FDOIApplySchema
Haris Kurtagic haris at sl-king.com
Sat Oct 21 20:10:15 EDT 2006
I have couple of question:
1. I am trying to implement ApplySchema command in King.Oracle provider.
I have problem because I need to have Spatial context of geometries when
creating new schema and classes.
FDOIApplySchema interface is designed with FeatureSchema as only
parameter, no spatial context.
Geometry properties have Spatial Context name property but no spatial
context to read from in apply schema command.
There is command to create spatial context but it is another command so
it doesn't help me.
Am I missing something here ? I would appreciate if someone can comment
on this.
Note: I am trying to recreate Oracle tables from fdo classes and I am
not using fdo metadata tables.
2. How can I create clone of FdoFeatureClass ?
    I see that FDOFetaureSchemaCollection has a way to ser/deser  from
XML, but I would like to do it just for one class.
    I am testing with Set (FdoClassDefinition *pClass,
FdoSchemaXmlContext *pContext) , but I have filing that is not right way
Thank you,
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061022/2fb7a3a4/attachment.html
More information about the Fdo-internals mailing list
