[fdo-commits] r2711 - trunk/Fdo/Python/Inc/Common
svn_fdo at osgeo.org svn_fdo at osgeo.org
Sat Mar 24 12:36:20 EDT 2007
Author: gregboone
Date: 2007-03-24 12:36:20 -0400 (Sat, 24 Mar 2007)
New Revision: 2711
Removed:
   trunk/Fdo/Python/Inc/Common/StringCollection.h
   trunk/Fdo/Python/Inc/Common/Vector.h
Ticket #39 - Add Python Wrappers for FDO API (Fix Linux build issues)
Deleted: trunk/Fdo/Python/Inc/Common/StringCollection.h
--- trunk/Fdo/Python/Inc/Common/StringCollection.h	2007-03-24 16:35:54 UTC (rev 2710)
+++ trunk/Fdo/Python/Inc/Common/StringCollection.h	2007-03-24 16:36:20 UTC (rev 2711)
@@ -1,281 +0,0 @@
-#ifndef FDO_STRING_COLLECTION_H
-#define FDO_STRING_COLLECTION_H		1
-// Copyright (C) 2004-2006  Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-#ifdef _WIN32
-#pragma once
-#endif
-#include <Common/Collection.h>
-/// \cond DOXYGEN-IGNORE
-// An element in a string collection.
-// This class is just a wrapper around a string.
-class FdoStringElement : public FdoDisposable
-public:
-    /// Create from a string.
-	static FdoStringElement* Create( FdoStringP src )
-	    return new FdoStringElement(src);
-    /// Operator to copy from a "managed" string.
-	FdoStringElement& operator=( const FdoStringP& src )
-	    mString = src;
-        return(*this);
-    /// Operator to copy from an "unmanaged" string.
-	FdoStringElement& operator=( FdoString* wString )
-	    mString = wString;
-        return(*this);
-    /// Returns the string that this element represents.
-	FdoStringP GetString()
-	    return mString;
-protected:
-    FdoStringElement() {}
-    FdoStringElement( FdoStringP src )
-	    mString = src;
-    virtual ~FdoStringElement(void)
-private:
-    FdoStringP mString;
-typedef FdoPtr<FdoStringElement> FdoStringElementP;
-/// \endcond
-/// \brief
-/// FdoStringCollection is a collection of strings.
-class FdoStringCollection : public FdoCollection<FdoStringElement,FdoException>
-public:
-    /// \brief
-    /// Constructs a new empty string collection
-    /// \return
-    /// Returns FdoStringCollection
-	FDO_API_COMMON static FdoStringCollection* Create(void);
-    /// \brief
-    /// Creates a copy of string collection
-    /// \param src
-    /// Input the source collection
-    /// \return
-	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringCollection& src);
-    /// \brief
-    /// \param src
-    /// Input pointer to the source collection
-    /// \return
-	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringCollection* src);
-    /// \brief
-    /// Creates a string collection that is tokenize from a string.
-    /// The collection contains an element for each token.
-    /// \param inString
-    /// Input the string to tokenize.
-    /// \param delimiters
-    /// Input list of single character token delimiters.
-    /// \param bNullTokens
-    /// true: include zero-length tokens in the collection.
-    /// false: exclude zero-length tokens
-    /// \return
-	FDO_API_COMMON static FdoStringCollection* Create( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
-    /// \brief
-    /// Gets the string in the collection at the specified index. Throws an invalid argument exception if the index is out of range.
-    /// \param index
-    /// Input index
-    /// \return
-    /// Returns the string in the collection at the specified index
-	FDO_API_COMMON FdoString* GetString(int index) const;
-    /// \brief
-    /// Appends the strings from src to the end of this collection.
-    /// \param src
-	FDO_API_COMMON void Append( const FdoStringCollection& src);
-    /// \brief
-    /// Adds a string to the end of this collection.
-    /// \param src
-	FDO_API_COMMON int Add( FdoStringP src);
-    /// \brief
-    /// Given a string, returns its position in this collection.
-    /// \param value
-    /// Input the string to check
-    /// \param caseSensitive
-    /// Input if true, do a case-sensitive comparison
-    /// of the string and members of this collection. If false, the comparison
-    /// is case-insensitive.
-    /// \return
-    /// Returns the string's position. Returns -1 if the string
-    /// is not in this collection.
-    FDO_API_COMMON virtual FdoInt32 IndexOf(FdoStringP value, FdoBoolean caseSensitive = true) const;
-    /// \brief
-    /// Concatenates the strings in this collection.
-    /// \param separator
-    /// Input separate each collection string with this separator string.
-    /// \return
-    /// Returns the concatenation if all strings in this collection.
-    /// Returns a concatenation of all the strings in this collection,
-    /// separated by the given separator.
-	FDO_API_COMMON FdoStringP ToString( FdoString* separator );
-protected:
-	FDO_API_COMMON FdoStringCollection(void);
-	FDO_API_COMMON FdoStringCollection( const FdoStringCollection& src);
-	FDO_API_COMMON FdoStringCollection( const FdoStringCollection* src);
-	FDO_API_COMMON FdoStringCollection( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
-	FDO_API_COMMON virtual ~FdoStringCollection(void);
-/// \endcond
-    FDO_API_COMMON virtual void Dispose()
-        delete this;
-private:
-//typedef FdoPtr<FdoStringCollection> FdoStringsP;
-/// \brief
-/// FdoStringsP is a FdoPtr on FdoStringCollection, provided for convenience.
-class FdoStringsP : public FdoPtr<FdoStringCollection>
-public:
-    FdoStringsP() {}
-    FdoStringsP( const FdoStringsP& src )
-        : FdoPtr<FdoStringCollection>(src)
-    FdoStringsP( FdoStringCollection* src )
-    ~FdoStringsP() {}
-    /// \brief
-    /// Copies a string collection
-    /// \param src
-    /// \return
-    /// Returns the copy FdoStringCollection
-	FDO_API_COMMON FdoStringCollection* operator=( FdoStringCollection* src );
-    /// \brief
-    /// Concatenates two string collections
-    /// \param coll2
-    /// Input collection to append to the end of this collection
-    /// \return
-    /// Returns the concatenated FdoStringCollection
-	FDO_API_COMMON const FdoStringsP operator+( const FdoStringsP coll2 ) const;
-    /// \brief
-    /// Concatenates a string collection and a string
-    /// \param str2
-    /// Input stromg to append to the end of this collection
-    /// \return
-	FDO_API_COMMON const FdoStringsP operator+( const FdoStringP str2 ) const;
-    /// \brief
-    /// \param coll2
-    /// \return
-	FDO_API_COMMON FdoStringsP operator+=( FdoStringsP coll2 );
-    /// \brief
-    /// \param str2
-    /// \return
-	FDO_API_COMMON FdoStringsP operator+=( FdoStringP str2 );
-#endif
Deleted: trunk/Fdo/Python/Inc/Common/Vector.h
--- trunk/Fdo/Python/Inc/Common/Vector.h	2007-03-24 16:35:54 UTC (rev 2710)
+++ trunk/Fdo/Python/Inc/Common/Vector.h	2007-03-24 16:36:20 UTC (rev 2711)
@@ -1,408 +0,0 @@
-#ifndef FDO_VECTOR_H
-#define FDO_VECTOR_H		1
-#ifdef _WIN32
-#pragma once
-#endif
-/// \brief
-/// An element in a vector.
-/// This class is just a ref-countable wrapper around a double.
-class FdoVectorElement : public FdoDisposable
-public:
-    /// \brief
-    /// Creates a vector element.
-    /// \param value
-    /// Input the value to assign the element
-    /// \return
-    /// Returns FdoProviderNameTokens
-	FDO_API_COMMON static FdoVectorElement* Create( double value )
-	    return new FdoVectorElement(value);
-    /// \brief
-    /// Gets the element value.
-    /// \return
-    /// Returns the value that this element represents.
-	FDO_API_COMMON double  GetValue()
-	    return mValue;
-    /// \brief
-    /// Sets the element value.
-    /// \param value
-    FDO_API_COMMON void SetValue( double value )
-        mValue = value;
-    /// \brief
-    /// Gets the element value in string format.
-    /// \return
-    FDO_API_COMMON FdoStringP GetString();
-protected:
-    FdoVectorElement() {}
-    FdoVectorElement( double value )
-	    mValue = value;
-    virtual ~FdoVectorElement(void)
-/// \endcond
-private:
-    double mValue;
-typedef FdoPtr<FdoVectorElement> FdoVectorElementP;
-/// \brief
-/// FdoVector is a one-dimensional collection of numbers.
-class FdoVector : public FdoCollection<FdoVectorElement,FdoException>
-public:
-    /// \brief
-    /// Constructs a new empty vector
-    /// \return
-    /// Returns FdoVector
-	FDO_API_COMMON static FdoVector* Create(void);
-    /// \brief
-    /// Creates a copy of a vector
-    /// \param src
-    /// Input pointer to the source vector
-    /// \return
-	FDO_API_COMMON static FdoVector* Create( const FdoVector* src);
-    /// \brief
-    /// Creates a vector that is tokenize from a string.
-    /// The vector contains an element for each token. Non-numberic tokens
-    /// become 0.0.
-    /// true: include zero-length tokens in the vector ( as 0.0 ).
-    /// \return
-	FDO_API_COMMON static FdoVector* Create( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
-    /// \brief
-    /// Gets the number in the vector at the specified index. Throws an invalid argument exception if the index is out of range.
-    /// \param index
-    /// Input index
-    /// \return
-    /// Returns the number in the vector at the specified index
-	FDO_API_COMMON double GetValue(int index) const;
-    /// \brief
-    /// Appends the numbers from src to the end of this vector.
-    /// \param src
-	FDO_API_COMMON void Append( const FdoVector* src);
-    /// \brief
-    /// Adds a number to the end of this vector.
-    /// \param value
-	FDO_API_COMMON int Add( double value );
-    /// \brief
-    /// Concatenates the numbers in this collection.
-    /// Input separate each collection number with this separator string.
-    /// \return
-    /// Returns the concatenation of all numbers in this vector,
-    /// separated by the given separator..
-protected:
-	FdoVector(void);
-	FdoVector( const FdoVector* src);
-	FdoVector( const FdoStringP& inString, FdoString* delimiters, bool bNullTokens = false );
-	virtual ~FdoVector(void);
-/// \endcond
-        delete this;
-private:
-/// \brief
-/// FdoVectorP is a FdoPtr on FdoVector, provided for convenience. It
-/// also provides vector arithmetic and comparison operators.
-class FdoVectorP : public FdoPtr<FdoVector>
-public:
-    /// \brief
-    /// Vector FdoPtr default constructor
-    /// \return
-    /// Returns FdoVectorP
-    FDO_API_COMMON FdoVectorP() {}
-    /// \brief
-    /// Vector FdoPtr copy constructor
-    /// \param src
-    /// Input the source vector as a FdoPtr
-    /// \return
-    FDO_API_COMMON FdoVectorP( const FdoVectorP& src )
-        : FdoPtr<FdoVector>(src)
-    /// \brief
-    /// \param src
-    /// Input the source vector as an object pointer
-    /// \return
-    FDO_API_COMMON FdoVectorP( FdoVector* src )
-    /// \brief
-    /// Vector FdoPtr destructor
-    FDO_API_COMMON ~FdoVectorP() {}
-    /// \brief
-    /// Copies a vector
-    /// \param src
-    /// \return
-    /// Returns a new copy of the input vector
-	FDO_API_COMMON FdoVector* operator=( FdoVector* src );
-    /// \brief
-    /// Adds two vectors, by adding each individual element. The output vector has
-    /// the same length as the longer of the input vectors. If one input
-    /// vector is shorter than the other, it is treated as if it
-    /// is padded with zeros.
-    /// \param vec2
-    /// Input vector to add to this vector
-    /// \return
-    /// Returns the sum of the two input vectors
-	FDO_API_COMMON const FdoVectorP operator+( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Subtracts two vectors, by subtracting each individual element. The output vector has
-    /// \param vec2
-    /// Input vector to subtract from this vector
-    /// \return
-    /// Returns the difference of the two input vectors
-	FDO_API_COMMON const FdoVectorP operator-( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Adds a vector, to this vector, by adding each individual element. The output vector has
-    /// \param vec2
-    /// \return
-	FDO_API_COMMON FdoVectorP operator+=( const FdoVectorP vec2 );
-    /// \brief
-    /// Subtracts a vector, from this vector, by subtracting each individual element. The output vector has
-    /// \param vec2
-    /// \return
-	FDO_API_COMMON FdoVectorP operator-=( const FdoVectorP vec2 );
-    /// \brief
-    /// Compare two vectors for equality. The vectors are equal
-    /// if all of their elements are equal. If one vector is shorter than the other
-    /// then it is treated as if it were padded with zeros to the length of the
-    /// other vector.
-    /// \param vec2
-    /// Input vector to compare this vector
-    /// \return
-    /// Returns true if the two vectors are identical.
-	FDO_API_COMMON FdoBoolean operator==( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Compare two vectors for difference. The vectors are differnt
-    /// if one of their elements is differnt. If one vector is shorter than the other
-    /// other vector.
-    /// \param vec2
-    /// \return
-    /// Returns true if the two vectors are different.
-	FDO_API_COMMON FdoBoolean operator!=( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Checks if this vector is greater than a second vector.
-    /// Comparison is done by comparing the first element in each vector.
-    /// If they are equal, then the second element is check and so on until
-    /// a differing element is found. If one vector is shorter than the other
-    /// other vector.
-    /// \param vec2
-    /// \return
-    /// Returns true if this vector is greater than vec2.
-	FDO_API_COMMON FdoBoolean operator>( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Checks if this vector is greater or equal to a second vector.
-    /// other vector.
-    /// \param vec2
-    /// \return
-    /// Returns true if this vector is greater or equal vec2.
-	FDO_API_COMMON FdoBoolean operator>=( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Checks if this vector is less than a second vector.
-    /// other vector.
-    /// \param vec2
-    /// \return
-    /// Returns true if this vector is less than vec2.
-	FDO_API_COMMON FdoBoolean operator<( const FdoVectorP vec2 ) const;
-    /// \brief
-    /// Checks if this vector is less than or equal to a second vector.
-    /// other vector.
-    /// \param vec2
-    /// \return
-    /// Returns true if this vector is less than or equal vec2.
-	FDO_API_COMMON FdoBoolean operator<=( const FdoVectorP vec2 ) const;
-protected:
-    /// General function to do the vector comparisons.
-    FdoBoolean Compare( const FdoVectorP vec2, FdoBoolean lt, FdoBoolean eq, FdoBoolean gt ) const;
-/// \endcond
-#endif
More information about the fdo-commits mailing list
