Does clean remove source files on Windows?
Mateusz Loskot mateusz at loskot.net
Fri Sep 22 15:03:06 EDT 2006
I've just noticed something strange on Windows.
Here is a small session:
C:\dev\fdo\svn> svn update
Next, I try to compile, etc.
Then I want to clean the source tree:
C:\dev\fdo\svn> .\build.bat -a=clean
Next I update:
Odtworzono 'Fdo\Unmanaged\Src\Fdo\Schema\SchemaFromInternal.h'
Odtworzono 'Fdo\Unmanaged\Src\Fdo\Schema\SchemaFromExternal.h'
Odtworzono 'Fdo\Unmanaged\Src\Common\Gml212\geometry.h'
Odtworzono 'Fdo\Unmanaged\Src\Common\Gml212\feature.h'
Odtworzono 'Fdo\Unmanaged\Src\Common\Gml212\xlinks.h'
Uaktualnione do wersji 388.
NOTE: 'Odtoworzono' means 'restored'
Next, immediately, I run clean again:
And, immediately, I run update again:
C:\dev\fdo\_svn>svn up
As you see, some files are restored every time after I run clean,
but without building or removing this files.
So, I suppose these are not intermediate files.
Is this a well-known and intentional behaviour?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
More information about the Fdo-internals mailing list
