[fdo-dev] GDAL version in the trunk
Mateusz Loskot mateusz at loskot.net
Fri Oct 6 14:27:43 EDT 2006
Frank Warmerdam wrote:
> I do look forward to improving the FDO build mechanisms so that an existing
> external version of GDAL can be used, as least optionally, at some point.
I vote to extend this concept.
I'm going to add --with-boost option to ./configure script so user
will be able to select his own existing of Boost installation.
If no --with-boost option is provided, Thirdparty's Boost will be used.
Do you also like this idea?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
