[fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW: [fdo-users] RE: [fdo-dev] Query on MySQL FDO
Robert Fortin robert.fortin at autodesk.com
Wed Oct 18 09:15:58 EDT 2006
Map 2007 is compatible with FDO 3.1 providers.  You can find tarballs on
https://fdo.osgeo.org/servlets/ProjectDocumentList?folderID=93&expandFol
der=93&folderID=0 for SDF and SHP.  For preview of additional providers
(ArcSDE, MySQL, ODBC, WFS/WMS), you can find them at
https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=100&exp
andFolder=100&folderID=0
R050 is basically equivalent to Map 2007 SP2 and MapGuide 1.0 release.
R071 is part of the next service pack for MapGuide.  It is compatible
with Map 2007 SP3.
MapGuide 1.2  will be supporting FDO 3.2 providers.  Map will support
this version of FDO in its next release.
RF
  _____
From: Rajneesh Verma [mailto:rajneesh at klgsystel.com]
Sent: Wednesday, October 18, 2006 12:10 AM
To: Romica Dascalescu; dev at fdo.osgeo.org; Partha P. Sarkar
Cc: 'Manjeet Sharma'
Subject: RE: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev] Re: FW:
Hi Romica,
May we know the version which is supported by MYSQL provider?
Regards
Rajneesh
  _____
From: Romica Dascalescu [mailto:Romica.Dascalescu at autodesk.com]
Sent: Tuesday, October 17, 2006 8:38 PM
To: dev at fdo.osgeo.org; Rajneesh Verma; Manjeet Sharma
Cc: ganesh.bansal at daffodildb.com; parveen.agarwal at daffodildb.com
Hi Rajneesh,
For that version of Map which you have, is no open source code for MySQL
provider available.
For that version of Map you have only FDO, SHP and SDF providers
available.
Regards,
Romica.
	-----Original Message-----
	Sent: Tue 10/17/2006 9:34 AM
	To: Romica Dascalescu; 'Manjeet Sharma'; dev at fdo.osgeo.org
	What versions does it support?
	Regards
	Rajneesh
  _____
	Sent: Tuesday, October 17, 2006 6:21 PM
	To: Manjeet Sharma; dev at fdo.osgeo.org
	Cc: Rajneesh Verma; ganesh.bansal at daffodildb.com;
	Hi Manjeet,
	Latest FDO is not supported by the version of Map which you
having.
	Regards,
	Romica.
[mailto:manjeet.sharma at daffodildb.com]
		Sent: Tue 10/17/2006 1:07 AM
		Subject: Re: [fdo-dev] FW: FW: [fdo-users] RE: [fdo-dev]
		Hi Romica,
		I am sending you the following configuration details for
FDO provider :
		Product name: Autodesk Map 3D 2007
		Product version: A.54.0 (UNICODE)
		Product service pack: 0
		License type: Standalone - Locked
		License behavior: Unregistered Version
		License usage type: In Trial
		FDO provider version: 3.2.0.0
		and we could not find the library file
MgFdoMySQLOverrides.dll  after
		build process at the following locations:
		 \\Providers\GenericRdbms\Managed\bin\debug\ and
		\\Providers\GenericRdbms\Managed\bin\release\
		but we have another library file
		OSGeo.FDO.Providers.MySQL.Overrides.dll at the same
path. we tried to
		use the same but the error message during autodesk
startup is same as
		i have told you earlier.
		i have also tried all the newly build fdo core dll file
(including
		debug dependencies (Xalan-C_1_7_0D.dll,
XalanMessages_1_7_0D.dll,
		xerces-c_2_5_0D.dll) by placing all those files.
		Right now i am trying to build the FDO provider  using
FDO 3.0.0.0 version
		Thanks
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061018/27c7ac7b/attachment.html
More information about the Fdo-internals mailing list
