[fdo-internals] automake/autoconf/libtool preferred version?
Sun Feb 11 14:49:27 EST 2007
Traian Stanev wrote:
> I remember having to fix this exact thing for my 64 bit build too, but I
> redeclared the variable len to be the correct type (i.e. not FdoSize,
> but whatever int Xerces wanted).
Traian,
Right, on reflection I came to the same conclusion.  I adjusted things to this:
warmerda at amd64[9]% svn diff FeaturePropertyReaderImpl.cpp
Index: FeaturePropertyReaderImpl.cpp
--- FeaturePropertyReaderImpl.cpp       (revision 2498)
+++ FeaturePropertyReaderImpl.cpp       (working copy)
@@ -532,7 +532,7 @@
          break;
      case ParsingState_base64Binary:
-            FdoSize len;
+            unsigned int len;
              XMLByte* decoded = XERCES_CPP_NAMESPACE::Base64::decode((const
XMLByte*)(const char*)m_dataProperty, &len);
              if (decoded != NULL) {
                  curFeatureHandler->FeatureBinaryData(m_featureContext,
decoded, len);
Are there any objections to me committing tihs change in trunk?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
More information about the fdo-internals mailing list
