeLibrary="2"
 				TreatWChar_tAsBuiltInType="true"
Modified: trunk/Providers/SDF/Src/Utils/FilterExecutor.cpp
--- trunk/Providers/SDF/Src/Utils/FilterExecutor.cpp	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/FilterExecutor.cpp	2007-03-09 19:14:44 UTC (rev 2670)
@@ -26,8 +26,11 @@
 #include "DateTimeValue.h"
 #include "NullValue.h"
 #include <FdoSpatial.h>
+#include "FdoCommonMiscUtil.h"
+#include <wctype.h>
+#include <malloc.h>
+#include <math.h>
 FilterExecutor::FilterExecutor(FdoIFeatureReader* featureReader, PropertyIndex* propIndex, FdoIdentifierCollection* compIdents, FdoClassDefinition* classDef)
     //don't think we need an addref since the FeatureReader owns us.
@@ -437,11 +440,129 @@
         return ExecuteARGB(expr);
+    else if (wcscmp (name, FDO_FUNCTION_CEIL) == 0 || wcscmp (name, FDO_FUNCTION_FLOOR) == 0)
+        FdoPtr<FdoExpressionCollection> args = expr.GetArguments ();
+        if (args->GetCount () != 1)
+            throw FdoException::Create (FdoException::NLSGetMessage(FDO_NLSID(FDO_75_INVALID_NUM_ARGUMENTS), expr.GetName(), 1, args->GetCount()));
+        FdoPtr<FdoExpression> left = args->GetItem (0);
+        left->Process (this);
+        DataValue* argLeft = m_retvals.pop ();
+		ProcessFunctionCeilFloor( name, argLeft );
+		m_pPool->RelinquishDataValue(argLeft);
+    else if (wcscmp (name, FDO_FUNCTION_LOWER) == 0)
+        if (FdoDataType_String != argLeft->GetType ())
+            throw FdoException::Create (FdoException::NLSGetMessage(FDO_NLSID(FDO_88_INVALID_FUNCTION_ARG_TYPE), 1, name, FdoCommonMiscUtil::FdoDataTypeToString(argLeft->GetType()), FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_String)));
+        if ( argLeft->GetType() == Dvt_Null  )
+            m_retvals.push ( m_pPool->ObtainNullValue() );
+        else
+            FdoString* arg = argLeft->GetAsString();
+            size_t len = wcslen (arg) + 1;
+            wchar_t* res = new wchar_t[len];
+            wcscpy (res, arg);
+            for (size_t i = 0; i < len; i++)
+                res[i] = towlower (res[i]);
+            m_retvals.push (m_pPool->ObtainStringValue (res,true) );
+    else if (wcscmp (name, FDO_FUNCTION_UPPER) == 0)
+        else
+                res[i] = towupper (res[i]);
+            m_retvals.push (m_pPool->ObtainStringValue ( res, true ));
     else
-        throw FdoException::Create(L"Function not supported");
+        throw FdoException::Create (FdoException::NLSGetMessage(FDO_NLSID(FDO_89_UNSUPPORTED_FUNCTION), name));
+void FilterExecutor::ProcessFunctionCeilFloor( FdoString *name, DataValue* argLeft )
+    FdoDataType		type = argLeft->GetType ();
+	// TODO: Int16 and Int32 are handled by Int64Value. Therefore for those types the retuned type will be always FdoDataType_Int64
+	//       We need to define a specific Value classes for these types.
+    if ((FdoDataType_Double != type) && (FdoDataType_Single != type) && (FdoDataType_Decimal != type) && (FdoDataType_Int64 != type) &&
+	    (FdoDataType_Int32 != type) && (FdoDataType_Int16 != type) )
+		FdoStringP	allowedTypes =	FdoStringP(FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_Double))  + L" / " +
+									FdoStringP(FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_Single))  + L" / " +
+									FdoStringP(FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_Decimal)) + L" / " +
+									FdoStringP(FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_Int32))   + L" / " +
+									FdoStringP(FdoCommonMiscUtil::FdoDataTypeToString(FdoDataType_Int16));
+																FdoCommonMiscUtil::FdoDataTypeToString(type),
+	  														    (FdoString *)allowedTypes));
+	else
+        else
+            double d = 0.0;
+            if (FdoDataType_Double == type || FdoDataType_Decimal == type)
+                d = argLeft->GetAsDouble();
+            else if ( FdoDataType_Single == type )
+			else if ( FdoDataType_Int32 == type || FdoDataType_Int64 == type )
+				d = argLeft->GetAsInt64();
+			else if ( FdoDataType_Int16 == type )
+			d = ( wcscmp (name, FDO_FUNCTION_CEIL) == 0) ? ceil (d) : floor (d);
+            m_retvals.push (m_pPool->ObtainDoubleValue (d));
 FdoPropertyDefinition* GetProperty(FdoClassDefinition* cls, FdoString* propName )
 	FdoPropertyDefinition* prop = FdoPtr<FdoPropertyDefinitionCollection>(cls->GetProperties())->FindItem( propName );
@@ -679,7 +800,7 @@
 void FilterExecutor::ProcessGeometryValue(FdoGeometryValue& expr)
-    //m_tokens.push_back(new GeometryVal());
+    //m_tokens.push(new GeometryVal());
     printf("geometry value\n");
Modified: trunk/Providers/SDF/Src/Utils/FilterExecutor.h
--- trunk/Providers/SDF/Src/Utils/FilterExecutor.h	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/FilterExecutor.h	2007-03-09 19:14:44 UTC (rev 2670)
@@ -151,6 +151,8 @@
 	void PushIdentifierValue(FdoIFeatureReader* reader, FdoString* name, FdoDataType type );
+	void ProcessFunctionCeilFloor( FdoString *name, DataValue* argLeft );
     void ExecuteARGB(FdoFunction& function);
     //pattern matching
Modified: trunk/Providers/SDF/Src/Utils/Makefile.am
--- trunk/Providers/SDF/Src/Utils/Makefile.am	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/Makefile.am	2007-03-09 19:14:44 UTC (rev 2670)
@@ -55,6 +55,7 @@
   -I../../Inc \
   -I$(FDO)/Unmanaged/Inc \
   -I$(FDO)/Unmanaged/Src/Nls \
+  -I$(FDOUTILITIES)/Common/Inc \
   -I/usr/include
 CXXFLAGS = @CXXFLAGS_SDF@ -DSQLITE
Modified: trunk/Providers/SDF/Src/Utils/NullValue.cpp
--- trunk/Providers/SDF/Src/Utils/NullValue.cpp	2007-03-09 19:07:28 UTC (rev 2669)
+++ trunk/Providers/SDF/Src/Utils/NullValue.cpp	2007-03-09 19:14:44 UTC (rev 2670)
@@ -34,7 +34,7 @@
 DataValueType NullValue::GetType()
-    return Dvt_Null;
+    return (DataValueType)Dvt_Null;
 DataValue* NullValue::Negate(DataValuePool* pPool)
More information about the fdo-commits mailing list
