[fdo-dev] [UnitTest] More detailed log
Mateusz Loskot mateusz at loskot.net
Mon Aug 28 10:39:47 EDT 2006
Romica Dascalescu wrote:
> Hi Mateusz,
> You must fill up your MySqlInit.txt file with the right values. The
> unit test stops when an exception is thrown in a test function and
> there is missing a "try{}catch(...){}" block.
Hi Romica,
This is what I need to know (MySqlInit.txt) to run UT.
I should search through files yesterday first. :-)
Thanks
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
