[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Romica Dascalescu Romica.Dascalescu at autodesk.com
Mon Oct 16 11:10:33 EDT 2006
Hi Manjeet,
Please can you provide me the next information?
In the menu Help -> About Autodesk Map 3D
	-> Click on Product Information
I need to tell me: Product Name, Product version, Product Service pack.
It's very important if your Map version supports the latest version of
FDO.
Also in you install folder you have FDO\Bin and inside providers.xml.
Please tell me the value of version node from providers (is it 3.0.0.0,
3.1.0.0 or 3.2.0.0)
About MgFdoMySQLOverrides.dll you should find this library after build
in: \\Providers\GenericRdbms\Managed\bin\debug\ or
\\Providers\GenericRdbms\Managed\bin\release\
If you have build errors please let me know.
Usually as rule, after you build one provider and you want to replace
the dll in Map you must copy also FDO libraries
(\\Fdo\Unmanaged\bin\win32\debug\)
If you want to use the debug libraries do not forget about debug
dependencies (Xalan-C_1_7_0D.dll, XalanMessages_1_7_0D.dll,
xerces-c_2_5_0D.dll and boost_thread-vc80-mt-gd-1_32.dll <last one is
only for WMS and WFS providers>)
Best Regards,
Romica.
-----Original Message-----
From: Manjeet Sharma [mailto:manjeet.sharma at daffodildb.com]
Sent: Monday, October 16, 2006 6:12 AM
To: Romica Dascalescu
Cc: Rajneesh Verma
Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
Dear Romica,
                          Thanks for your nice support. The build
process for MySQL provider is succssfull without any error.But it does
not produce MgFdoMySQLOverrides.dll files. But when i replace these
newly build     .dll files (only three)  with existing ones in
Autodesk map 2007 at the path " C:\Program Files\Autodesk Map 3D
2007\FDO\bin ", the FDO  provider for Mysql does not work. It gives
the error message during Autodesk map 2007 startup.
C:\Program Files\Autodesk Map 3D 2007\AcMapWorkspace.arx cannot find a
dll or
other file that it needs.
.Failed.
AcMapWorkspace.arx Load FailedRegenerating model.
AutoCAD menu utilities loaded.
Command: COMMANDLINE
The names of the newly created three dll files are :
MySQLProvider.dll
MySQLOverrides.dll
RdbmsOverrides.dll
but still we could not create MgFdoMySQLOverrides.dll file.
waiting for your reply.
Thanks
On 10/13/06, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
> Hi Rajneesh,
> I had a look at the project Fdo\UnitTest\UnitTest.vcproj
>         - UseOfMFC="0" - ok
>         - PreprocessorDefinitions does not contains __CPPUNIT_MFC_APP
> ok
>         - The File Fdo\UnitTest\Pch.h does not contains define
> __CPPUNIT_MFC_APP - ok
> Everything looks ok. I tried a full build on a clean machine (with
VC++
> and VC# Express 2005 and it worked + SDK).
> Maybe your problem is coming from file
> Thirdparty\cppunit\HostApp\StdAfx.h
> In this file you should have next part of code (it's the only place
> where an afx (MFC) header file can be included):
> #ifdef __CPPUNIT_MFC_APP
>         #define _AFXDLL
>         #include <afxwin.h>         // MFC core and standard
components
>         #include <afxext.h>         // MFC extensions
>         #ifndef _AFX_NO_AFXCMN_SUPPORT
>                 #include <afxcmn.h>
>         #endif // _AFX_NO_AFXCMN_SUPPORT
> #else
>         #define WIN32_LEAN_AND_MEAN
>         #include <stdio.h>
>         #include <tchar.h>
>         #include <Windows.h>
> #endif // __CPPUNITMFCAPP
> Can you check please if you have the last version of Thirdparty
folder?
> Can you make an update on this folder and if something changed make a
> build?
> Also can you check for __CPPUNIT_MFC_APP if you defined?
> __CPPUNIT_MFC_APP must be undefined.
> Regards,
> Romica
> From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
> Sent: Friday, October 13, 2006 1:06 AM
> Cc: dev at fdo.osgeo.org; users at fdo.osgeo.org; 'Manjeet Sharma'
> Subject: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
[fdo-users]
> Hi Romica,
> We are getting these error messages during build process of both "Core
> FDO and  MySql FDO provider ".
> The project names that we are trying to build are:
> FDO.sln
> MYSQL.sln
> and we are getting these errors during the build process of subproject
> "unittest.sln" (FDO project) and "unittestmysql.sln" (MySQL project).
> Please mark your response to Manjeet also as he is working with us on
> this
> project.
> Thanks
> Rajneesh
> > From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
> > Sent: Thursday, October 12, 2006 8:11 PM
> > To: dev at fdo.osgeo.org
> > Cc: users at fdo.osgeo.org; Rajneesh Verma
> > Subject: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev]
> Query
> > on MySQL FDO
> > Hi Rajneesh,
> > Could you please tell me on which project (.sln and .vcproj) do you
> have
> > this error?
> > Could you please provide me more information?
> > Thanks,
> > Romica.
> > Sent: Thursday, October 12, 2006 2:34 AM
> > Subject: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL
> FDO
> > Hi Romica,
> > Thanks for the guidance. However, we are still facing problem as
given
> > below:
> > We have already done checkout of utilities folder and are getting
the
> > error
> > message as below:
> > c:\program files\microsoft visual studio
8\vc\atlmfc\include\afx.h(24)
> > : fatal error C1189: #error :  Building MFC application with /MD[d]
> (CRT
> > dll
> > version) requires MFC shared dll version. Please #define _AFXDLL or
do
> > not
> > use /MD[d]
> > Regards
> > Rajneesh
> > > Sent: Tuesday, October 10, 2006 11:44 PM
> > > To: dev at fdo.osgeo.org; users at fdo.osgeo.org
> > > Cc: Rajneesh Verma
> > > Subject: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
> > > Hi,
> > > Because '[FDO Open Source]\Utilities' directory is not on your
local
> > > disk I think you took from SVN only fdo, thirdparty and rdbms. You
> > need
> > > also the utilities for providers.
> > > You can use checkoutsvn.bat to get/update your working folder by
> using
> > > -w command e.g.:
> > > checkoutsvn.bat -w=fdocore -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
> > > Or
> > > checkoutsvn.bat -w=fdo -w=utilities -w=rdbms -u=xxx -p=xxx -o=xxx
> > -s=xxx
> > > The option fdocore include utilities option.
> > > Before running checkoutsvn.bat, please update it from SVN.
> > > After this command you should have and build the utilities without
> any
> > > problems.
> > > If you still have problems please let me know.
> > > Regards,
> > > Romica.
> > Manjeet Sharma
> > Software Engineer
> > Daffodil Software Ltd.
> > To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
> > For additional commands, e-mail: dev-help at fdo.osgeo.org
> > To unsubscribe, e-mail: users-unsubscribe at fdo.osgeo.org
> > For additional commands, e-mail: users-help at fdo.osgeo.org
> Manjeet Sharma
> Software Engineer
Manjeet Sharma
Software Engineer
More information about the Fdo-internals mailing list
