[fdo-commits] r2696 - in trunk/Fdo/Python: Inc Inc/Common Src/Common
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Mar 19 19:59:49 EDT 2007
Author: gregboone
Date: 2007-03-19 19:59:49 -0400 (Mon, 19 Mar 2007)
New Revision: 2696
Added:
   trunk/Fdo/Python/Inc/Common/StringCollection.h
   trunk/Fdo/Python/Inc/Common/Vector.h
   trunk/Fdo/Python/Inc/stdafx.h
   trunk/Fdo/Python/Src/Common/StringBuffer.cpp
Ticket #39: Add Linux Makefile Support -- Work In Progress
Added: trunk/Fdo/Python/Inc/Common/StringCollection.h
--- trunk/Fdo/Python/Inc/Common/StringCollection.h	                        (rev 0)
+++ trunk/Fdo/Python/Inc/Common/StringCollection.h	2007-03-19 23:59:49 UTC (rev 2696)
@@ -0,0 +1,281 @@
+#ifndef FDO_STRING_COLLECTION_H
+#define FDO_STRING_COLLECTION_H		1
+// Copyright (C) 2004-2006  Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#ifdef _WIN32
+#pragma once
+#endif
+#include <Common/Collection.h>
+/// \cond DOXYGEN-IGNORE
+// An element in a string collection.
+// This class is just a wrapper around a string.
+class FdoStringElement : public FdoDisposable
+public:
+    /// Create from a string.
+	static FdoStringElement* Create( FdoStringP src )
+	    return new FdoStringElement(src);
+    /// Operator to copy from a "managed" string.
+	FdoStringElement& operator=( const FdoStringP& src )
+	    mString = src;
+        return(*this);
+    /// Operator to copy from an "unmanaged" string.
+	FdoStringElement& operator=( FdoString* wString )
+	    mString = wString;
+        return(*this);
+    /// Returns the string that this element represents.
+	FdoStringP GetString()
+	    return mString;
+protected:
+    FdoStringElement() {}
+    FdoStringElement( FdoStringP src )
+	    mString = src;
+    virtual ~FdoStringElement(void)
+private:
+    FdoStringP mString;
+typedef FdoPtr<FdoStringElement> FdoStringElementP;
+/// \endcond
+/// \brief
+/// FdoStringCollection is a collection of strings.
+class FdoStringCollection : public FdoCollection<FdoStringElement,FdoException>
+public:
+    /// \brief
+    /// Constructs a new empty string collection
+    /// \return
+    /// Returns FdoStringCollection
+	FDO_API_COMMON static FdoStringCollection* Create(void);
+    /// \brief
+    /// Creates a copy of string collection
+    /// \param src
+    /// Input the source collection
+    /// \return
+	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringCollection& src);
+    /// \brief
+    /// \param src
+    /// Input pointer to the source collection
+    /// \return
+	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringCollection* src);
+    /// \brief
+    /// Creates a string collection that is tokenize from a string.
+    /// The collection contains an element for each token.
+    /// \param inString
+    /// Input the string to tokenize.
+    /// \param delimiters
+    /// Input list of single character token delimiters.
+    /// \param bNullTokens
+    /// true: include zero-length tokens in the collection.
+    /// false: exclude zero-length tokens
+    /// \return
+	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
+    /// \brief
+    /// Gets the string in the collection at the specified index. Throws an invalid argument exception if the index is out of range.
+    /// \param index
+    /// Input index
+    /// \return
+    /// Returns the string in the collection at the specified index
+	FDO_API_COMMON FdoString* GetString(int index) const;
+    /// \brief
+    /// Appends the strings from src to the end of this collection.
+    /// \param src
+	FDO_API_COMMON void Append( const FdoStringCollection& src);
+    /// \brief
+    /// Adds a string to the end of this collection.
+    /// \param src
+	FDO_API_COMMON int Add( FdoStringP src);
+    /// \brief
+    /// Given a string, returns its position in this collection.
+    /// \param value
+    /// Input the string to check
+    /// \param caseSensitive
+    /// Input if true, do a case-sensitive comparison
+    /// of the string and members of this collection. If false, the comparison
+    /// is case-insensitive.
+    /// \return
+    /// Returns the string's position. Returns -1 if the string
+    /// is not in this collection.
+    FDO_API_COMMON virtual FdoInt32 IndexOf(FdoStringP value, FdoBoolean caseSensitive = true) const;
+    /// \brief
+    /// Concatenates the strings in this collection.
+    /// \param separator
+    /// Input separate each collection string with this separator string.
+    /// \return
+    /// Returns the concatenation if all strings in this collection.
+    /// Returns a concatenation of all the strings in this collection,
+    /// separated by the given separator.
+	FDO_API_COMMON FdoStringP ToString( FdoString* separator );
+protected:
+	FDO_API_COMMON FdoStringCollection(void);
+	FDO_API_COMMON FdoStringCollection( const FdoStringCollection& src);
+	FDO_API_COMMON FdoStringCollection( const FdoStringCollection* src);
+	FDO_API_COMMON FdoStringCollection( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
+	FDO_API_COMMON virtual ~FdoStringCollection(void);
+/// \endcond
+    FDO_API_COMMON virtual void Dispose()
+        delete this;
+private:
+//typedef FdoPtr<FdoStringCollection> FdoStringsP;
+/// \brief
+/// FdoStringsP is a FdoPtr on FdoStringCollection, provided for convenience.
+class FdoStringsP : public FdoPtr<FdoStringCollection>
+public:
+    FdoStringsP() {}
+    FdoStringsP( const FdoStringsP& src )
+        : FdoPtr<FdoStringCollection>(src)
+    FdoStringsP( FdoStringCollection* src )
+    ~FdoStringsP() {}
+    /// \brief
+    /// Copies a string collection
+    /// \param src
+    /// \return
+    /// Returns the copy FdoStringCollection
+	FDO_API_COMMON FdoStringCollection* operator=( FdoStringCollection* src );
+    /// \brief
+    /// Concatenates two string collections
+    /// \param coll2
+    /// Input collection to append to the end of this collection
+    /// \return
+    /// Returns the concatenated FdoStringCollection
+	FDO_API_COMMON const FdoStringsP operator+( const FdoStringsP coll2 ) const;
+    /// \brief
+    /// Concatenates a string collection and a string
+    /// \param str2
+    /// Input stromg to append to the end of this collection
+    /// \return
+	FDO_API_COMMON const FdoStringsP operator+( const FdoStringP str2 ) const;
+    /// \brief
+    /// \param coll2
+    /// \return
+	FDO_API_COMMON FdoStringsP operator+=( FdoStringsP coll2 );
+    /// \brief
+    /// \param str2
+    /// \return
+	FDO_API_COMMON FdoStringsP operator+=( FdoStringP str2 );
+#endif
Added: trunk/Fdo/Python/Inc/Common/Vector.h
--- trunk/Fdo/Python/Inc/Common/Vector.h	                        (rev 0)
+++ trunk/Fdo/Python/Inc/Common/Vector.h	2007-03-19 23:59:49 UTC (rev 2696)
@@ -0,0 +1,408 @@
+#ifndef FDO_VECTOR_H
+#define FDO_VECTOR_H		1
+#ifdef _WIN32
+#pragma once
+#endif
+/// \brief
+/// An element in a vector.
+/// This class is just a ref-countable wrapper around a double.
+class FdoVectorElement : public FdoDisposable
+public:
+    /// \brief
+    /// Creates a vector element.
+    /// \param value
+    /// Input the value to assign the element
+    /// \return
+    /// Returns FdoProviderNameTokens
+	FDO_API_COMMON static FdoVectorElement* Create( double value )
+	    return new FdoVectorElement(value);
+    /// \brief
+    /// Gets the element value.
+    /// \return
+    /// Returns the value that this element represents.
+	FDO_API_COMMON double  GetValue()
+	    return mValue;
+    /// \brief
+    /// Sets the element value.
+    /// \param value
+    FDO_API_COMMON void SetValue( double value )
+        mValue = value;
+    /// \brief
+    /// Gets the element value in string format.
+    /// \return
+    FDO_API_COMMON FdoStringP GetString();
+protected:
+    FdoVectorElement() {}
+    FdoVectorElement( double value )
+	    mValue = value;
+    virtual ~FdoVectorElement(void)
+/// \endcond
+private:
+    double mValue;
+typedef FdoPtr<FdoVectorElement> FdoVectorElementP;
+/// \brief
+/// FdoVector is a one-dimensional collection of numbers.
+class FdoVector : public FdoCollection<FdoVectorElement,FdoException>
+public:
+    /// \brief
+    /// Constructs a new empty vector
+    /// \return
+    /// Returns FdoVector
+	FDO_API_COMMON static FdoVector* Create(void);
+    /// \brief
+    /// Creates a copy of a vector
+    /// \param src
+    /// Input pointer to the source vector
+    /// \return
+	FDO_API_COMMON static FdoVector* Create( const FdoVector* src);
+    /// \brief
+    /// Creates a vector that is tokenize from a string.
+    /// The vector contains an element for each token. Non-numberic tokens
+    /// become 0.0.
+    /// true: include zero-length tokens in the vector ( as 0.0 ).
+    /// \return
+	FDO_API_COMMON static FdoVector* Create( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
+    /// \brief
+    /// Gets the number in the vector at the specified index. Throws an invalid argument exception if the index is out of range.
+    /// \param index
+    /// Input index
+    /// \return
+    /// Returns the number in the vector at the specified index
+	FDO_API_COMMON double GetValue(int index) const;
+    /// \brief
+    /// Appends the numbers from src to the end of this vector.
+    /// \param src
+	FDO_API_COMMON void Append( const FdoVector* src);
+    /// \brief
+    /// Adds a number to the end of this vector.
+    /// \param value
+	FDO_API_COMMON int Add( double value );
+    /// \brief
+    /// Concatenates the numbers in this collection.
+    /// Input separate each collection number with this separator string.
+    /// \return
+    /// Returns the concatenation of all numbers in this vector,
+    /// separated by the given separator..
+protected:
+	FdoVector(void);
+	FdoVector( const FdoVector* src);
+	FdoVector( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
+	virtual ~FdoVector(void);
+/// \endcond
+        delete this;
+private:
+/// \brief
+/// FdoVectorP is a FdoPtr on FdoVector, provided for convenience. It
+/// also provides vector arithmetic and comparison operators.
+class FdoVectorP : public FdoPtr<FdoVector>
+public:
+    /// \brief
+    /// Vector FdoPtr default constructor
+    /// \return
+    /// Returns FdoVectorP
+    FDO_API_COMMON FdoVectorP() {}
+    /// \brief
+    /// Vector FdoPtr copy constructor
+    /// \param src
+    /// Input the source vector as a FdoPtr
+    /// \return
+    FDO_API_COMMON FdoVectorP( const FdoVectorP& src )
+        : FdoPtr<FdoVector>(src)
+    /// \brief
+    /// \param src
+    /// Input the source vector as an object pointer
+    /// \return
+    FDO_API_COMMON FdoVectorP( FdoVector* src )
+    /// \brief
+    /// Vector FdoPtr destructor
+    FDO_API_COMMON ~FdoVectorP() {}
+    /// \brief
+    /// Copies a vector
+    /// \param src
+    /// \return
+    /// Returns a new copy of the input vector
+	FDO_API_COMMON FdoVector* operator=( FdoVector* src );
+    /// \brief
+    /// Adds two vectors, by adding each individual element. The output vector has
+    /// the same length as the longer of the input vectors. If one input
+    /// vector is shorter than the other, it is treated as if it
+    /// is padded with zeros.
+    /// \param vec2
+    /// Input vector to add to this vector
+    /// \return
+    /// Returns the sum of the two input vectors
+	FDO_API_COMMON const FdoVectorP operator+( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Subtracts two vectors, by subtracting each individual element. The output vector has
+    /// \param vec2
+    /// Input vector to subtract from this vector
+    /// \return
+    /// Returns the difference of the two input vectors
+	FDO_API_COMMON const FdoVectorP operator-( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Adds a vector, to this vector, by adding each individual element. The output vector has
+    /// \param vec2
+    /// \return
+	FDO_API_COMMON FdoVectorP operator+=( const FdoVectorP vec2 );
+    /// \brief
+    /// Subtracts a vector, from this vector, by subtracting each individual element. The output vector has
+    /// \param vec2
+    /// \return
+	FDO_API_COMMON FdoVectorP operator-=( const FdoVectorP vec2 );
+    /// \brief
+    /// Compare two vectors for equality. The vectors are equal
+    /// if all of their elements are equal. If one vector is shorter than the other
+    /// then it is treated as if it were padded with zeros to the length of the
+    /// other vector.
+    /// \param vec2
+    /// Input vector to compare this vector
+    /// \return
+    /// Returns true if the two vectors are identical.
+	FDO_API_COMMON FdoBoolean operator==( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Compare two vectors for difference. The vectors are differnt
+    /// if one of their elements is differnt. If one vector is shorter than the other
+    /// other vector.
+    /// \param vec2
+    /// \return
+    /// Returns true if the two vectors are different.
+	FDO_API_COMMON FdoBoolean operator!=( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Checks if this vector is greater than a second vector.
+    /// Comparison is done by comparing the first element in each vector.
+    /// If they are equal, then the second element is check and so on until
+    /// a differing element is found. If one vector is shorter than the other
+    /// other vector.
+    /// \param vec2
+    /// \return
+    /// Returns true if this vector is greater than vec2.
+	FDO_API_COMMON FdoBoolean operator>( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Checks if this vector is greater or equal to a second vector.
+    /// other vector.
+    /// \param vec2
+    /// \return
+    /// Returns true if this vector is greater or equal vec2.
+	FDO_API_COMMON FdoBoolean operator>=( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Checks if this vector is less than a second vector.
+    /// other vector.
+    /// \param vec2
+    /// \return
+    /// Returns true if this vector is less than vec2.
+	FDO_API_COMMON FdoBoolean operator<( const FdoVectorP vec2 ) const;
+    /// \brief
+    /// Checks if this vector is less than or equal to a second vector.
+    /// other vector.
+    /// \param vec2
+    /// \return
+    /// Returns true if this vector is less than or equal vec2.
+	FDO_API_COMMON FdoBoolean operator<=( const FdoVectorP vec2 ) const;
+protected:
+    /// General function to do the vector comparisons.
+    FdoBoolean Compare( const FdoVectorP vec2, FdoBoolean lt, FdoBoolean eq, FdoBoolean gt ) const;
+/// \endcond
+#endif
Modified: trunk/Fdo/Python/Inc/stdafx.h
--- trunk/Fdo/Python/Inc/stdafx.h	2007-03-19 19:47:09 UTC (rev 2695)
+++ trunk/Fdo/Python/Inc/stdafx.h	2007-03-19 23:59:49 UTC (rev 2696)
@@ -20,24 +20,13 @@
 // are changed infrequently
-#pragma once
+#ifdef WIN32
+#pragma once
 #define WIN32_LEAN_AND_MEAN		// Exclude rarely-used stuff from Windows headers
-#include <string.h>
 #include <windows.h>
-#include <stdio.h>
-//#if defined(_DEBUG)
-//#define _DEBUG_WAS_DEFINED
-//#undef _DEBUG
-//#pragma message ("Compiling Python header files in Release mode.")
-//#endif
+#endif
-//#include <Python.h>
-//#ifdef _DEBUG_WAS_DEFINED
-//#define _DEBUG
-//#undef _DEBUG_WAS_DEFINED
-//#endif
+#include <string.h>
+#include <stdio.h>
Modified: trunk/Fdo/Python/Src/Common/StringBuffer.cpp
--- trunk/Fdo/Python/Src/Common/StringBuffer.cpp	2007-03-19 19:47:09 UTC (rev 2695)
+++ trunk/Fdo/Python/Src/Common/StringBuffer.cpp	2007-03-19 23:59:49 UTC (rev 2696)
@@ -33,7 +33,11 @@
 	m_lCapacity = (long)wcslen(str) * 2;
 	m_pBuffer = this->createEmptyBuffer( m_lCapacity );
-    wcscpy_s(m_pBuffer, m_lCapacity, str);
+#ifdef WIN32
+	wcscpy_s(m_pBuffer, m_lCapacity, str);
+#else
+	wcscpy(m_pBuffer, str);
+#endif
 StringBuffer::StringBuffer( unsigned long initCapacity )
More information about the fdo-commits mailing list
