[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Rajneesh Verma rajneesh at klgsystel.com
Tue Oct 17 09:34:23 EDT 2006
What versions does it support?
Regards
Rajneesh
  _____
From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
Sent: Tuesday, October 17, 2006 6:21 PM
To: Manjeet Sharma; dev at fdo.osgeo.org
Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com;
parveen.agarwal at daffodildb.com
Subject: RE: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Manjeet,
Latest FDO is not supported by the version of Map which you having.
Regards,
Romica.
-----Original Message-----
From: Manjeet Sharma [mailto:manjeet.sharma at daffodildb.com]
Sent: Tue 10/17/2006 1:07 AM
To: Romica Dascalescu
Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users]
Hi Romica,
I am sending you the following configuration details for FDO provider :
Product name: Autodesk Map 3D 2007
Product version: A.54.0 (UNICODE)
Product service pack: 0
License type: Standalone - Locked
License behavior: Unregistered Version
License usage type: In Trial
FDO provider version: 3.2.0.0
and we could not find the library file MgFdoMySQLOverrides.dll  after
build process at the following locations:
 \\Providers\GenericRdbms\Managed\bin\debug\ and
\\Providers\GenericRdbms\Managed\bin\release\
but we have another library file
OSGeo.FDO.Providers.MySQL.Overrides.dll at the same path. we tried to
use the same but the error message during autodesk startup is same as
i have told you earlier.
i have also tried all the newly build fdo core dll file (including
debug dependencies (Xalan-C_1_7_0D.dll, XalanMessages_1_7_0D.dll,
xerces-c_2_5_0D.dll) by placing all those files.
Right now i am trying to build the FDO provider  using FDO 3.0.0.0 version
Thanks
On 10/16/06, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
> Hi Manjeet,
> Please can you provide me the next information?
> In the menu Help -> About Autodesk Map 3D
>         -> Click on Product Information
> I need to tell me: Product Name, Product version, Product Service pack.
> It's very important if your Map version supports the latest version of
> FDO.
> Also in you install folder you have FDO\Bin and inside providers.xml.
> Please tell me the value of version node from providers (is it 3.0.0.0,
> 3.1.0.0 or 3.2.0.0)
> About MgFdoMySQLOverrides.dll you should find this library after build
> in: \\Providers\GenericRdbms\Managed\bin\debug\ or
> If you have build errors please let me know.
> Usually as rule, after you build one provider and you want to replace
> the dll in Map you must copy also FDO libraries
> (\\Fdo\Unmanaged\bin\win32\debug\)
> If you want to use the debug libraries do not forget about debug
> xerces-c_2_5_0D.dll and boost_thread-vc80-mt-gd-1_32.dll <last one is
> only for WMS and WFS providers>)
> Best Regards,
> Romica.
> Sent: Monday, October 16, 2006 6:12 AM
> Cc: Rajneesh Verma
> Dear Romica,
>                           Thanks for your nice support. The build
> process for MySQL provider is succssfull without any error.But it does
> not produce MgFdoMySQLOverrides.dll files. But when i replace these
> newly build     .dll files (only three)  with existing ones in
> Autodesk map 2007 at the path " C:\Program Files\Autodesk Map 3D
> 2007\FDO\bin ", the FDO  provider for Mysql does not work. It gives
> the error message during Autodesk map 2007 startup.
> C:\Program Files\Autodesk Map 3D 2007\AcMapWorkspace.arx cannot find a
> dll or
> other file that it needs.
> .Failed.
> AcMapWorkspace.arx Load FailedRegenerating model.
> AutoCAD menu utilities loaded.
> Command: COMMANDLINE
> The names of the newly created three dll files are :
> MySQLProvider.dll
> MySQLOverrides.dll
> RdbmsOverrides.dll
> but still we could not create MgFdoMySQLOverrides.dll file.
> waiting for your reply.
> Thanks
> On 10/13/06, Romica Dascalescu <Romica.Dascalescu at autodesk.com> wrote:
> > Hi Rajneesh,
> > I had a look at the project Fdo\UnitTest\UnitTest.vcproj
> >         - UseOfMFC="0" - ok
> >         - PreprocessorDefinitions does not contains __CPPUNIT_MFC_APP
> > ok
> >         - The File Fdo\UnitTest\Pch.h does not contains define
> > __CPPUNIT_MFC_APP - ok
> > Everything looks ok. I tried a full build on a clean machine (with
> VC++
> > and VC# Express 2005 and it worked + SDK).
> > Maybe your problem is coming from file
> > Thirdparty\cppunit\HostApp\StdAfx.h
> > In this file you should have next part of code (it's the only place
> > where an afx (MFC) header file can be included):
> > #ifdef __CPPUNIT_MFC_APP
> >         #define _AFXDLL
> >         #include <afxwin.h>         // MFC core and standard
> components
> >         #include <afxext.h>         // MFC extensions
> >         #ifndef _AFX_NO_AFXCMN_SUPPORT
> >                 #include <afxcmn.h>
> >         #endif // _AFX_NO_AFXCMN_SUPPORT
> > #else
> >         #define WIN32_LEAN_AND_MEAN
> >         #include <stdio.h>
> >         #include <tchar.h>
> >         #include <Windows.h>
> > #endif // __CPPUNITMFCAPP
> > Can you check please if you have the last version of Thirdparty
> folder?
> > Can you make an update on this folder and if something changed make a
> > build?
> > Also can you check for __CPPUNIT_MFC_APP if you defined?
> > __CPPUNIT_MFC_APP must be undefined.
> > Regards,
> > Romica
> > From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
> > Sent: Friday, October 13, 2006 1:06 AM
> > Cc: dev at fdo.osgeo.org; users at fdo.osgeo.org; 'Manjeet Sharma'
> > Subject: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
> [fdo-users]
> > Hi Romica,
> > We are getting these error messages during build process of both "Core
> > FDO and  MySql FDO provider ".
> > The project names that we are trying to build are:
> > FDO.sln
> > MYSQL.sln
> > and we are getting these errors during the build process of subproject
> > "unittest.sln" (FDO project) and "unittestmysql.sln" (MySQL project).
> > Please mark your response to Manjeet also as he is working with us on
> > this
> > project.
> > Thanks
> > Rajneesh
> > > Sent: Thursday, October 12, 2006 8:11 PM
> > > To: dev at fdo.osgeo.org
> > > Cc: users at fdo.osgeo.org; Rajneesh Verma
> > > Subject: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev]
> > Query
> > > on MySQL FDO
> > > Hi Rajneesh,
> > > Could you please tell me on which project (.sln and .vcproj) do you
> > have
> > > this error?
> > > Could you please provide me more information?
> > > Thanks,
> > > Romica.
> > > Sent: Thursday, October 12, 2006 2:34 AM
> > > Subject: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL
> > FDO
> > > Hi Romica,
> > > Thanks for the guidance. However, we are still facing problem as
> given
> > > below:
> > > We have already done checkout of utilities folder and are getting
> the
> > > error
> > > message as below:
> > > c:\program files\microsoft visual studio
> 8\vc\atlmfc\include\afx.h(24)
> > > : fatal error C1189: #error :  Building MFC application with /MD[d]
> > (CRT
> > > dll
> > > version) requires MFC shared dll version. Please #define _AFXDLL or
> do
> > > not
> > > use /MD[d]
> > > Regards
> > > Rajneesh
> > > > Sent: Tuesday, October 10, 2006 11:44 PM
> > > > To: dev at fdo.osgeo.org; users at fdo.osgeo.org
> > > > Cc: Rajneesh Verma
> > > > Subject: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
> > > > Hi,
> > > > Because '[FDO Open Source]\Utilities' directory is not on your
> local
> > > > disk I think you took from SVN only fdo, thirdparty and rdbms. You
> > > need
> > > > also the utilities for providers.
> > > > You can use checkoutsvn.bat to get/update your working folder by
> > using
> > > > -w command e.g.:
> > > > checkoutsvn.bat -w=fdocore -w=rdbms -u=xxx -p=xxx -o=xxx -s=xxx
> > > > Or
> > > > checkoutsvn.bat -w=fdo -w=utilities -w=rdbms -u=xxx -p=xxx -o=xxx
> > > -s=xxx
> > > > The option fdocore include utilities option.
> > > > Before running checkoutsvn.bat, please update it from SVN.
> > > > After this command you should have and build the utilities without
> > any
> > > > problems.
> > > > If you still have problems please let me know.
> > > > Regards,
> > > > Romica.
> > > Manjeet Sharma
> > > Software Engineer
> > > Daffodil Software Ltd.
> > > To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
> > > For additional commands, e-mail: dev-help at fdo.osgeo.org
> > > To unsubscribe, e-mail: users-unsubscribe at fdo.osgeo.org
> > > For additional commands, e-mail: users-help at fdo.osgeo.org
> > Manjeet Sharma
> > Software Engineer
> Manjeet Sharma
> Software Engineer
Manjeet Sharma
Software Engineer
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061017/77b6a11a/attachment.html
More information about the Fdo-internals mailing list
