[fdo-commits] r2703 - in trunk: Providers/GenericRdbms/Inc/Rdbi Providers/GenericRdbms/Src/MySQL/Driver Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph Providers/GenericRdbms/Src/Rdbi Providers/GenericRdbms/Src/UnitTest/Common Providers/GenericRdbms/Src/UnitTest/MySql Utilities/SchemaMgr/Src/Sm/Ph
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Mar 21 16:54:55 EDT 2007
Author: romicadascalescu
Date: 2007-03-21 16:54:55 -0400 (Wed, 21 Mar 2007)
New Revision: 2703
   trunk/Providers/GenericRdbms/Inc/Rdbi/proto.h
   trunk/Providers/GenericRdbms/Src/MySQL/Driver/fetch.c
   trunk/Providers/GenericRdbms/Src/MySQL/Driver/fre_cursor.c
   trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.cpp
   trunk/Providers/GenericRdbms/Src/Rdbi/disconnect.c
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.cpp
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.h
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationUpdateTest.h
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp
   trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoInsertTest.cpp
   trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoUpdateTest.cpp
   trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
Ticket #48 Fixed some memory leaks on MySQL provider
Modified: trunk/Providers/GenericRdbms/Inc/Rdbi/proto.h
--- trunk/Providers/GenericRdbms/Inc/Rdbi/proto.h	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Inc/Rdbi/proto.h	2007-03-21 20:54:55 UTC (rev 2703)
@@ -499,6 +499,7 @@
 int rdbi_autocommit_on (rdbi_context_def *context);
 int rdbi_autocommit_off (rdbi_context_def *context);
 int rdbi_autocommit_mode (rdbi_context_def *context);
+int rdbi_free_all(rdbi_context_def *context);
 #endif /* INC_RDBI_PROTO_H */
Modified: trunk/Providers/GenericRdbms/Src/MySQL/Driver/fetch.c
--- trunk/Providers/GenericRdbms/Src/MySQL/Driver/fetch.c	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/MySQL/Driver/fetch.c	2007-03-21 20:54:55 UTC (rev 2703)
@@ -36,6 +36,7 @@
                 FreeGeometry (cursor->redefines[i].geometry);
                 cursor->redefines[i].geometry = (void*)NULL;
+                *((char**)(cursor->redefines[i].original)) = NULL;
             if (0 != *(cursor->defines[i].is_null))
@@ -97,7 +98,8 @@
 						// helps the caller to handle the TEXT columns.
 						unsigned long	*size = curs->defines[i].length;
 						char			*address = (char *)curs->defines[i].buffer;
-						address[*size] = '\0';
+						if (curs->redefines == NULL || curs->redefines[i].orig_type != MYSQL_TYPE_GEOMETRY)
+							address[*size] = '\0';
Modified: trunk/Providers/GenericRdbms/Src/MySQL/Driver/fre_cursor.c
--- trunk/Providers/GenericRdbms/Src/MySQL/Driver/fre_cursor.c	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/MySQL/Driver/fre_cursor.c	2007-03-21 20:54:55 UTC (rev 2703)
@@ -30,9 +30,9 @@
         for (i = 0; i < cursor->define_count; i++)
             if ((void*)NULL != cursor->redefines[i].geometry)
-#pragma message ("ToDo: Investigate why it leads to a crash in case the geometry is released.")
-            // FreeGeometry (cursor->redefines[i].geometry);
+                FreeGeometry (cursor->redefines[i].geometry);
         free (cursor->redefines);
         cursor->redefines = (mysql_define_def *)NULL;
Modified: trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.cpp
--- trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/ColumnGeom.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -38,6 +38,7 @@
 				mSRID = gdbiResult->GetInt64(L"srid", NULL, NULL);
 		gdbiResult->End();
+        delete gdbiResult;
 	return mSRID;
Modified: trunk/Providers/GenericRdbms/Src/Rdbi/disconnect.c
--- trunk/Providers/GenericRdbms/Src/Rdbi/disconnect.c	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/Rdbi/disconnect.c	2007-03-21 20:54:55 UTC (rev 2703)
@@ -51,6 +51,7 @@
 #include    <Inc/Nls/rdbi_msg.h>
 #include <Inc/debugext.h>
 #include <Inc/ut.h>         /* ut_vm_free()             */
+#include <Inc/Rdbi/proto.h>
 #include <Inc/Rdbi/context.h>
 #include "global.h"         /* rdbi global area         */
@@ -74,6 +75,7 @@
+    rdbi_free_all(context);
     context->rdbi_last_status = (*(context->dispatch.disconnect))(context->drvr, &context->rdbi_cnct->vendor_data);
     context->rdbi_cnct->in_use = FALSE;              /* mark as available    */
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.h	2007-03-21 20:54:55 UTC (rev 2703)
@@ -46,12 +46,12 @@
     virtual void  set_provider() {};
 	static FdoPropertyValue* AddNewProperty( FdoPropertyValueCollection* propertyValues, const wchar_t *name );
-    void TestSchema ();
-    void TestOverrides ();
-    void TestOverrideDefaults ();
-    void TestOverrideErrors ();
-    void TestLT();
-    void TestConfigDoc();
+    virtual void TestSchema ();
+    virtual void TestOverrides ();
+    virtual void TestOverrideDefaults ();
+    virtual void TestOverrideErrors ();
+    virtual void TestLT();
+    virtual void TestConfigDoc();
     void DeleteAcadSchema( FdoIConnection* connection );
 	void DeleteLandSchema( FdoIConnection* connection );
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -55,6 +55,7 @@
 		pDelCmd->Execute();
 		connection->Close();
+    catch(FdoException* e) {e->Release();}
     catch(...) { }
 	UnitTestUtil::CreateDB(false, false, DB_SUFFIX);
@@ -87,13 +88,15 @@
         // (re)create the schema
        // FdoPtr<FdoFeatureSchemaCollection> pSchemas = FdoFeatureSchemaCollection::Create(NULL);
-	    FdoFeatureSchema* pTestSchema = FdoFeatureSchema::Create( L"AssociationSchema", L"Test Association schema" );
+	    FdoPtr<FdoFeatureSchema> pTestSchema = FdoFeatureSchema::Create( L"AssociationSchema", L"Test Association schema" );
        // pSchemas->Add( pTestSchema );
-        FdoClassDefinition*    pfeatureclass;
+        FdoPtr<FdoClassDefinition>    pfeatureclass;
         FdoPtr<FdoDataPropertyDefinition> pProp;
         // Create a feature class
+        FdoPtr<FdoPropertyDefinitionCollection> propDefColl;
+        FdoPtr<FdoDataPropertyDefinitionCollection> propDataDefColl;
         if( ownerIsFeat )
             pfeatureclass = FdoFeatureClass::Create(L"TestFeatureClass", L"FeatureClass Desc");
@@ -102,8 +105,10 @@
 	        pProp->SetDataType( FdoDataType_Int64 );
 	        pProp->SetNullable(false);
             pProp->SetIsAutoGenerated(true);
-            FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->Add( pProp );
-	        FdoPtr<FdoDataPropertyDefinitionCollection>(pfeatureclass->GetIdentityProperties())->Add( pProp );
+            propDefColl = pfeatureclass->GetProperties();
+            propDefColl->Add( pProp );
+	        propDataDefColl = pfeatureclass->GetIdentityProperties();
+            propDataDefColl->Add( pProp );
         else
@@ -111,24 +116,28 @@
             pProp = FdoDataPropertyDefinition::Create( L"Id", L"Id Prop" );
         // Add first name and last name properties
         pProp = FdoDataPropertyDefinition::Create( L"First Name", L"First Name" );
 	    pProp->SetDataType( FdoDataType_String );
         pProp->SetLength(32);
         pProp = FdoDataPropertyDefinition::Create( L"Last Name", L"Last Name" );
         // Create a class
-        FdoClassDefinition*           pclass;
+        FdoPtr<FdoClassDefinition> pclass;
         if( associatedIsFeat )
             pclass = FdoFeatureClass::Create(L"TestClass", L"Class Desc");
@@ -136,8 +145,10 @@
-            FdoPtr<FdoPropertyDefinitionCollection>(pclass->GetProperties())->Add( pProp );
-	        FdoPtr<FdoDataPropertyDefinitionCollection>(pclass->GetIdentityProperties())->Add( pProp );
+            propDefColl = pclass->GetProperties();
+	        propDataDefColl = pclass->GetIdentityProperties();
         else
@@ -146,63 +157,75 @@
         // Add name one and name two properties
         pProp = FdoDataPropertyDefinition::Create( L"Name One", L"Name One" );
         pProp = FdoDataPropertyDefinition::Create( L"Name Two", L"Name Two" );
         // Create a class
-        FdoClass*           pclassLeafObj = FdoClass::Create(L"TestSuperObjClass", L"Obj Class Desc");
+        FdoPtr<FdoClass> pclassLeafObj = FdoClass::Create(L"TestSuperObjClass", L"Obj Class Desc");
         // Add identity property
         pProp = FdoDataPropertyDefinition::Create( L"Id", L"ObjId Prop" );
-        FdoPtr<FdoPropertyDefinitionCollection>(pclassLeafObj->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pclassLeafObj->GetIdentityProperties())->Add( pProp );
+        propDefColl = pclassLeafObj->GetProperties();
+	    propDataDefColl = pclassLeafObj->GetIdentityProperties();
         pProp = FdoDataPropertyDefinition::Create( L"First Name", L"Name One" );
         pProp = FdoDataPropertyDefinition::Create( L"Last Name", L"Name Two" );
         // Create a class
-        FdoClass*           pclassObj = FdoClass::Create(L"TestOC", L"Obj Class Desc");
+        FdoPtr<FdoClass> pclassObj = FdoClass::Create(L"TestOC", L"Obj Class Desc");
-        FdoPtr<FdoPropertyDefinitionCollection>(pclassObj->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pclassObj->GetIdentityProperties())->Add( pProp );
+        propDefColl = pclassObj->GetProperties();
+	    propDataDefColl = pclassObj->GetIdentityProperties();
         // Create a feature Sub class class
-        FdoClassDefinition*    pSubFeatureclass;
+        FdoPtr<FdoClassDefinition> pSubFeatureclass;
         if( ownerIsFeat )
             pSubFeatureclass = FdoFeatureClass::Create(L"TestSubFeatureClass", L"A subclass from a featureClass");
@@ -212,7 +235,8 @@
             pProp = FdoDataPropertyDefinition::Create( L"Id", L"An Id Prop" );
 	        pProp->SetNullable(true);
-            FdoPtr<FdoPropertyDefinitionCollection>(pSubFeatureclass->GetProperties())->Add( pProp );
+            propDefColl = pSubFeatureclass->GetProperties();
         else
@@ -220,11 +244,12 @@
             pSubFeatureclass->SetBaseClass( pfeatureclass );
         // Add the classes to the schema class collection
-        FdoClassesP(pTestSchema->GetClasses())->Add( pfeatureclass );
-        FdoClassesP(pTestSchema->GetClasses())->Add( pclass );
-        FdoClassesP(pTestSchema->GetClasses())->Add( pclassLeafObj );
-        FdoClassesP(pTestSchema->GetClasses())->Add( pclassObj );
-        FdoClassesP(pTestSchema->GetClasses())->Add( pSubFeatureclass );
+        FdoClassesP clsColl = pTestSchema->GetClasses();
+        clsColl->Add( pfeatureclass );
+        clsColl->Add( pclass );
+        clsColl->Add( pclassLeafObj );
+        clsColl->Add( pclassObj );
+        clsColl->Add( pSubFeatureclass );
         // Create a valid association property
@@ -237,24 +262,16 @@
         passprop->SetReverseMultiplicity(L"1");
         if( useIdent )
-            FdoPtr<FdoDataPropertyDefinition> pprop = (FdoDataPropertyDefinition*)FdoPtr<FdoPropertyDefinitionCollection>(pclass->GetProperties())->GetItem( L"Name One" );
-            FdoPtr<FdoDataPropertyDefinitionCollection>(passprop->GetIdentityProperties())->Add( pprop );
+            propDataDefColl = passprop->GetIdentityProperties();
+            FdoPtr<FdoDataPropertyDefinition> pprop = (FdoDataPropertyDefinition*)propDefColl->GetItem( L"Name One" );
+            propDataDefColl->Add( pprop );
-                FdoPtr<FdoDataPropertyDefinition>( (FdoDataPropertyDefinition*)
-                    FdoPtr<FdoPropertyDefinitionCollection>(pclass->GetProperties())->GetItem( L"Name Two" )
-            FdoPtr<FdoDataPropertyDefinitionCollection>(passprop->GetReverseIdentityProperties())->Add(
-                    FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->GetItem( L"First Name" )
-                    FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->GetItem( L"Last Name" )
+            propDataDefColl->Add( FdoPtr<FdoDataPropertyDefinition>( (FdoDataPropertyDefinition*)propDefColl->GetItem( L"Name Two" )));
+            propDataDefColl = passprop->GetReverseIdentityProperties();
+            propDataDefColl->Add( FdoPtr<FdoDataPropertyDefinition>( (FdoDataPropertyDefinition*)propDefColl->GetItem( L"First Name" )));
+            propDataDefColl->Add( FdoPtr<FdoDataPropertyDefinition>( (FdoDataPropertyDefinition*)propDefColl->GetItem( L"Last Name" )));
         passprop->SetAssociatedClass(pclass);
@@ -276,13 +293,15 @@
             // Add the association property to the feature class property collection
             if( addToSubclass )
-                FdoPtr<FdoPropertyDefinitionCollection>(pSubFeatureclass->GetProperties())->Add( passprop );
-                FdoPtr<FdoPropertyDefinitionCollection>(pSubFeatureclass->GetProperties())->Add( passprop2 );
+                propDefColl->Add( passprop );
+                propDefColl->Add( passprop2 );
             else
-                FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->Add( passprop );
-                FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->Add( passprop2 );
         else
@@ -290,30 +309,28 @@
             if( useNestedObj )
                 // Add the association property to the leaf class of the obj class
-                FdoPtr<FdoPropertyDefinitionCollection>(pclassLeafObj->GetProperties())->Add( passprop );
                 FdoPtr<FdoObjectPropertyDefinition>pLeafObjPropData = FdoObjectPropertyDefinition::Create( L"LeafObject", L"object property" );
 	            pLeafObjPropData->SetClass( pclassLeafObj );
                 pLeafObjPropData->SetObjectType( FdoObjectType_Value );
-	            FdoPtr<FdoPropertyDefinitionCollection>(pclassObj->GetProperties())->Add( pLeafObjPropData );
+	            propDefColl->Add( pLeafObjPropData );
             else
                 // Add the association property to the Obj class property collection
-                FdoPtr<FdoPropertyDefinitionCollection>(pclassObj->GetProperties())->Add( passprop );
             // Add an object property that contain an association
             FdoPtr<FdoObjectPropertyDefinition>pObjPropData = FdoObjectPropertyDefinition::Create( L"Object", L"object property" );
 	        pObjPropData->SetClass( pclassObj );
             pObjPropData->SetObjectType( FdoObjectType_Value );
-	        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass->GetProperties())->Add( pObjPropData );
+	        propDefColl->Add( pObjPropData );
-        pclassObj->Release();
-        pSubFeatureclass->Release();
-        pclassLeafObj->Release();
-        pclass->Release();
-        pfeatureclass->Release();
         FdoPtr<FdoIApplySchema>pCmd = (FdoIApplySchema*) connection->CreateCommand(FdoCommandType_ApplySchema);
         pCmd->SetFeatureSchema( pTestSchema );
@@ -330,8 +347,6 @@
-        pTestSchema->Release();
     catch ( FdoSchemaException* e )
@@ -355,6 +370,7 @@
         FdoPtr<FdoFeatureSchema> schema = pfsc->GetItem(L"AssociationSchema");
         FdoPtr<FdoClassCollection> classes = schema->GetClasses();
         FdoPtr<FdoClassDefinition> cls;
+        FdoPtr<FdoClassDefinition> ascClass;
         cls = classes->GetItem(L"TestFeatureClass");
         if( cls )
@@ -368,9 +384,10 @@
                 propCol = cls->GetProperties();
             prop = (FdoAssociationPropertyDefinition*)propCol->GetItem(L"Association Prop1");
+            ascClass = prop->GetAssociatedClass();
             printf("Association: name(%ls) associated class(%ls) multiplicity(%ls)\n",
                 prop->GetName(),
-                (FdoPtr<FdoClassDefinition>(prop->GetAssociatedClass()))->GetName(),
+                ascClass->GetName(),
                 prop->GetMultiplicity() );
             FdoPtr<FdoDataPropertyDefinitionCollection> identProps = prop->GetIdentityProperties();
             printf("Identity properties: \n");
@@ -397,14 +414,15 @@
                 FdoPtr<FdoObjectPropertyDefinition> objProp = (FdoObjectPropertyDefinition*)propCol->GetItem(L"Object");
                 cls = objProp->GetClass();
-                prop = (FdoAssociationPropertyDefinition*)cls->GetProperties()->GetItem(L"Association Prop1");
+                FdoPtr<FdoPropertyDefinitionCollection> propsDefColl = cls->GetProperties();
+                prop = (FdoAssociationPropertyDefinition*)propsDefColl->GetItem(L"Association Prop1");
             else
                 prop->GetName(),
@@ -498,59 +516,74 @@
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass1->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pfeatureclass1->GetIdentityProperties())->Add( pProp );
+        FdoPtr<FdoPropertyDefinitionCollection> propsColl = pfeatureclass1->GetProperties();
+        propsColl->Add( pProp );
+	    FdoPtr<FdoDataPropertyDefinitionCollection> propsIdColl = pfeatureclass1->GetIdentityProperties();
+        propsIdColl->Add( pProp );
         pProp = FdoDataPropertyDefinition::Create( L"FeatId", L"FeatId Prop" );
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass2->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pfeatureclass2->GetIdentityProperties())->Add( pProp );
+        propsColl = pfeatureclass2->GetProperties();
+	    propsIdColl = pfeatureclass2->GetIdentityProperties();
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass3->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pfeatureclass3->GetIdentityProperties())->Add( pProp );
+        propsColl = pfeatureclass3->GetProperties();
+	    propsIdColl = pfeatureclass3->GetIdentityProperties();
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass4->GetProperties())->Add( pProp );
-	    FdoPtr<FdoDataPropertyDefinitionCollection>(pfeatureclass4->GetIdentityProperties())->Add( pProp );
+        propsColl = pfeatureclass4->GetProperties();
+	    propsIdColl = pfeatureclass4->GetIdentityProperties();
-        pTestSchema->GetClasses()->Add( pfeatureclass1 );
-        pTestSchema->GetClasses()->Add( pfeatureclass2 );
-        pTestSchema->GetClasses()->Add( pfeatureclass3 );
-        pTestSchema->GetClasses()->Add( pfeatureclass4 );
+        FdoPtr<FdoClassCollection> clsColl = pTestSchema->GetClasses();
+        clsColl->Add( pfeatureclass1 );
+        clsColl->Add( pfeatureclass2 );
+        clsColl->Add( pfeatureclass3 );
+        clsColl->Add( pfeatureclass4 );
-        FdoPtr<FdoFeatureClass>pclass = FdoFeatureClass::Create(L"AssoClass", L"Associated FeatureClass Desc");
+        FdoPtr<FdoFeatureClass> pclass = FdoFeatureClass::Create(L"AssoClass", L"Associated FeatureClass Desc");
-        pTestSchema->GetClasses()->Add( pclass );
+        propsColl = pclass->GetProperties();
+	    propsIdColl = pclass->GetIdentityProperties();
         FdoPtr<FdoAssociationPropertyDefinition> passprop = FdoAssociationPropertyDefinition::Create(L"AssocProp1", L"Association Prop Desc");
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass1->GetProperties())->Add( passprop );
+        propsColl = pfeatureclass1->GetProperties();
+        propsColl->Add( passprop );
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass2->GetProperties())->Add( passprop );
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass3->GetProperties())->Add( passprop );
-        FdoPtr<FdoPropertyDefinitionCollection>(pfeatureclass4->GetProperties())->Add( passprop );
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.h
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.h	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationSchemaTest.h	2007-03-21 20:54:55 UTC (rev 2703)
@@ -49,18 +49,18 @@
     void setUp ();
 	void tearDown ();
-    void TestCreate_NoIdent () { TestCreate( false, false ); }
+    virtual void TestCreate_NoIdent () { TestCreate( false, false ); }
-    void TestCreate_NoIdentAssocFeatClass () { TestCreate( false, false,false,false,true,true ); }
-    void TestCreate_WithIdent (){ TestCreate( true, false ); }
-    void TestCreate_WithIdentNoFeatClass (){ TestCreate( true, false, false, false, true, false, false ); }
-    void TestCreate_WithIdentNoFeatClassSubClass (){ TestCreate( true, false, false, false, true, false, false, true ); }
-    void TestCreate_NoIdentObj () { TestCreate( false, true ); }
-    void TestCreate_WithIdentObj (){ TestCreate( true, true ); }
-    void TestCreate_NoIdentObjNested () { TestCreate( false, true, true ); }
-    void TestCreate_Rollback () { TestCreate( false, false, false, true, false ); }
-    void TestLoadWithObj() { TestLoad(true); }
-    void TestLoadWithNoObj() { TestLoad(false); }
+    virtual void TestCreate_NoIdentAssocFeatClass () { TestCreate( false, false,false,false,true,true ); }
+    virtual void TestCreate_WithIdent (){ TestCreate( true, false ); }
+    virtual void TestCreate_WithIdentNoFeatClass (){ TestCreate( true, false, false, false, true, false, false ); }
+    virtual void TestCreate_WithIdentNoFeatClassSubClass (){ TestCreate( true, false, false, false, true, false, false, true ); }
+    virtual void TestCreate_NoIdentObj () { TestCreate( false, true ); }
+    virtual void TestCreate_WithIdentObj (){ TestCreate( true, true ); }
+    virtual void TestCreate_NoIdentObjNested () { TestCreate( false, true, true ); }
+    virtual void TestCreate_Rollback () { TestCreate( false, false, false, true, false ); }
+    virtual void TestLoadWithObj() { TestLoad(true); }
+    virtual void TestLoadWithNoObj() { TestLoad(false); }
     void TestCreate (bool useIdent, bool useObjProp, bool useNetstedObj = false, bool useTransaction = false,
             bool commitTransaction=true, bool associatedIsFeat=false, bool ownerIsFeat=true, bool addToSubclass=false );
@@ -68,10 +68,10 @@
     void TestLoad ( bool withOjb );
     void TestDelete ( bool rollbak );
-    void TestDelete_rollbak (  ) { TestDelete( true ); }
-    void TestDelete_commit (  ) { TestDelete( false ); }
-    void TestCreateMultiple();
-    void TestLoadMultiple();
+    virtual void TestDelete_rollbak (  ) { TestDelete( true ); }
+    virtual void TestDelete_commit (  ) { TestDelete( false ); }
+    virtual void TestCreateMultiple();
+    virtual void TestLoadMultiple();
 protected:
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationUpdateTest.h
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationUpdateTest.h	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoAssociationUpdateTest.h	2007-03-21 20:54:55 UTC (rev 2703)
@@ -55,15 +55,15 @@
     virtual ~FdoAssociationUpdateTest(void);
     void setUp () { mSchemaUtil = GetSchemaUtil(); mSchemaUtil->setUp(); }
     void tearDown () { mSchemaUtil->tearDown (); }
-    void update_NoIdent();
-    void update_NoIdentAssocFeatClass ();
-    void update_WithIdent();
-    void update_WithIdentNoFeatClass();
-    void update_WithIdentParent();
-    void update_WithIdentError();
-    void update_NoIdentObj();
-    void update_WithIdentObj();
-    void update_NoIdentObjNested();
+    virtual void update_NoIdent();
+    virtual void update_NoIdentAssocFeatClass ();
+    virtual void update_WithIdent();
+    virtual void update_WithIdentNoFeatClass();
+    virtual void update_WithIdentParent();
+    virtual void update_WithIdentError();
+    virtual void update_NoIdentObj();
+    virtual void update_WithIdentObj();
+    virtual void update_NoIdentObjNested();
 private:
     void masterTestNoObj( AssociationUpdateType type, const wchar_t* name1, const wchar_t* name2, int id, bool assocIsFeat=false, bool ownerIsFeat=true );
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -847,66 +847,58 @@
 void FdoInsertTest::insertDate (FdoIConnection *connection, FdoDateTime dateTime, FdoString*colorIndex)
+    double                    coordsBuffer[400];
+    FdoPtr<FdoPropertyValue>  propertyValue;
+    bool supportsZ = (FdoPtr<FdoIGeometryCapabilities>(connection->GetGeometryCapabilities())->GetDimensionalities() & FdoDimensionality_Z);
-    try
-        double                    coordsBuffer[400];
-        FdoPtr<FdoPropertyValue>  propertyValue;
-        bool supportsZ = (FdoPtr<FdoIGeometryCapabilities>(connection->GetGeometryCapabilities())->GetDimensionalities() & FdoDimensionality_Z);
+    FdoPtr<FdoITransaction> featureTransaction = connection->BeginTransaction();
+    FdoPtr<FdoIInsert> insertCommand = (FdoIInsert *) connection->CreateCommand(FdoCommandType_Insert);
+    insertCommand->SetFeatureClassName(L"Acad:AcDb3dPolyline");
+    FdoPtr<FdoPropertyValueCollection> propertyValues = insertCommand->GetPropertyValues();
-        FdoPtr<FdoITransaction> featureTransaction = connection->BeginTransaction();
-        FdoPtr<FdoIInsert> insertCommand = (FdoIInsert *) connection->CreateCommand(FdoCommandType_Insert);
-        insertCommand->SetFeatureClassName(L"Acad:AcDb3dPolyline");
-        FdoPtr<FdoPropertyValueCollection> propertyValues = insertCommand->GetPropertyValues();
+    FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance();
+	FdoPtr<FdoILineString> line1;
+	if ( supportsZ )
+		coordsBuffer[0] = 1.1;
+		coordsBuffer[1] = 2.2;
+		coordsBuffer[2] = 0.0;
+		coordsBuffer[3] = 1.1;
+		coordsBuffer[4] = 3.3;
+		coordsBuffer[5] = 0.0;
+		line1 = gf->CreateLineString(FdoDimensionality_XY|FdoDimensionality_Z, 2*3, coordsBuffer);
+	else
+		coordsBuffer[2] = 1.1;
+		coordsBuffer[3] = 3.3;
+		line1 = gf->CreateLineString(FdoDimensionality_XY, 2*2, coordsBuffer);
+    propertyValue = AddNewProperty( propertyValues, L"Geometry");
+    FdoPtr<FdoByteArray> byteArray = gf->GetFgf(line1);
+    FdoPtr<FdoGeometryValue> geometryValue = FdoGeometryValue::Create(byteArray);
+    propertyValue->SetValue(geometryValue);
-        FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance();
-		FdoPtr<FdoILineString> line1;
-		if ( supportsZ )
-			coordsBuffer[0] = 1.1;
-			coordsBuffer[1] = 2.2;
-			coordsBuffer[2] = 0.0;
-			coordsBuffer[3] = 1.1;
-			coordsBuffer[4] = 3.3;
-			coordsBuffer[5] = 0.0;
-			line1 = gf->CreateLineString(FdoDimensionality_XY|FdoDimensionality_Z, 2*3, coordsBuffer);
-		else
-			coordsBuffer[2] = 1.1;
-			coordsBuffer[3] = 3.3;
-			line1 = gf->CreateLineString(FdoDimensionality_XY, 2*2, coordsBuffer);
-        propertyValue = AddNewProperty( propertyValues, L"Geometry");
-        FdoPtr<FdoByteArray> byteArray = gf->GetFgf(line1);
-        FdoPtr<FdoGeometryValue> geometryValue = FdoGeometryValue::Create(byteArray);
-        propertyValue->SetValue(geometryValue);
+    FdoPtr<FdoDataValue> dataValue;
+    dataValue = FdoDataValue::Create(colorIndex);
+    propertyValue = AddNewProperty( propertyValues, L"color");
+    propertyValue->SetValue(dataValue);
-        FdoPtr<FdoDataValue> dataValue;
-        dataValue = FdoDataValue::Create(colorIndex);
-        propertyValue = AddNewProperty( propertyValues, L"color");
-        propertyValue->SetValue(dataValue);
+    dataValue = FdoDataValue::Create(dateTime);
+    propertyValue = AddNewProperty( propertyValues, L"datetime");
-        dataValue = FdoDataValue::Create(dateTime);
-        propertyValue = AddNewProperty( propertyValues, L"datetime");
+    FdoPtr<FdoIFeatureReader> reader = insertCommand->Execute();
-        FdoPtr<FdoIFeatureReader> reader = insertCommand->Execute();
+    int numberInsertedObjects = 0;
-        int numberInsertedObjects = 0;
+    while (reader->ReadNext())
+        numberInsertedObjects++;
+    wprintf(L"    Number of rows entered: %d \n", numberInsertedObjects);
-        while (reader->ReadNext())
-            numberInsertedObjects++;
-        wprintf(L"    Number of rows entered: %d \n", numberInsertedObjects);
-        featureTransaction->Commit();
-    catch ( ... )
-        throw;
+    featureTransaction->Commit();
 void FdoInsertTest::insertDateVerification (FdoIConnection *connection, int numOfSuccess)
@@ -1165,7 +1157,7 @@
         FdoPtr<FdoIInsert>insertCommand = (FdoIInsert *) connection->CreateCommand(FdoCommandType_Insert);
         //FdoPtr<FdoPropertyValueCollection> propertyValues = insertCommand->GetPropertyValues();
-        insertCommand->Execute();
     catch (FdoCommandException *ex)
@@ -1548,63 +1540,65 @@
     return (FdoDouble) 2.225073858507202e-308;
 void FdoInsertTest::insertAutoGen()
-	FdoIConnection* connection = UnitTestUtil::GetConnection(mSuffix, true);
-        try
-			FdoPtr<FdoIDescribeSchema>  pDescCmd = (FdoIDescribeSchema*) connection->CreateCommand(FdoCommandType_DescribeSchema);
-			FdoFeatureSchemasP pSchemas = pDescCmd->Execute();
-			if (pSchemas)
-				FdoFeatureSchemaP pSchema = pSchemas->FindItem( L"TestEmpty" );
-				if (!pSchema)
-					FdoIApplySchema*  pCmd = (FdoIApplySchema*) connection->CreateCommand(FdoCommandType_ApplySchema);
-					//FdoPtr<FdoFeatureSchemaCollection> pSchemas = FdoFeatureSchemaCollection::Create(NULL);
+    FdoPtr<FdoIConnection> connection = UnitTestUtil::GetConnection(mSuffix, true);
+    try
+	    FdoPtr<FdoIDescribeSchema>  pDescCmd = (FdoIDescribeSchema*) connection->CreateCommand(FdoCommandType_DescribeSchema);
+	    FdoFeatureSchemasP pSchemas = pDescCmd->Execute();
+	    if (pSchemas)
+		    FdoFeatureSchemaP pSchema = pSchemas->FindItem( L"TestEmpty" );
+		    if (!pSchema)
+			    FdoPtr<FdoIApplySchema>  pCmd = (FdoIApplySchema*) connection->CreateCommand(FdoCommandType_ApplySchema);
+			    //FdoPtr<FdoFeatureSchemaCollection> pSchemas = FdoFeatureSchemaCollection::Create(NULL);
-					FdoFeatureSchema* pNewSchema = FdoFeatureSchema::Create( L"TestEmpty", L"Test schema" );
-					//pSchemas->Add( pSchema );
-					FdoClass* pNewClass = FdoClass::Create( L"Empty", L"Test class" );
-					pNewClass->SetIsAbstract(false);
-					FdoDataPropertyDefinition* pProp = FdoDataPropertyDefinition::Create( L"AttrId", L"id" );
-					pProp->SetDataType( FdoDataType_Int64 );
-					pProp->SetNullable(false);
-					pProp->SetIsAutoGenerated(true);
-					pNewClass->GetProperties()->Add( pProp );
-					pNewClass->GetIdentityProperties()->Add( pProp );
+			    FdoPtr<FdoFeatureSchema> pNewSchema = FdoFeatureSchema::Create( L"TestEmpty", L"Test schema" );
+			    //pSchemas->Add( pSchema );
+			    FdoPtr<FdoClass> pNewClass = FdoClass::Create( L"Empty", L"Test class" );
+			    pNewClass->SetIsAbstract(false);
+			    FdoPtr<FdoDataPropertyDefinition> pProp = FdoDataPropertyDefinition::Create( L"AttrId", L"id" );
+			    pProp->SetDataType( FdoDataType_Int64 );
+			    pProp->SetNullable(false);
+			    pProp->SetIsAutoGenerated(true);
+                FdoPtr<FdoPropertyDefinitionCollection> pProps = pNewClass->GetProperties();
+			    pProps->Add( pProp );
+                FdoPtr<FdoDataPropertyDefinitionCollection> pIdProps = pNewClass->GetIdentityProperties();
+			    pIdProps->Add( pProp );
-					pProp = FdoDataPropertyDefinition::Create( L"AttrName", L"Name" );
-					pProp->SetDataType( FdoDataType_String );
-					pProp->SetLength(64);
-					pProp->SetNullable(true);
+			    pProp = FdoDataPropertyDefinition::Create( L"AttrName", L"Name" );
+			    pProp->SetDataType( FdoDataType_String );
+			    pProp->SetLength(64);
+			    pProp->SetNullable(true);
-					FDO_SAFE_RELEASE(pProp);
+                FdoPtr<FdoClassCollection> pClassColl = pNewSchema->GetClasses();
+			    pClassColl->Add( pNewClass );
+			    pCmd->SetFeatureSchema( pNewSchema );
+			    pCmd->Execute();
-					pNewSchema->GetClasses()->Add( pNewClass );
-					pCmd->SetFeatureSchema( pNewSchema );
-					pCmd->Execute();
-			FdoIInsert *insertCommand = (FdoIInsert *) connection->CreateCommand(FdoCommandType_Insert);
-			insertCommand->SetFeatureClassName(L"TestEmpty:Empty");
-			FdoIFeatureReader *myReader = insertCommand->Execute();
-			CPPUNIT_ASSERT(myReader != NULL);
-			while (myReader->ReadNext())
-				CPPUNIT_ASSERT(!myReader->IsNull(L"AttrId"));
-			myReader->Release();
-			connection->Close();
-		catch (...)
+	    insertCommand->SetFeatureClassName(L"TestEmpty:Empty");
+	    FdoPtr<FdoIFeatureReader> myReader = insertCommand->Execute();
+	    CPPUNIT_ASSERT(myReader != NULL);
+	    while (myReader->ReadNext())
+		    CPPUNIT_ASSERT(!myReader->IsNull(L"AttrId"));
+	    myReader->Close();
+	    connection->Close();
+    catch (FdoException* e)
         connection->Close ();
-        throw;
+        TestCommonFail(e);
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -1860,7 +1860,6 @@
         // Select and verify all data (post-update state).
         SelectNoMetaAll( connection, phMgr, table_id_geom, m_hasGeom, m_hasAssoc );
         SelectNoMetaAll( connection, phMgr, L"VIEW_ID_GEOM", m_hasGeom, false );
         SelectNoMetaAll( connection, phMgr, L"TABLE_NOID_GEOM", m_hasGeom, false );
@@ -1871,30 +1870,34 @@
         SelectNoMetaFilter( connection, phMgr, L"TABLE_NOID_GEOM", m_hasGeom, false );
         SelectNoMetaFilter( connection, phMgr, table_noid_nogeom, false, false );
-        SelectNoMetaProps( connection, phMgr, table_id_geom, m_hasGeom );
-        SelectNoMetaProps( connection, phMgr, L"VIEW_ID_GEOM", m_hasGeom );
-        SelectNoMetaProps( connection, phMgr, L"TABLE_NOID_GEOM", m_hasGeom );
-        SelectNoMetaProps( connection, phMgr, table_noid_nogeom, false );
 #ifndef RDBI_DEF_SSQL
 		SelectNoMetaSpatial( connection, phMgr, table_id_geom, m_hasAssoc );
 		SelectNoMetaSpatial( connection, phMgr, L"VIEW_ID_GEOM", false );
 		SelectNoMetaSpatial( connection, phMgr, L"TABLE_NOID_GEOM", false );
 #endif
+        SelectNoMetaProps( connection, phMgr, table_id_geom, m_hasGeom );
+        SelectNoMetaProps( connection, phMgr, L"VIEW_ID_GEOM", m_hasGeom );
+        SelectNoMetaProps( connection, phMgr, L"TABLE_NOID_GEOM", m_hasGeom );
+        SelectNoMetaProps( connection, phMgr, table_noid_nogeom, false );
         phMgr = NULL;
         mgr = NULL;
         conn->disconnect();
         delete conn;
+        conn = NULL;
     catch (FdoException *ex)
         try {
             if( connection )
+                connection->Close ();
+            if (conn != NULL)
-                connection->Close ();
+                conn->disconnect();
+                delete conn;
         catch ( ... )
@@ -1906,8 +1909,11 @@
         try {
             if( connection )
+            if (conn != NULL)
+                delete conn;
         catch ( ... )
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoInsertTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoInsertTest.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoInsertTest.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -147,7 +147,7 @@
                 wprintf(L"    Unexpected Exception: %ls\n", ex->GetExceptionMessage());
-                throw ex;
+                UnitTestUtil::FailOnException(ex);
             wchar_t expectedErrMsg[] = L"Incomplete date/time setting. ";
@@ -160,17 +160,17 @@
-                throw ex;
             else
                 wprintf(L"    Expected Exception: %ls\n", ex->GetExceptionMessage());
+            ex->Release();
         catch ( ... )
-            wprintf(L"    Unexpected Exception in insertDate()\n");
-            throw;
+            UnitTestUtil::FailOnException(FdoException::Create(L"    Unexpected Exception in insertDate()\n"));
@@ -238,10 +238,11 @@
         mgr = NULL;
         conn->disconnect();
         delete conn;
+        conn = NULL;
         FdoPtr<FdoIConnection> connection = UnitTestUtil::GetConnection(UNSIGNED_SUFFIX, false);
         insertCommand->SetFeatureClassName(tableName);
@@ -267,10 +268,9 @@
-        insertCommand->Release();
         // check
-    	FdoISelect* selectCmd = (FdoISelect *) connection->CreateCommand(FdoCommandType_Select);
+    	FdoPtr<FdoISelect> selectCmd = (FdoISelect *) connection->CreateCommand(FdoCommandType_Select);
 	    selectCmd->SetFeatureClassName(tableName);
     	FdoPtr<FdoIFeatureReader> featureReader = selectCmd->Execute();
@@ -289,15 +289,24 @@
                 break;
         CPPUNIT_ASSERT( rowCount == 2 );
+        if (conn)
+            delete conn;
+        if (conn)
+            delete conn;
@@ -336,7 +345,8 @@
         owner->Commit();
         owner->SetCurrent();
-        GdbiConnection* gdbiConnection = phMgr->SmartCast<FdoSmPhGrdMgr>()->GetGdbiConnection();
+        FdoSmPhGrdMgrP grdMgr = phMgr->SmartCast<FdoSmPhGrdMgr>();
+        GdbiConnection* gdbiConnection = grdMgr->GetGdbiConnection();
         // Create tables for various combinations of character set and types of characters
         // that will be stored in the table.
@@ -351,6 +361,12 @@
         charSetCreateTable( gdbiConnection, L"cp932", L"ascii7" );
         charSetCreateTable( gdbiConnection, L"cp932", L"japan" );
+        phMgr = NULL;
+        mgr = NULL;
+        delete conn;
+        conn = NULL;
         // A couple of combinations are not tried:
         //  - latin11 character set, Japanese characters
         //  = cp932 character set, 8 bit characters
@@ -372,10 +388,20 @@
+        if (conn)
+            delete conn;
+        if (conn)
+            delete conn;
@@ -419,7 +445,7 @@
     dataValue = FdoDataValue::Create(charVal);
+    FdoPtr<FdoIFeatureReader>rdr = insertCommand->Execute();
   	FdoPtr<FdoISelect>selCmd = (FdoISelect*)connection->CreateCommand( FdoCommandType_Select );
     selCmd->SetFeatureClassName(className);
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoUpdateTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoUpdateTest.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/MySql/MySqlFdoUpdateTest.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -55,6 +55,7 @@
             UnitTestUtil::Sql2Db( (const wchar_t**) mForeignPolygonTest, connection.p );
+        catch(FdoException* e){e->Release();}
         catch(...){}
         userConnectString = UnitTestUtil::GetConnectionString(Connection_WithDatastore, L"_foreign_sch");
Modified: trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
--- trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp	2007-03-21 20:38:20 UTC (rev 2702)
+++ trunk/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp	2007-03-21 20:54:55 UTC (rev 2703)
@@ -960,6 +960,7 @@
 				scName = FdoStringP::Format(L"%ls_%ld", scReader->GetName(), currSC);
             // Generate physical spatial context from current SpatialContextGeom
+            FdoPtr<FdoByteArray> scExtent = scReader->GetExtent();
 			FdoSmPhSpatialContextP sc = new FdoSmPhSpatialContext(
                 GetManager(),
                 scReader->GetSrid(),
@@ -968,7 +969,7 @@
                 scReader->GetCoordinateSystem(),
                 scReader->GetCoordinateSystemWkt(),
                 scReader->GetExtentType(),
-                scReader->GetExtent(),
+                scExtent,
                 scReader->GetXYTolerance(),
                 scReader->GetZTolerance()
More information about the fdo-commits mailing list
