[fdo-dev] sdf provider
Haris Kurtagic haris at sl-king.com
Tue Oct 31 18:06:36 EST 2006
Thank you
From: Greg Boone [mailto:greg.boone at autodesk.com]
Sent: Wednesday, November 01, 2006 12:03 AM
To: dev at fdo.osgeo.org
Subject: RE: [fdo-dev] sdf provider
See inline...
Sent: Tuesday, October 31, 2006 5:55 PM
Thanks,
1.	So no way to create a new class in existing non-empty sdf ?
[GB] No. I don't believe there is any way to do this.
2. I would think from your answear that get null is a error?
    I got already created sdf (created with standard tool ) files which
are returning null.
[GB] Someone will need to check into this futher....
Haris
Sent: Tuesday, October 31, 2006 11:51 PM
See inline...
Sent: Tuesday, October 31, 2006 4:36 PM
Subject: [fdo-dev] sdf provider
1. When I execute command apply schema on sdf which already has schema
applied in it, sdf provider returns error that schema already exists.
What is a way to add new class into existing sdf ?
[GB] No. You can only ApplySchema once for an SDF file
2. In some SDF's sdf provider is returning null for
GetSpatialContextAssociation
<https://fdo.osgeo.org/nonav/docs/FDO_API/df/d40/class_fdo_geometric_pro
perty_definition_ec20045b117ee761d323102dac225e68.html#ec20045b117ee761d
323102dac225e68>
    Is this in line whith fdo interface ?
[GB] I believe when you create the SDF file, you have to specify the
Spatial Context as part of the creation parameters.
Haris
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20061101/40eef46b/attachment.html
More information about the Fdo-internals mailing list
