[fdo-dev] FDO Unit Test fails
Greg Boone greg.boone at autodesk.com
Wed Oct 4 09:42:52 EDT 2006
This is probably a problem in the source/test code. I think your
environment is ok.
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Wednesday, October 04, 2006 3:52 AM
To: fdo-dev
Subject: [fdo-dev] FDO Unit Test fails
Yesterday, I updated fdocore after a few days.
I cleaned up my working copy and removed everything from the
installation directory usr/local/fdo-3.2.0.
Next, I run svn update and built:
. ./setenvironment.sh
./build_thirdparty.sh
./build_linux.sh
Next, I did run UnitTest program and here is what I got:
mloskot:~/dev/fdo/_svn/Fdo/UnitTest$ ./UnitTest
In-memory limited conversion to unaligned FGF Polygons, retained as
FGF...
0.075332 sec for 14915 positions in 343 polygons (4553 geom/s)
In-memory use of limited retained, unaligned FGF, accessed via streamed
geometries...
0.234421 sec for 304095 positions in 7000 streamed geometries (29860
geom/s)
............................Filter = ( Width*Length ) AS Area, Area =
123
.............................ERROR (XSL Processor): 'xsl:variable' has
an invalid 'junk' attributeWARNING (XSL Processor): At source node
'#document/DataSet', '' is an illegal element name. The element will not
be addedFDO_28_UTF8FAILURE
F.........................................
UnitTestUtil.cpp:47:Assertion
Test name: 7XmlTest.testXsl
FDO_28_UTF8FAILURE
Failures !!!
Run: 100   Failure total: 1   Failures: 1   Errors: 0
Does anyone has idea where is the problem?
Is this something wrong with my environment?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
