[fdo-dev] TestRunner project
Greg Boone greg.boone at autodesk.com
Fri Sep 22 10:31:03 EDT 2006
TestRunner was removed as a part of the default compilation of
Thirdparty components under revision 250.
> Revision: 250
> Author: gregboone
> Date: 7:30:18 PM, Tuesday, July 11, 2006
> Message:
> FDO89: Support Windows development using VCExpress (Remove C# Project
> from .sln file)
> Modified : /trunk/Thirdparty/Thirdparty.sln
> Modified : /trunk/Thirdparty/Thirdparty_fdo.sln
TestRunner was removed because it relies on MFC which is not available
in MS VCExpress. As part of supporting VCExpress, all FDO provider unit
test projects had their settings changed so that they do not
automatically link in TestRunner and it's associated MFC UI.
If the TestRunner MFC UI is required, define __CPPUNIT_MFC_APP in the
unit test preprocessor definitions and link in the TestRunner library.
Greg
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Thursday, September 21, 2006 5:16 PM
To: fdo-dev
Subject: [fdo-dev] TestRunner project
I don't know why, but TestRunner project is omitted during FDO
compilation on Windows. Here is screenshot with message underlined in
red:
http://mateusz.loskot.net/tmp/fdo-testrunner-not-build.png
Unfortunately, I have only polish version of Windows system,
so the message is in polish.
It means:
Project "TestRunner" has not been selected to compiler for Debug|Win32
configuration.
However, the same message is thrown for Release. So, I assume the
problem is with configuration of dependencies between projects.
Please, could anyone take a look at it and tell me where is the problem?
Thanks in advance.
I build Thirdparty module using:
- for release
.\build_thirdparty.bat -a=buildinstall -o=C:\fdo
- for debug
.\build_thirdparty.bat -a=buildinstall -o=C:\fdo -c=debug
Cheers
Mateusz Loskot
To unsubscribe, e-mail: dev-unsubscribe at fdo.osgeo.org
For additional commands, e-mail: dev-help at fdo.osgeo.org
More information about the Fdo-internals mailing list
