[fdo-internals] FDO3: : It is not appropriate to use the first CRS as default SC when multiple CRS codes are provided.
Greg Boone greg.boone at autodesk.com
Mon Feb 12 18:35:30 EST 2007
Code Submission Notification:
Author: gregboone
Date: 2007-02-12 18:38:11 -0500 (Mon, 12 Feb 2007) New Revision: 2505
   trunk/Providers/WMS/Src/Provider/FdoWmsConnection.cpp
   trunk/Providers/WMS/Src/UnitTest/CubeServer_WMS_Config.xml
   trunk/Providers/WMS/Src/UnitTest/WmsTestDescribeSchema.cpp
   trunk/Providers/WMS/Src/UnitTest/WmsTestSelect.cpp
This submission resolves FDO Ticket:
FDO3 - WMS: It is not appropriate to use the first CRS as default SC
When a WMS layer is available in several coordinate reference systems,
the first one listed in the capability document has been used as the
default spatial context for that layer. A more appropriate way to deal
with such situation is trying to use the most universal one, or
non-distortion one, e.g., geographic coordinate systems is preferable to
projected CRS.
Here is an example,
http://www.datadoors.net/$_streaminguid.258b2328-80bc-426a-a0a1-fc2023db
b333/wms.ashx?
All layers served in this server are available in many CRSs and
EPSG:4267(LL27) is listed first. As a result, LL27 is the default
spatial context for all layers. However, when layers are requested via
LL27, the areas outside NA can't be rendered properly by the server.
When switching to another available CRS EPSG:4326 (LL84), all the layers
will work properly.
Since we don't allow specifying CRS for layers via UI in both Map and
MapGuide, choosing a more appropriate CRS for a layer becomes more
important for rendering a layer properly.
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070212/436641ec/attachment.html
More information about the fdo-internals mailing list
