[fdo-commits] r2701 - trunk
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Mar 20 17:37:55 EDT 2007
Author: gregboone
Date: 2007-03-20 17:37:53 -0400 (Tue, 20 Mar 2007)
New Revision: 2701
   trunk/OpenSourceBuild__README.txt
Ticket #39 - Add Python Wrappers for FDO API (Documentation Update)
Modified: trunk/OpenSourceBuild__README.txt
--- trunk/OpenSourceBuild__README.txt	2007-03-20 17:08:00 UTC (rev 2700)
+++ trunk/OpenSourceBuild__README.txt	2007-03-20 21:37:53 UTC (rev 2701)
@@ -579,10 +579,10 @@
      ** These variables are maintained in the setenvironment.sh script.
-     In order to build the FDO Python Wrappers. Build and install the FDO
+     In order to build the FDO Python Wrappers, build and install the FDO
      libraries. Once the install is complete, run the
      [FDO OpenSource]/Fdo/Python/build_linux.sh script.
-     The Python components wil be installed in /usr/local/fdo-3.3.0/lib
+     The Python components will be installed in /usr/local/fdo-3.3.0/lib
   8. NOTE: To run the unit test, you must set LD_LIBRARY_PATH as follows:
More information about the fdo-commits mailing list
