[fdo-internals] Revision 2547 - Align MySql Schema Manager with changes to generic level.
Brent Robinson brent.robinson at autodesk.com
Thu Feb 15 15:44:21 EST 2007
Revision: 2547
Author: brentrobinson
Date: 4:34:40 PM, Thursday, February 15, 2007
Message:
View support - Aligned MySql Schema Manager with changes to generic
level. Fixed various memory leaks.
Modified :
/trunk/Providers/GenericRdbms/Inc/Rdbms/Override/RdbmsOvGeometricPropert
yDefinition.h
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Lp/GeometricPropertyDe
finition.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/DbObject.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/DbObject.h
Modified :
/trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Table.cpp
Modified : /trunk/Providers/GenericRdbms/Src/MySQL/SchemaMgr/Ph/Table.h
Modified :
/trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ObjectPropertyDefinition.
cpp
Modified :
/trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/PropertyMappingConcrete.c
pp
Modified :
/trunk/Providers/GenericRdbms/Src/SchemaMgr/Ov/RdbmsOvGeometricPropertyD
efinition.cpp
Modified : /trunk/Providers/GenericRdbms/Src/SchemaMgr/Ph/Mgr.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoApplySchemaTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.cpp
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoUpdateTest.h
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalBender.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/LogicalPhysicalFormatter.xslt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test1_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test2_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test3_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test4_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test5_master.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_test_ov3_master.
txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_ma
ster.txt
Modified :
/trunk/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master
.txt
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
Modified : /trunk/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
URL: http://lists.osgeo.org/pipermail/fdo-internals/attachments/20070215/ce93a535/attachment.html
More information about the fdo-internals mailing list
