[fdo-dev] Empty subversion logs
    Mateusz Loskot
    mateusz at loskot.net
    Fri Sep  8 17:50:19 EDT 2006
Romica Dascalescu wrote:
> Mateusz,
> On subversion you have different repositories for fdocore and each
> provider.
> When you create an artifact you create this artifact on fdo, the base
> project not on each repository.
> So when you submit some changes which affect more than one repository
> you must submit more than one time.
Romica,
Yes, I have it in mind, though I've not considered the common PT
as a kind of cross-projects issues synchronization utility ;-)
Thanks!
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals
