[fdo-dev] Binary compatibility change to fdo.dll (trunk version)
Mateusz Loskot mateusz at loskot.net
Fri Dec 15 16:09:48 EST 2006
Brent Robinson wrote:
> Hi,
> I will be checking in some modifications to the svn trunk that will
> change the binary compatibility for fdo.dll. Once this is done, if you
> update from the svn trunk and build the FDO project, you will also need
> to build your providers. The changes will likely go in on Monday, Dec 18.
Thanks for the note.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
