[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Romica Dascalescu Romica.Dascalescu at autodesk.com
Tue Oct 17 08:50:36 EDT 2006
Hi Manjeet,
Latest FDO is not supported by the version of Map which you having.
Regards,
Romica.
	-----Original Message-----
	From: Manjeet Sharma [mailto:manjeet.sharma at daffodildb.com]
	Sent: Tue 10/17/2006 1:07 AM
	To: Romica Dascalescu
	Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com; parveen.agarwal at daffodildb.com
	Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
	Hi Romica,
	I am sending you the following configuration details for FDO provider :
	Product name: Autodesk Map 3D 2007
	Product version: A.54.0 (UNICODE)
	Product service pack: 0
	License type: Standalone - Locked
	License behavior: Unregistered Version
	License usage type: In Trial
	FDO provider version: 3.2.0.0
	and we could not find the library file MgFdoMySQLOverrides.dll  after
	build process at the following locations:
	 \\Providers\GenericRdbms\Managed\bin\debug\ and
	\\Providers\GenericRdbms\Managed\bin\release\
	but we have another library file
	OSGeo.FDO.Providers.MySQL.Overrides.dll at the same path. we tried to
	use the same but the error message during autodesk startup is same as
	i have told you earlier.
	i have also tried all the newly build fdo core dll file (including
	debug dependencies (Xalan-C_1_7_0D.dll, XalanMessages_1_7_0D.dll,
	xerces-c_2_5_0D.dll) by placing all those files.
	Right now i am trying to build the FDO provider  using FDO 3.0.0.0 version
	Thanks
	On 10/16/06, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
	> Hi Manjeet,
	> Please can you provide me the next information?
	> In the menu Help -> About Autodesk Map 3D
	>         -> Click on Product Information
	> I need to tell me: Product Name, Product version, Product Service pack.
	> It's very important if your Map version supports the latest version of
	> FDO.
	> Also in you install folder you have FDO\Bin and inside providers.xml.
	> Please tell me the value of version node from providers (is it 3.0.0.0,
	> 3.1.0.0 or 3.2.0.0)
	> About MgFdoMySQLOverrides.dll you should find this library after build
	> in: \\Providers\GenericRdbms\Managed\bin\debug\ or
	> If you have build errors please let me know.
	> Usually as rule, after you build one provider and you want to replace
	> the dll in Map you must copy also FDO libraries
	> (\\Fdo\Unmanaged\bin\win32\debug\)
	> If you want to use the debug libraries do not forget about debug
	> xerces-c_2_5_0D.dll and boost_thread-vc80-mt-gd-1_32.dll <last one is
	> only for WMS and WFS providers>)
	> Best Regards,
	> Romica.
	> Sent: Monday, October 16, 2006 6:12 AM
	> Cc: Rajneesh Verma
	> Dear Romica,
	>                           Thanks for your nice support. The build
	> process for MySQL provider is succssfull without any error.But it does
	> not produce MgFdoMySQLOverrides.dll files. But when i replace these
	> newly build     .dll files (only three)  with existing ones in
	> Autodesk map 2007 at the path " C:\Program Files\Autodesk Map 3D
	> 2007\FDO\bin ", the FDO  provider for Mysql does not work. It gives
	> the error message during Autodesk map 2007 startup.
	> C:\Program Files\Autodesk Map 3D 2007\AcMapWorkspace.arx cannot find a
	> dll or
	> other file that it needs.
	> .Failed.
	> AcMapWorkspace.arx Load FailedRegenerating model.
	> AutoCAD menu utilities loaded.
	> Command: COMMANDLINE
	> The names of the newly created three dll files are :
	> MySQLProvider.dll
	> MySQLOverrides.dll
	> RdbmsOverrides.dll
	> but still we could not create MgFdoMySQLOverrides.dll file.
	> waiting for your reply.
	> Thanks
	> On 10/13/06, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
	> > Hi Rajneesh,
	> > I had a look at the project Fdo\UnitTest\UnitTest.vcproj
	> >         - UseOfMFC="0" - ok
	> >         - PreprocessorDefinitions does not contains __CPPUNIT_MFC_APP
	> > ok
	> >         - The File Fdo\UnitTest\Pch.h does not contains define
	> > __CPPUNIT_MFC_APP - ok
	> > Everything looks ok. I tried a full build on a clean machine (with
	> VC++
	> > and VC# Express 2005 and it worked + SDK).
	> > Maybe your problem is coming from file
	> > Thirdparty\cppunit\HostApp\StdAfx.h
	> > In this file you should have next part of code (it's the only place
	> > where an afx (MFC) header file can be included):
	> > #ifdef __CPPUNIT_MFC_APP
	> >         #define _AFXDLL
	> >         #include <afxwin.h>         // MFC core and standard
	> components
	> >         #include <afxext.h>         // MFC extensions
	> >         #ifndef _AFX_NO_AFXCMN_SUPPORT
	> >                 #include <afxcmn.h>
	> >         #endif // _AFX_NO_AFXCMN_SUPPORT
	> > #else
	> >         #define WIN32_LEAN_AND_MEAN
	> >         #include <stdio.h>
	> >         #include <tchar.h>
	> >         #include <Windows.h>
	> > #endif // __CPPUNITMFCAPP
	> > Can you check please if you have the last version of Thirdparty
	> folder?
	> > Can you make an update on this folder and if something changed make a
	> > build?
	> > Also can you check for __CPPUNIT_MFC_APP if you defined?
	> > __CPPUNIT_MFC_APP must be undefined.
	> > Regards,
	> > Romica
	> > From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
	> > Sent: Friday, October 13, 2006 1:06 AM
	> > Cc: dev at fdo.osgeo.org; users at fdo.osgeo.org; 'Manjeet Sharma'
	> > Subject: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
	> [fdo-users]
	> > Hi Romica,
	> > We are getting these error messages during build process of both "Core
	> > FDO and  MySql FDO provider ".
	> > The project names that we are trying to build are:
	> > FDO.sln
	> > MYSQL.sln
	> > and we are getting these errors during the build process of subproject
	> > "unittest.sln" (FDO project) and "unittestmysql.sln" (MySQL project).
	> > Please mark your response to Manjeet also as he is working with us on
	> > this
	> > project.
	> > Thanks
	> > Rajneesh
	> > > From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
	> > > Sent: Thursday, October 12, 2006 8:11 PM
	> > > To: dev at fdo.osgeo.org
	> > > Cc: users at fdo.osgeo.org; Rajneesh Verma
	> > > Subject: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev]
	> > Query
	> > > on MySQL FDO
	> > > Hi Rajneesh,
	> > > Could you please tell me on which project (.sln and .vcproj) do you
	> > have
	> > > this error?
	> > > Could you please provide me more information?
	> > > Thanks,
	> > > Romica.
	> > > Sent: Thursday, October 12, 2006 2:34 AM
	> > > Subject: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL
	> > FDO
	> > > Hi Romica,
	> > > Thanks for the guidance. However, we are still facing problem as
	> given
	> > > below:
	> > > We have already done checkout of utilities folder and are getting
	> the
	> > > error
	> > > message as below:
	> > > c:\program files\microsoft visual studio
	> 8\vc\atlmfc\include\afx.h(24)
	> > > : fatal error C1189: #error :  Building MFC application with /MD[d]
	> > (CRT
	> > > dll
	> > > version) requires MFC shared dll version. Please #define _AFXDLL or
	> do
	> > > not
	> > > use /MD[d]
	> > > Regards
	> > > Rajneesh
	> > > > Sent: Tuesday, October 10, 2006 11:44 PM
	> > > > To: dev at fdo.osgeo.org; users at fdo.osgeo.org
	> > > > Cc: Rajneesh Verma
	> > > > Subject: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
	> > > > Hi,
	> > > > Because '[FDO Open Source]\Utilities' directory is not on your
	> local
	> > > > disk I think you took from SVN only fdo, thirdparty and rdbms. You
	> > > need
	> > > > also the utilities for providers.
	> > > > You can use checkoutsvn.bat to get/update your working folder by
	> > using
	> > > > -w command e.g.:
	> > > > checkoutsvn.bat -w=fdocore -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
	> > > > Or
	> > > > checkoutsvn.bat -w=fdo -w=utilities -w=rdbms -u=xxx -p=xxx -o=xxx
	> > > -s=xxx
	> > > > The option fdocore include utilities option.
	> > > > Before running checkoutsvn.bat, please update it from SVN.
	> > > > After this command you should have and build the utilities without
	> > any
	> > > > problems.
	> > > > If you still have problems please let me know.
	> > > > Regards,
	> > > > Romica.
	> > > Manjeet Sharma
	> > > Software Engineer
	> > > Daffodil Software Ltd.
	> > > To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
	> > > For additional commands, e-mail: dev-help at fdo.osgeo.org
	> > > To unsubscribe, e-mail: users-unsubscribe at fdo.osgeo.org
	> > > For additional commands, e-mail: users-help at fdo.osgeo.org
	> > Manjeet Sharma
	> > Software Engineer
	> Manjeet Sharma
	> Software Engineer
	Manjeet Sharma
	Software Engineer
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061017/6924e5f6/attachment.html
More information about the Fdo-internals mailing list
